Question about Microsoft Windows 2000 Professional for PC
Boot from CD
I'm trying to dual boot windows 2000 and Ubuntu on my PC
I have already set up the bootable disk, but when i try to make the computer boot from the disk drive first, it wont. When i reboot the computer after i attempt to switch the boot order, it says ''loading bootable drives'' then goes to another screen that says ''A: Drive Error
press F8 to resume''
  • Jack Redder Jan 09, 2009
    I've tried to, but it isn't listed in the boot-from option. It just looked like this:
    Diskette Drive (A:) First
    Hard Drive (C:) Second
    Compaq Ethernet Controller Third
  • Microsoft Master
  • 19,396 Answers
Try going into the Bios setting and setting the boot order sequence with the CD as first booting device.
Posted on Jan 08, 2009
How to remove ubuntu-linux from pc
Hi Fred,
I would like to inform you that you can't remove Linux or Ubuntu using this method as it has boot loader. May I know if it is dual boot with Windows? I would suggest to backup all your data by booting to Windows and then format PC using Windows Bootable disk.
Warm Regards,
Abhay Pujari
Jan 07, 2015 | The Computers & Internet
Bios does not see cd-rom but dos does, can't boot cd
Sounds like a hardware issue. Try downloading UBUNTU as an alternative to Windows. If you still need windows Install virtual box for UBUNTU and run it that way.
Virtual Box: https://www.virtualbox.org/wiki/Linux_Downloads
You probably have tried holding "F12" during bootup. This will give you the option to start from the CD.
If you suspect it's a BIOS issue try flashing the BIOS. You can do this by going to the PC manufacturer website and searching for support- Drivers and downloads.
If your BIOS supports USB boot you can try to update the BIOS that way. Then going back and configuring it for CD boot.
You can also try to create an ISO image of Windows and install it via USB.
Mar 10, 2012 | Computers & Internet
NTLDR is missing
Causes
  1. Computer is booting from a non-bootable source.
  2. Computer hard disk drive is not properly setup in BIOS.
  3. Corrupt NTLDR and NTDETECT.COM file.
  4. Misconfiguration with the boot.ini file..
  5. Corrupt boot sector / master boot record.
  6. Seriously corrupted version of Windows 2000 or Windows XP.
  7. Loose or Faulty IDE/EIDE hard disk drive cable.
  8. Failing to enable USB keyboard support in the BIOS.
Solutions
Many times this error is caused when the computer is attempting to boot from a non-bootable CD-ROM. First verify that no CD is in the computer, unless you are attempting to boot from a CD.
Nov 29, 2011 | HP Compaq 6710b Notebook
Ntlrd missing xp tablet on my hp tc1000 with no cd rom
Causes
  5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
  6. New hard disk drive being added.
  7. Corrupt boot sector / master boot record.
  8. Seriously corrupted version of Windows 2000 or Windows XP.
  9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Solutions
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette or CD is in the computer, unless you are attempting to boot from a diskette.
Note: This error has also been known to occur when a memory stick is in a card reader and the computer is attempting to boot from it. If you have any card reader or flash reader make sure that no memory stick is inside the computer. Additionally disconnect all USB drives, cameras, ipods, iphones, etc. from the computer.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again.
Note: If you are not receiving the above message and your BIOS boot options are set properly it's also possible that your CD-ROM drive may not be booting from the CD-ROM properly. Verify the jumpers are set properly on the CD-ROM drive.
Verify that your computer hard disk drive is properly setup in the CMOS setup. Improper settings can cause this error.
Corrupt NTLDR or NTDETECT.COM file
Windows 2000 users
Windows XP users
Sep 24, 2011 | Computers & Internet
How can I uninstall Ubuntu from Dual Boot. I have a dual boot of Windows Vista Ultimate with Ubuntu 9.04 The specs of my computer is 2gb ram, 500 gb HDD and dual core processor 2.66ghz (E5300). I installed...
How to remove Ubuntu from a Vista dual-boot config
On my new PC I wanted (still want) to have toa go with Linux. I chose to experiment with Ubuntu. I downloaded thedesktop CD, burned it, freed up some disk space (inside Vista) andloaded up Ubuntu from the CD. After some experimenting I figured outhow to install Ubuntu in the empty disk space and it all worked fine(GRUB took over my booting (recognized Vista automatically!) and Ubuntuloaded up fine).
Then I tried to install my GPU drivers andeverything went wrong.. For some reason Ubuntu wouldn't boot anymore(failed to load X-Server or something). I was completely lost andwanted to remove Ubuntu.
This is where things start to get really messy!
Ifyou simply remove the Ubuntu partition, GRUB (Linux boot loader) willstill be on your PC (in control). It will trip out, as the Ubuntupartition will be removed.. Bad thing!
So you need to restore your Master Boot Record (MBR) for Vista (so that Vista will handle the booting, not GRUB).
Googleonly pointed me to sites that explained how to REMOVE VISTA, whichisn't what I wanted. Many sites talked about the 'fixmbr' command, butthis is really only available in Windows XP.
So how do you restore your MBR for Windows Vista?
1. Put the Windows Vista installation disc in the disc drive, and then start the computer.
2. Press a key when you are prompted.
3. Select a language, a time, a currency, a keyboard or an input method, and then click Next.
4. Click Repair your computer.
5. Click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options dialog box, click Command Prompt.
7. Type Bootrec.exe /FixMbr, and then press ENTER.
That'sit. Now when you reboot your PC, Vista will load automatically... Youcan now safely boot using your Ubuntu desktop CD, to use the built inGnome Partition Manager to remove your Ubuntu partition!
Apr 06, 2010 | Microsoft Computers & Internet
0xc000000f error, Laptop wont boot into vista, tryed vista dvd to try recovery but wont load
That error maybe a harddrive faulty / not connected. But you may need to go into the setup/bios and change the boot order so that it boots from CD first To get into the bios when the PC boots you should see a message on the screen for a very short while which will tell you how to get into the setup/bios - usually by pressing a key - like F2, or DEL key or F10 once in the bios you then need to go through the menus at the top until you find a menu page which includes the boot order - make sure CD is first
Another test, if you have access to another PC and CD writer, would be to create a bootable CD from ubuntu - this will boot from the CD only and test that the hardware works
goto http://www.ubuntu.com/ and download the ISO
full details are here http://www.howtogeek.com/howto/windows-vista/use-ubuntu-live-cd-to-backup-files-from-your-dead-windows-computer/
click on the image "download ubuntu"
Select a location
then begin download
Save the file onto your PC – remember where you saved it – so you can find it again to create the image bootable CD.
You do NOT copy the ISO file onto a CD - you have to use the ISO to create a bootable CD The CD creator software you have on the PC may have an option to create an image from an ISO If not - use this free program http://www.imgburn.com/
When the UBUNTU CD boots - you will see the following options 1) Try ubunto without any change to your computer 2) Install ubuntu 3) Check CD for defects 4) Test memory 5) Boot from first hard disk.
Use OPTION 1 "Try ubunto without any change to your computer" ONLY this option this will run from the CD and not install onto your harddrive - be careful, if you do install onto the PC - you will wipe the data and software OFF your hard drive.., so repeat only use option 1
Now you should see a UBUNTU desktop This at least proves the main parts of the PC are working
With UBUNTU it may just be possible to copy any of your data onto a USB harddrive or thumbdrive
Feb 27, 2010 | Toshiba Satellite Pro P300 Notebook
I hav ejust purchased a new lg gh22 dvd writer. It is working fine in operating system like windows xp and ubuntu. The bios also recognizes the drive. But when i insert a bootable cd/dvd of ubuntu windows...
hi,
Is the hard disk drive is in secondary slave? If yes, change it to master and your dvd is into slave. Refer to the jumper settings at the back on the drive. If not work, your bootable disk may defective. Try other a botable disk.
Best regards,
geloaa
Oct 06, 2009 | Intel Desktop Board D815EEA2 (BOX815EEAA2)...
Dual Boot Ubuntu
1st, install windows or if you have already its good .
Then, download Linux distribution that suits You better
Download It and burn into a CD or DVD with ISO file you can use Magic ISO or other manufacturer
then Go to BIOS setup and set 1st priority is the CD or DVD drive and save and exit
and install follow the instruction of linux.
also if you chose capacity of windows or linux is to little dont worry you can make install a partition magic and resize what you like....
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Sep 07, 2008 | Canonical Ltd. Ubuntu
I cant identify the prolem
It looks like you may have a boot sector virus. A boot sector virus is one that infects the first sector, i.e. the boot sector, of a floppy disk or hard drive. Boot sector viruses can also infect the MBR. All disks and hard drives are divided into small sectors. The first sector is called the boot sector and contains the Master Boot Record (MBR). The MBR contains the information concerning the location of partitions on the drive and reading of the bootable operating system partition.
When disinfecting a boot sector virus, the system should always be booted from a known clean system disk. On a DOS-based PC, a bootable system disk can be created on a clean system running the exact same version of DOS as the infected PC. From a DOS prompt, type:
    SYS C:\ A:\
and press enter. This will copy the system files from the local hard drive (C:\) to the floppy drive (A:\).
If the disk has not been formatted, the use of FORMAT /S will format the disk and transfer the necessary system files. On Windows 3.1x systems, the disk should be created as described above for DOS-based PC's. On Windows 95/98/NT systems, click Start | Settings | Control Panel | Add/Remove Programs and choose the Startup Disk tab. Then click on "Create Disk". Windows 2000 users should insert the Windows 2000 CD-ROM into the CD-ROM drive, click Start | Run and type the name of the drive followed by bootdisk\makeboot a: and then click OK. For example:
    d:\bootdisk\makeboot a:
Follow the screen prompts to finish creating the bootable system disk. In all cases, after the creation of the bootable system disk, the disk should be write protected to avoid infection.
Once the OS loads, run your anti-virus software and it should clean the virus.
Should this not help, I'm afraid the only other alternative would be to reformat the HDD and reinstall XP again from a bootable disc.
Hope that helps..
May 07, 2008 | Computers & Internet
Microsoft Windows 2000 Professional for PC Logo
44 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
