Question about Kenwood KDC-MP528 CD Player
Auxillary input I am having trouble figuring out how to get to the auxillary input setting on my faceplate. I have had it there in the past, but for some reason it disappeared about a week ago. I have gone through the manual thoroughly and there is no solution for the problem. It is not just a matter of pressing the SRC button. That takes you through the available options, but AUX is not appearing. I had a similar problem when the system was first installed, but it was a matter of getting it set up. Because the manual does not have this information it would be great if someone could help me out!! I just need to be able to listen to my ipod.
    Scholar:
  • 125 Answers
There is a setting to called `Aux On' and 'Aux Off' on PAge 27. MAybe it is set to off.
Posted on Jun 01, 2007
Won't go to tuner
If the set's input is selected to AV, it will skip tuner. Check whether its the reason. Check its input selection first. If it is set to AV; set it to TV. Gopakumar Gopalan Google
Mar 19, 2014 | Televison & Video
Finding auxillary
you must make sure your radio come with Aux input feature. or else may not be able to support
Nov 25, 2013 | JVC Car Audio & Video
How do i take apart my dr heater dr-968
I am also trying to disassemble my DR-968 but am having trouble with the faceplate. Has anyone figured out how to remove the faceplate?
Mar 17, 2013 | Heating & Cooling
I cant figure out how to get an MP3 player to play through my CD player....it has 3 different audio rca jacks in the back...i try all three none worked....is there an AUX setting that need to put my cd...
what kind of cd player do you have? you must make sure that your unit has auxillary inputs. some decks dont have them. if it is set up with aux input rca's, then you just connect those to the mp3 player, then you should be able to play it in the aux mode on the deck. if you cant find it by hitting the source button, then you may not have it. I know on my sony stereo, I actually had to turn the deck off with the ignition switch on. then I press the menu button, and there I can toggle the aux mode on or off. if that doesnt work either, then you either dont have aux inputs, or the inputs are bad on the stereo, meaning its not gonna work at all.
Jul 28, 2009 | Car Audio & Video
2 discs stuck in console
WOW!!! I am so sorry that this happened. Nintendo products are really hard to open. If you cant wedge the game out with a small screwdriver, dont worry about the game, here are the directions on opening it. Just copy and paste to word so you can see the whole thing easily.
How to open your Wii Console Step by Step Instructions
To disassemble:
  1. Flip the device upside down and remove the small silver Phillips screw. Once out, remove the battery tray from the console.
  2. Next remove the rubber foot directly above this battery tray. Also remove the three square white stickers from the bottom of the Wii. The rubber foot and the sticker are covering hidden screws. Figure 3 provides a shot of where these screws are located. NOTE
    Hiding screws under stickers and rubber pads is a common method used by electronics manufactures to help increase the aesthetics of their devices, as well as prevent people from easily locating screws and taking apart their products.
  3. Unscrew the two Triwing screws and three Phillips screws from the bottom of the Wii.
Figure 3 - Bottom Screws
  1. Flip the Wii over onto its right side. Locate and remove the two rear rubber feet and the two rectangle stickers near the faceplate.
  2. Remove the two silver Triwing screws in the holes and remove the two black Triwing screws on the faceplate (Figure 4).
Figure 4 - Left side screw locations
  1. Flip the Wii upright and carefully remove the two socket covers. They come right out with a little wiggling.
  2. Remove the three black Phillips screws from the black plate (Figure 5). Note the one closest to the faceplate is the longest and will need to go back into that hole when putting the Wii back together.
Figure 5 - Top black plate screw locations
  1. With the screws removed, carefully pull off the faceplate of the front of the Wii. You will need to disconnect the red/black wire plug from the Wii to remove the faceplate completely. Figure 6 shows what is hiding under the faceplate.
wiifig06.jpg Figure 6 - Under the Wii faceplate
  1. Remove black plate from memory/controller socket area.
Remove two silver Phillips and two silver Triwing screws from memory/controller socket area (Figure 7). wiifig07.jpg Figure 7 - Topside screw locations
Lay the Wii on left side (with the ATI and Nintendo logo facing you) and slowly work the right side cover of the console off the device.
This will take a little bit of force. If something appears to be stuck, double check to ensure you removed all the screws.
Locate and remove four screws holding DVD reader in place. Two are located in plain site in the middle of the unit. Two are located near the front of the Wii inside the DVD unit (Figure 8). wiifig08.jpg Figure 8 - The insides of the Wii
Slowly tilt the DVD player upward toward top of Wii. There are two wires that need to be disconnected before you can safely remove the DVD unit. One is a plug type of connector that only requires a little tug. The other is a circuit strip connector that requires you to lift the brown catch, which will release the pressure holding the strip in place (Figure 9). Do not break this!
May 11, 2009 | Nintendo Wii Console
Aux wont work
Make sure that "AUX" is turned on on the menu. Some Pioneer radios have a front aux, a rear aux, a rear steering wheel control jack, and an aux through the IP-BUS only. First, make sure that if there is an auxillary port on the back of the unit, that it isn't the steering wheel control plug by accident. Second, front auxillary inputs on Pioneer radios NEVER need to be turned on in the menu, only inputs on the back. Any back inputs are turned on in the main set-up menu when the radio is first turned off. Hope this info helps.
Aug 22, 2008 | Pioneer Audio Players & Recorders
Auxillary mode!
I'm sorry, but you need the original remote or a universal that will activate the input on the tv.
Dec 15, 2007 | Sansui COM312AD 13" TV/VCR Combo
Auxilary
If your cd player is a DEH-P4600MP (mp3 player)then you have to turn off the player first, then press the button on the upper right hand corner of the faceplate and then scroll through the menu and find aux to turn it off or on with the "wheel" on the right on the faceplate. You will also find the alarm and clock settings there in the menu as well but the key is to make sure the player is off first while doing this or you can't access the menu. To use the auxillary input on the back of the unit you need to purchase (eBay has them) an aux input adapter ref CD-RB10 cable. Hope this helps.
Aug 01, 2007 | Pioneer DEH-P4600 CD Player
Playing itunes through receiver
On the back of your tower you should have auxillary outputs that will go into your receiver. Get a connection going between the two ports and you should have perfect sound. The sound that comes out of your headphone output will not really have the amount of power that your receiver needs. Hope this helps.
Sep 14, 2006 | Marantz SR-5600 Receiver
Kenwood KDC-MP528 CD Player Logo
245 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
