Question about Milwaukee Tool Milwaukee 4206 - 1 Electromagnetic Drill Press with 3/4'' Motor
Mag drill will not hold strong to surface
When using the Mag Drill, the drill will unattach from the beam with very little pressure on the handle. What can be done to make sure that this
will not happen. Is the electro magnet failing?
  • wadams509 Jan 11, 2009
    thanks, very helpful, it is what i thought the problem might be.
  • 58 Answers
Hi first try the magnet on a clean flat piece of m/s sheet/plate 2 inches bigger than the magnetic base ,it should be very hard to remove make shure the magnetic base is clean and the beam you are drilling is paint and rust free if possible clean up the beam with a sanding disc try it make shure the cutter is sharp and use coolant a dull /blunt tool will need more force a good tool almost cuts with no effort on the handle if you are drilling upside down or on the side of the beam NOmagi drill will do this without extra support silk090
Posted on Jan 08, 2009
The drill switch will not stay on unless it is held in on my evolution me 3500
Check the wiring at the back of the switch other wise I suspect you will need a new switch.
Mar 20, 2013 | Now Evolution Evolution Mustang Mag Drill...
Remove the chuck dc970
I'm assuming you have a DCD970 as DeWalt doesn't have a DC970 and the DW970 is an impact driver. The chuck on your drill is a new design that doesn't have a lock screw inside the chuck, they are put on very tight with lock-tite to hold them on. They are made to be taken off with a special chuck holder and vice jig that only service centers have. The allen wrench method used on older chucks won't work as the chuck will just loosen when you hit the allen wrench. I have on occasion removed one by doing the following: Turn the chuck fully open then secure it in a vice with the drill straight up. Holding the drill body and using the handle for leverage, turn the drill counterclockwise, as you are looking down on it, with steady, strong pressure. If the chuck breaks free it will spin off easily. If you are at all afraid you may break the handle you may have to take or send it to a service center to have it removed.
Mar 07, 2012 | Dewalt Drills
I have need operation, maintenance and parts manual for 4209-1 magnetic drill press
go to"milwaukeetool.com and type in your model number, you will also need the serial number to locate the information you requested. You might need to separate the tools and use the base and motor separately but it is there.
Jul 21, 2011 | Milwaukee Tool 4209 1 Drill 1 1/4 Mag...
MILWAUKEE 4253-1. HOW TO REMOVE THE SPINDLE #47 ON THE PARTS LIST. AFTER THE CHUCK AND GEAR CASE IS REMOVED FROM THE MOTOR.
The spindle is pressed into the bearing in the nose of the gear case. You usually need a hydraulic press to get them out. If the spindle gear, woodruff key and spacer come out easily (it may need a little prying pressure) you may be able to tap the spindle out with a dead blow/rubber hammer or with a piece of wood on the end of the spindle. If you hit the spindle directly with a metal hammer you can mushroom the end and it won't fit in the needle bearing in the service diaphram.
Mar 22, 2011 | Milwaukee Tool 4253 1 Drill 1/2 Mag Motor...
4270-21 Compact Magnetic Drill Press: mag base will not hold at all...
If I'm not mistaken, these drills use an electromagnet. Start by measuring the current when the magnet is switched on, but not the drill. If you don't have a current meter, just plug the drill plus an incandescent light into a long lightweight extension cord. You should see the light dim a little when you switch on the magnet. If the light doesn't dim, you just aren't getting power to the electromagnet, and it's probably a broken wire or a bad switch. If the tool has it's own fuse, I would think it would be for the drill only, not the electromagnet.
May 06, 2010 | Milwaukee 4270-21 Compact Magnetic Drill...
Cordless drill question
1/2"
A 24 position clutch controls torque output. 2 speed range gear box for high torque applications. Auxiliary handle with metal depth stop rod. Has an overmold grip handle for added comfort. A Mag Tray holds screws, small bits and hardware, etc. on foot of drill for easy access. 1/2 Ft.' heavy duty keyless chuck for quick and easy bit changes. Removable 2 position level for convenience and accuracy
Apr 19, 2010 | Ryobi 18v Variable Speed Impact Driver...
Milwaukee mag drill #4202 drill starts then dies right away,or wont start. has good brushes thank you
sounds like a fault in the winding. Sorry, service centre required.
Sep 20, 2009 | Drills
Milwaukee Tool Milwaukee 4206 - 1 Electromagnetic Drill Press with 3/4'' Motor Logo
355 people viewed this question
Top Milwaukee Tool Drills Experts
Mike
andrew-loeb
Level 1 Expert
Are you a Milwaukee Tool Drill Expert? Answer questions, earn points and help others
