Question about Gigabyte 845pe (GA-8PE800PRO-R) Motherboard
Usb problem, need big help
Hy, i have a 8PE667 with intel 845PE chipset. i have had it for 1 year now, and did not have any problem, until i plugged in my camera to download some photos, the system froze. i've tried using a memory stick and a webcam and my system still freezes. what shall i do, because the usb works properly with mouse or anything else. Thank you in advance for your help
  • Marius Blue Jun 02, 2007
    except for a dvd-rom and 2 hard drives, i don't have anything plugged in. i don't think the power is the problem.
  • Marius Blue Jun 03, 2007
    It seems that low power supply was indeed my problem. But it started at the company that assembled my computer, and they did a 'reset' on the usb. all i had to do is unplug the usb and plug them back in. i also had my cpu overclocked, and when i connected a device to the usb it didn't freeze anymore, an error on low power supply appeared.
    Thanks for you're suggestion. Appreciate it.
    Genius:
  • 2,985 Answers
How devices are there actually running when you plug in the camera./webcam/memory stick? The point is the more you have plugged in that is relying on the computer for power -you will eventually reach a point when the PSU can no longer deliver. If you have stuff plugged in not in actual use - unplug it. Also a powered hub will take some of the load off the computer power supply
Posted on Jun 01, 2007
  • john ash
    john ash Jun 02, 2007
    The 2 hard drives if powered by the board are certainly a factor because they are running
    Not a factor if the are self powered[from a 'outside' power supply]
    I still reckon that over demand on the computers own power is a factor.
    It could also be an indicator of a failing power supply- if these devices are drawing power from it.
    Just try it
    Unplug all except the mouse
    Then report back.
I have Intel E210882 motherboard.Which is the chipset?
http://www.amazon.com/Intel-Desktop-Board-D845PEBT2-E210882/dp/B009B5L0OA/ref=sr_1_3?ie=UTF8&qid=1353781789&sr=8-3&keywords=intel+e210882
http://www.intel.com/support/motherboards/desktop/d845pebt2/sb/cs-012740.htm
Click on Product Specification (PDF)
Product Guide (PDF)
http://downloadmirror.intel.com/15337/eng/D845PEBT2_ProductGuide_English01.pdf
The motherboard chipset is an Intel 845PE.
Intel part number - Intel 82845PE - on Northbridge chip;
Intel part number - Intel 82801DB on the Southbridge chip,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
The Northbridge chip is under the tall aluminum finned Heatsink, that sits between the processor socket, and the bottom of the motherboard.
The Southbridge chip, Intel 82801DB, sits down towards the bottom of the motherboard.
For additional questions please deposit $30,000 in unmarked bills......................OH, I'M JUST KIDDING!
Post in a Comment.
Regards,
joecoolvette
Nov 24, 2012 | Intel Motherboard
Mm, my PC didn't turn on and I open de case and I coul see that it had a lot of dust and I cleaned and then It turn on normally. But when I turn on the Pc doesn't detect the netword card, so I can't...
If you have an OEM network card that you installed yourself, then we'll need it's make and model.
If you're referring to the onboard LAN functionality built into that motherboard, it's a Realtek 8201BL PHY
If you have another computer that you can download the drivers on, and then bring them over to this one by usb, you can download the drivers for your motherboard's built in network port from the website below:
http://www.centuso.com/realtek-8201bl-phy
Mar 04, 2011 | Gigabyte 845pe (GA-8PE800PRO-R)...
I need a vga driver of a gigabyte mother board,
Gigabyte GA-8I845PE-RZ driver
http://www.gigabyte.com/products/product-page.aspx?pid=1768&dl=1#driver
If this answer helpful please vote me.
Good luck.
Thanks for using FixYa
Jan 17, 2011 | Intel Gigabyte GA-8I845PE-RZ 845PE chipset...
Can I put a 3.0 chip on the 845PE Max motherboard?
If you are speaking of usb 3.0 most likely not atleast until they release and add in usb 3.0 card that is pci not pci express
Sep 24, 2010 | MSI 845PE Max (MS-6580-040) Motherboard
Drivers Needed !!
Go to intel and download and install this chipset deriver 845PE
It should fix your problem.
May 16, 2009 | Pine Technology MACH4 845PE (845PE-ANT)...
Who is the mother board manufature for sy -p41 845pe? what type of cpu does sy -p41 845pe suport and speed range? the type of module, max support capacity and speed ranges? the type of chipsets? the type...
Processors
  • Supports all Socket 478 CPUs (400FSB & 533FSB)
Chipset
  • North bridge: Intel I845PE MCH
  • South bridge: Intel ICH4
System Memory
  • 3 x 184-pin DDR SDRAM
  • DDR200 / DDR266 / DDR333 support @ 2.5v
  • 3GB maximum system RAM
Slots
  • AGP slot, 4x AGP compliant (1.5v support only)
  • 6 x 32-bit PCI 33MHz slots
On-board peripherals - I/O
  • 1 floppy port supports 2 FDD
  • 3 Audio Jacks for the CMI9738 sound chipset
  • CMI9738 6-channel sound
  • Davicom 10/100 LAN (10/100 Mbit/s)
  • 2 USB2.0 ports and a further 4 available via headers
  • PS/2 ports
On-board IDE
  • An IDE controller on the ICH4 chipset provides IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA/100/66/ operation modes
  • Highpoint HPT371 RAID single-channel ATA133 RAID controller
  • Ultra DMA/ATA133, 100, 66, 33 operation modes
  • Supports up to 2 hard drives
  • Serial ATA support via the Marvell 88I8030 single-ATA bridge
  • Supports 1 S-ATA drive
BIOS & Voltages
  • FSB speeds of 100Mhz - 255Mhz (quad-pumped)
  • 1.1 - 1.85v Vcore adjustable in 0.025v increments
  • 2.5v - 2.8v Vmem adjustable in 0.1v increments
  • 1.5v - 1.8v VAGP adjustment
  • Fix AGP/PCI speeds and variable settings
Jan 22, 2009 | Soyo SY-P4I 845PE Motherboard
Problem with usb port
your usb slots are died,by a new usb pci card and install int the computer
Feb 08, 2008 | Intel Gigabyte GA-8I845PE-RZ 845PE chipset...
Gigabyte 845pe (GA-8PE800PRO-R) Motherboard Logo
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
