Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool model gd5rhanq00
My double side ref is not cooling good on the refrigerator side the ice side works good but the ref is causing my food to thaw or go bad both knobs are in default 4. here is my e-mail hopefully you can help sove my problem thanks Master T. ememario@yahoo.com
I was having the same problem with my frig. Try unplugging your frig, take the back panel off in the FREEZER and thaw the coils. The problem might be the you need refrigerant.
Posted on Mar 26, 2009
I need a fan for my double door refrigerator freezer whirlpool ffw400me
not a good model # for ref. more info needed data tag is in fresh food side top right side
Oct 23, 2016 | Whirlpool Refrigerators
The ref. is running with all the bulbs are on.My problem is that it the freezer stopped making ice and and the ref is not longer cold . all the food were spoiled.Water dispenser still running and its just...
I would like to guess your compressor is not running and this is the cause. If your comporessor has a relay on it, that's where I would look. Remove the back lower cover, put your hand on the compressor, if working correctly it should be about 120 degrees. Do you hear a clicking noise? If so it's the relay to the compressor clicking out on the overload.
Good luck
Aug 27, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
My whirlpool side by side is getting warmer. Freezer was up to 45 F yesterday, today 55 F, Refrigerator getting warmer too. Fan on freezer and refrigerator vents blowing, but isn't that cool. What's...
check and clean the condenser coil under the ref , remove the back to the ref if the compressor is real hot you need to put a fan behind the ref for a couple of hours until the compressor cools down then plug it back in.
Nov 21, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water accumulating in bottom of kenmore
It's likely the condensate drain is plugged. You can access it from the back of the refrigerator. You can disconnect from the inside of the fridge and blow it out to ensure it is not blocked, then reconnect.
Aug 15, 2009 | Refrigerators
Refrigerator not cooling
sounds like the fan in the freezer isn't working.
Mar 21, 2009 | Whirlpool ED5VHGXM Side by Side...
Whirlpool double door fridge side is not cooling,
sounds like a defrost problem. check to see if there is any frost buildup in the back wall of the freezer. if so, it is not defrosting like it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
Jun 28, 2008 | Whirlpool GS6NBEXR Side by Side...
Whirlpool sideby side
this is normal this is the mulliion heater , it is a loop of tubing from the high side of the condenser it is used to keep moisture from forming between the doors of the ref, cool it will not be
but is cool how the manufacture thought about doing this
May 16, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
94 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
