Question about Ricoh Aficio 180 Laser Printer
Fusing Unit Mine is telling me to reset the fusing unit...what is that???
  • kitchensandb Jan 08, 2009
    We looked there...there is the cord and nothing else. And yes...I had a non-blond check too.
    Do you mean on the wall or machine?
    Novelist:
  • 140 Answers
If you will look where the power cord is plugged in, somewhere immediately close to there you will see a reset button or buttons similar to those you may find on electrical receptacles in the house. It is like a circuit breaker. Press it in to reset. It should be clearly marked as well.
Posted on Jan 08, 2009
  • roberto serbin Jan 09, 2009
    It is on the back of the machine to where the power cord goes into the machine. You should see some sort of red push button type to push in and reset the machine out of that error. It is like a circuit breaker for the machine in case it gets overloaded. Your model probably has more than one because it is a good brand. Let me know how it goes. God bless.
Recalibrate a printer
Can you tell us the model name of the printer? The calibration is different from machine to machine.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 15, 2014 | Konica Minolta Office Equipment & Supplies
Fusing unit setting error
To prevent damage to the machine, the main machine cannot be operated until the fusing related
SC has been reset by a service representative.
? Enter "SP Mode 3" in the SOM.
Click "OK" in "Reset Fusing Unit SC" with "SP Mode 3", and then turn the main power switch off
and on.
Dec 11, 2011 | Ricoh Aficio 2228C Copier
How do I replace the brother fuser?
    The fusing unit and the parts around it are hot! Be sure to wait until the fusing unit has cooled down sufficiently before replacing the fusing unit. If you touch the hot parts, you might get injured.
  1. Turn off the machine's power switch. To avoid injury, wait until the machine has cooled down sufficiently before you replace the fusing unit.
  2. Open the back cover (1) and the scanner unit (2) of the machine.
  4. To release the fusing unit from the machine, release the lock levers that are on both sides of the fusing unit.
  6. Hold the handles on both sides as you take the fusing unit out of the machine.
  8. Put the new fusing unit into the machine. Be sure to insert the fusing unit completely into the machine.
  10. Secure the fusing unit with the two lock levers that are on both sides of thefusing unit.
  12. Move the fusing unit pressure release levers to the Set position.
  14. Close the scanner unit and the back cover.
  15. Turn the machine's power switch back on.
  16. Press the Menu/Set key.
  17. Press the up or down navigation key to select Machine Info. and press Menu/Set.
  18. Press the up or down navigation key to select Reset Menu and press Menu/Set.
  19. Press the up or down navigation key to select Fusing Unit and press Menu/Set. The confirmation message appears on the LCD.
  20. Press 1 to reset the life counter.
  21. Caution
      Please be careful when replacing the fusing unit. Do not put pressure on the fusing unit; it should go in easily. If it does not, make sure the fusing unit connector is free to move.
      Do not apply force! It could damage both the fusing unit and the machine.
Feb 02, 2011 | Brother IntelliFAX 4750 Plain Paper Laser...
Functional error SC548-00
SC548: Fusing unit installation error
- Definition -
The machine cannot detect the fusing unit when the front cover and right cover are closed.
- Possible causes -
• Fusing unit is not installed
• Poor fusing unit connection
Reinstall the fusing unit, ensure proper installation. You will need to enter the service mode in order to reset this error. Enter the service mode, then turn the machine off and then on via the MAIN power switch.
Dec 14, 2009 | Ricoh Aficio 450 Copier
A Di-2010 has a co500 error after someone tried to run a transparency thru the copier.
This is a fusing unit malfuction. The fusing unit is the part that gets hot just before the paper exits the machine. The transparency issue makes perfect sense as if it was the incorrect material then it most likely melted in the fusing unit. A good tech can remove the fusing unit and the transparency material WITHOUT charging you for a new fusing unit. Then there is a service mode reset procedure for the code.
Good Luck.
Oct 23, 2009 | Minolta Di3010 Copier
Problem for Sharp AR-5320
The Fault fuzer. Possible faults of the block of the fastening the scene or in contact of the join or in signal of the controller of the direct current.
Address please in service Sharp
H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error
Oct 08, 2009 | Sharp AR-5320 Black and White Copier
Can i reset my Konica Minolta C250 transfer unit and fusing unit?? Is there a chip reset that I can buy for the transfer unit and fusing unit? I just purchsed the resets for the image units and they worked...
On your transfer unit there is a .80 amp fuse you can replace. this will reset your belt. make sure you use .80 amp or it will not work. on your fuser there is an inline 1/16 amp fuse next to the plug you can replace for that.
Sep 30, 2009 | Konica Minolta bizhub C250 All-In-One...
Problem replacing fusing unit for a Ricoh Aficio SP C411DN
Look in your owners manual for the set of reset keys you ppuch to reset the error in the machine. Can't tell you much other than it is a sequence like holding POWER button and 1 or 2 other keys for so many seconds. Have you tried to ask the question at their website?
http://www.ricohpr.com/
Here is the location for the manual
http://www.ricohpr.com/about/awards/pdf/2006/Ricoh%20Aficio%20SP%20C411DN%20LTR%20%5B34246%5D%20Reprint.pdf
Jul 15, 2009 | Office Equipment & Supplies
Error Message C3451
It is a fuser error.
Try resetting. To reset a Rank A error follow these steps:
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If the error recurrs then do the following:
1 Check the Fusing Unit for correct installation (whether it is secured in position).
2 Check the Fusing Unit, PWB-M and PU1 for proper connection and correct or change as necessary.
3 Change Fusing Unit
4 Change PWB-M
5 Change PU1
Oct 02, 2007 | Konica Minolta bizhub C250 All-In-One...
Ricoh Aficio 180 Laser Printer Logo
149 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
