Question about Amana ARGS7650SS Gas Kitchen Range
Ignitors do not turn off
Have a Maytag 4 burner gas stovetop. Problem is when all burner valves are turned off, the sparks still fly! Need to pull the plug and wait a long time for the problem to stop. Schematic shows all 4 burner valves/switches in parallel, so any one can provide AC hot to the ignitor box. Should I trust schematic and assume one of the 4 valve switches must be stuck on?
  • pshoetoe Jan 13, 2009
    The burner switches are inside the covered unit. I cannot easily check them. Also, the problem has "fixed" itself for now, but, when it returns (and I'm sure it will) I will inspect and measure as you recommend. I can't image how this could be the spark module if the burner switches remove AC power when closed.
  • pshoetoe Feb 09, 2009
    The problem returned. And sure enough it is due to moisture getting inside the box or valve switches and causing the ignitors to turn on with the valve switch off. This time the fuse blew.
    Sergeant:
  • 311 Answers
It is the place to start.you can use an ohm meter to check if the burner switches are open when the burner knobs are in off position.if the consumer cleans with water if it dosen't just short switch the water can also act as a conductor ,so make sure dry.then inspect wiring for frayed areas that could short curcit.then if all that checks good its your spark moduel. God bless ,tom
Posted on Jan 08, 2009
    Genius:
  • 2,920 Answers
You will need to call in a repeairman to fix the igniters they can be tricky to work on and its my guess the control panel has something to do with it, call in a repairman and have it fixed right
JDS9860AAP Front e-burner does not light.
follow this instructions. God bless you
    • 1
      Unplug your unit and turn off the gas supply at the saddle valve near the unit.
    • 2
      Lift up the hood of the oven. If you have sealed burners, the lid will not lift up. Locate the ignitors near the burners of the unit. Clean any gunk away from the ignitor using a toothbrush. Test the unit.
    • Sponsored Links
    • 3
      Pull the burner dials off the front of the unit if the ignitors won't work.
    • 4
      Remove the screws at the ends of the front cover, where the gas supply knobs are located, using a screwdriver, and remove the cover from the oven.
    • 5
      Slide the wires off the burner valve switches and pull them off the burner valve by sliding the switch forward. The switch will have wires attached to it. Loosen the screws holding down the wires of the burner valve. Pull out the wires carefully. Place the wires in a new switch. Slide the new switch onto the burner valve. Replace the knob, and turn on the gas supply and power. Ignite the burner.
    • 6
      Follow the switch wires into the oven if the new switch doesn't work. Locate the module box, which is usually 2 inches by 3 inches. Slide the wires out of the module terminal by pulling on the wire connectors. Remove the screws from the old module and pull the module out. Insert the wires into the new module, using the same wire orientation as before. Reassemble the oven. Turn on the electricity and gas, and turn on the burner.
Read more: http://www.ehow.com/how_7925141_repair-electronic-ignition-gas-stove.html#ixzz2ZPuc5nad
Jul 18, 2013 | Kitchen Ranges
Viking model VGR48 stovetop burners will not ignite?
First shut off the gas supply & disconnect electrical power to the range.
  • Remove all the burner control knobs, grates, burner caps & trim rings.
  • Remove the 2 screws securing the manifold panel, one from each corner. The panel will drop down.
  • Remove the screws from each manifold pipe mounting bracket. Remove 1/4 inch hex head bolt from the center of the manifold pipe. Push supply tube back to release from manifold pipe. Lift the cooktop assembly at the front to clear the 1/2 inch locator pins attached to the top of the bodyside.
  • Place cardboard between each side of cooktop & bodyside to prevent damage.
  • Move the cooktop to one side, being careful not to put stress on the wiring harness on left side.
  • Remove the wire from the electrode.
  • Remove the screw from the electrode mounting bracket to release the electrode.
You can replace the electrode & reassemble following instructions in reverse order.
Aug 20, 2008 | Viking VGSC306-4B Gas Kitchen Range
Electronic ignitors won't stop clicking
Pull the burner caps, etc off the stove and completely dry the area ..Be sure to inspect each ignitor contact for cleanliness as well. If the ignitors have soapy buildup or water, around them, they can act like this.
You should be able to pull the burner caps and flame diffusers off and clean with a paper towel, and if needed, a light scouring sponge. Be careful not to scratch the surfaces, but scour the top of the ignitors carefully if you need to clean them.
Jul 31, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Stove top burner ignitors will not turn off
This tip I wrote to help people with the problem of the spark not shutting off...the clicking non-stop is a common problem.
Gas Range2_bing.gif Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 30, 2010 | KitchenAid KGST307 Gas Kitchen Range
Ignitors on all burners are not working . gas is coming to burners , i can lite them with a match. i cannot hear the ignitors clicking when i turn the gas on for each burner either.
Hi, when any of the knobs is turned to the light position, all burners will spark. That being said, if one or more of the knobs is not switching the spark module, the problem is the switch mounted on the shaft of that burner valve. You need to replace the defective switch or you could turn on one of the good burners (to make the clicking occur) and then light the burner you really want.
Jan 24, 2010 | Whirlpool Kitchen Ranges
Spark ignitors on ge jgp636 either don't work or lght wrong burnr
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Dec 19, 2009 | GE Profile JGP636 Gas Cooktop
The ignition keeps on sparking after the burner is lit.
How old oof a unit is it? The burners switches when on will operate ignitors for all burners no matter which switch is "turned on". Usually when units get older these switches on the most "often used" burners will stick and stay "connected" then all ignitors will continue to spark this is also true if switches accidentally get wet with spillage or water till they dry out. No danger though because jsut because ignitor is sparking doesnt mean gas is being released, gas is only released when valves are turned on
May 22, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Spark ignitors on gas stovetop wont stop sparking
Make sure yo haven't spilled liquid on the ignitor becuase this will cuase all ignitors to spark constantly. If all is dry, the spark module must be replaced.
Feb 15, 2009 | Cooktops
Jenn-Air Gas Cooktop Model CVGX2423
you will need to contact your certified local service tech.you might have a distributor problem at yor ignitor box.if the problem is not with your ignitors.
Jun 30, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Amana ARGS7650SS Gas Kitchen Range Logo
109 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
