Question about Samsung HCN436W 43" Rear Projection Television
Broke ariel knob
I accidently broke off the ariel knob at the back of the tv can it be repaired or any thing????
    Genius:
  • 2,920 Answers
Yes it can be repaired.youll need to call a tv repair shop and have them come out and fix it but it shouldnt cost alot to repair
Posted on Jan 08, 2009
Broken ariel input on back of tv
the cover has to come off and the old or a new connector needs to be soldered in.
Sep 22, 2015 | Samsung UE42F5000AK 42" LED TV 1920x1080,...
No or bad signal
Check in the Installation Menu that Antenna Power is set to OFF.
There is a chance that the water that came down the aerial lead has damaged the tuner module in the Humax.
Dec 28, 2013 | Humax PVR9300T HD DVR
How do i connect a 64 nintendo to the tv HITACHI
I am presuming that by 64 nintendo you are refering to a Nintendo 64 console (or N64 for short). to connect it to any TV you will need a N64 RFunit which is often in the back of the N64 already along with a wire that goes to a standard ariel. just connect this ariel to the ariel port in the back of you Hitachi TV and it should connect. If you have any further issues with this, feel free to e-mail me at garleet@hotmail.co.uk :)
Jan 05, 2012 | Nintendo Video Game Consoles & Games
Recieving no digital channels in my LCD TV
hi there alot of the updates for the system should automaticly download via ariel to the tv to keep you up to date some times if the strenght of the signal isnt srong enough then you might not get the update they send out , one thing i have found is that if you use an ariel booster then this makes the signal stronger this helps particularly if you have more than one tv set up with the same ariel, you could try unpluging all ariels to other tvs making sure the ariel lead you are using has no conections in it as this also gives you loss of signal if there are multiple conections in the lead runing from the ariel to your tv set hope this helps some
Cheers ;)
Feb 05, 2009 | Toshiba Regza 42C3030DB 42 in. LCD TV
No signal on my goodmans xpro freeview on the flat screen it says
hi there the first thing i would make sure you have a wide band ariel capable of receiving free view if the ariel is old and was there before you moved in and you have been there a while theres a good chance that the ariel isn't a wide-band ariel,
also check here with your post code to make sure free view is transmitted in your area
http://www.freeview.co.uk/availability
if you know you can get it and you have a wide band ariel make sure all connections are secure and that you don't have many leads connected together because you will lose a vast amount of quality though many leads to a point where you wont get a picture also make sure its the only tv on the connection as having a few will also do the same thing. ariel boosters can make a massive improvement on the line these can be bought any where even you local asda/walmart, make sure you have one secure connection right to the ariel socket to your tv. this eliminates any other problems
make sure you have your tv tuned in right if you have just moved house you will need to rescan for Chanel's as they can be on different frequencies from where you last lived
I hope this helps you if you Need a maual for your set please leave make and model number from the back of the set and ill try and get u a online manual for this set
Good Luck Hope You Sort It
Feb 03, 2009 | Archos AV 500 400-Hours Video Recorder
Ariel socket broke
ya got to pul the panel apart to remove the old connection then you have to solder a new one in place mabey Radio shack might have a generic part to fix it . just trying
Jan 03, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Ariel socket in tv has broken
The best thing is to replace the signal board, that costs $24.
Check here for the part : Polaroid Replacement TV Parts
You find the part on Ebay here.
Part number is 200-013-JK371-1AH FLM-323B
Oct 24, 2008 | Polaroid LCD-2050 20 in. Television
Tv repair
Depends on the make and model, possibly be the entire main board or the tuner board
Nov 20, 2007 | iLO 2600 Television
Broken coax input to back of tv
NOT REALLY BUT YOU COULD GET ROUND IT BY BUYING A £20 DIGIBOX (FREEVIEW BOX) AND CONNECTING IT TO THE TV WITH SCART AND ARIEL GOES INTO THE DIGIBOX (FREEVIEW BOX).
MEANS YOU CANNOT WATCH ANALOG ON THE TV ANYMORE BUT DIGITAL IS MUCH BETTER.
Nov 12, 2007 | Protron PLTV-26 26 in. HD-Ready LCD...
Samsung HCN436W 43" Rear Projection Television Logo
Henry  Thomas
Henry Thomas
