Question about Coleman Powermate Premium Plus 6250W Portable Generator
Have a colemene powermate that will not stay started
When I start the unit it runs for a few seconds and shuts off. I have checked the filter in the gas tank and it apprears fine. I am thining the carb is stopped up. Can I run some carb cleaner in the unit or is there something else I should check first. I did replace the spart plug
  • Anonymous Feb 12, 2009
    I HAVE A COLEMAN 4000 WATT GENERATOR THE REPAIR SHOP CLEANED THE CARBURATOR ,REPLACED THE CARBURATOR ,CHANGED OIL, PLUG. FUEL LINES AND 300 DOLLARS LATER IT DOES SAME THING, IT RUNES FINE UNTIL 20 MINUTES OR LESS AND THEN IT BACK FIRES AND DIES OUT
Check the Oil. If it is low, the Low Oil cutout will shut the engine off after a few seconds. If the oil is full, try disconnecting the oil sensor. If this makes it run, you will need to diagnose and repair the cutout system.
Posted on Jan 21, 2009
  • Leo Harrington
    Leo Harrington Oct 29, 2013
    I added a little oil and it works great. Thanks for the info
Bad fuel? or varnished inside of carburetor needs to be removed all ports and jets thoroughly cleaned out should solve your problem
Posted on Jan 13, 2009
Proforce powermate 2300 wont run for more than 1 minute, starts in a few pulls....runs than shuts off. Is there a reset switch for the low oil shut off? Only thing i can think of.
It might be a clogged fuel filter or dirt in the float needle. Fuel will fill the carb slowly, allowing you to start it, but it cannot flow fast enough to keep up with the demands of the engine and it runs out of fuel. It sits long enough to refill the carb, you can get it started again, and the process repeats.
Mar 14, 2014 | Coleman Electrical Supplies
Coleman Powermate PM0545007 generator. Unit started and ran. I turned on a window air unit and it worked ok then in about a minute the generator shut off. We are in a hurricane, so I'm trying to...
The generator has a low oil level sensor. Fill the oil all the way to the FULL mark and try it again.
IF you still have the problem after adding oil; repsond here and I can still help you. Just want to get this off as it has been 4 hours since your post.
Kelly
Aug 28, 2011 | Coleman Powermate Premium Plus 6250W...
My powermate 5000 with subaru engine will run anywhere from 30-60 minutes and shut down. One light pull to the pull start and it runs great for another 30-60 minutes. Never a problem to start it back up...
There is debri or dirt in gas tank and eventually it gets sucked up and clogs the screen filter on the end of gas line. Drain gas tank and flush out a few times. let dry and put new gas in it. check your gas can, if it is metal, it may have rust in the bottom of it and it goes in the gas tank and clogs screen, make sure you have a clean gas can that you use to fill the generator.
Aug 25, 2011 | Coleman Powermate Subaru 5000W Portable...
Coleman Powermate 5000 with 10 HP Tecumseh engine. It had a float problem and leaked gas out the air filter. I replaced the float and stopped the leak, but now it won't start. It will start if engine...
I have a Coleman Powermate 5000 with 10 HP Tecumseh engine. It is very hard to get started. once started runs great . But when you shut it off and try to restart it it will not start.
I have plenty of fire. I also replace the carb.
I still have problems getting it started. I tried to start it with out the filter also. What can i try next?
Thanks for any help
Jun 18, 2010 | Coleman Powermate Powermate 5000W...
WHERE CAN I GET A NEW CARBURETOR FOR COLEMEN POWERMATE 5000
If you have a local small engine shop. They can help. If not, try ebay.
Mar 05, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
614 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Rivera
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
