Question about Xantrex Technology Heart Freedom 20 12 Inverter
Heart Freedom invertor 25/12 - cannot get invertor to function
Unit performed when connected to shore power, but when disconnected, get no function when trying to invert from batteries. From manual, understand that all that is required is to switch on switch. Have tried main a/c switch in both shore power and ship's power positions, and off, but nothing happens.
Is there anything I am doing wrong, or can you advise what I should check out
Briden Harding - Scotland
You are correct, if the unit is wired correctly, all you have to do is turn the inverter on.  The unit should make a bit of noise when the inverter is turned on.
Posted on Feb 08, 2009
    Novelist:
  • 113 Answers
Batteries could be too low, or unit could think batteries are too low because it is not set up for your battery configuration. (voltage, amperage, deep cycle, wet, gel, agm etc.)
I am not sure how you set up that model but the manual should explain it. If you don't have one you can get it online from xantrex.
Posted on Jan 08, 2009
Heart freedom 20. As soon as shore power is applied the inverter makes a growl sound, like a stuttering switch.
STOP!!! Immediately have the shore power breakers checked by assuring both output legs have EQUAL output. If not they can either burn out the inverter solid states components or the main coach A/C, Generator transfer switch. You can usually check this with a multimeter but the shore power park managers usually have maintenance personnel to check and replace bad pedestal breakers. Does this help?
May 04, 2010 | Xantrex Technology Heart Freedom 20 12...
Freedom 20 Inverter/Charger Overload will not reset.
When I switch my Freedom inverter on it shows E02 fault Low battery voltage. I have had the batteries tested and they are okay.
When I plug into the mains to charge batteries the Chrgeheart interphase shows charging light but nothing happens No current.
If anyone could advise I would greatly appreciate it. Thanks
Ian
Dec 16, 2009 | Xantrex Technology Heart Freedom 20 12...
Freedom 20 stopped working after ac breaker tripped
How do you get the PCB out all the 4 screws are out and clips are pushed off the pcb contacts on the sides. Unscrewed the antenna, but not the soldered in bulk antenna mount. I is still locked in somehow? how do I get the board out to look at the keypad buttons so I can see if threre is a bad contact?
Sep 10, 2009 | Xantrex Technology Heart Freedom 20 12...
I have an old Heart Freedom 20 charger/ inverter. It was in charge mode when lightening struck nearby and now doesn't do anything. Fuses???
Unlikely. Most likely it is dead. These are typically not very robust units and are riddled with issues without the help of lightning. If you can comfirm that there is voltage making it to the main input terminals and it is not doing anything, then it is time for a replacement or a rebuild. If you are on the East Coast, there is a great place where I send all of my Freedom units for repair. It is calle Tekris Power Electronics and they are in NJ. Good Luck
Aug 21, 2009 | Xantrex Technology RS3000 Sine Wave...
Freedom 20 stops passing good AC input after about 15 sec.
This unit does have an idle mode where it will not output without a load. What I am unsure of is if this exists only for invert mode or for both invert and pass through. Try reprogramming the remote to eliminate the idle feature and then see what happens.
Jul 30, 2009 | Xantrex Technology Heart Freedom 20 12...
I have a Heart Interface Freedom 20 Inverter/Battery Charger installed on a powerboat. The fan (cooling fan?) is making noise - it seems to be rubbling inside the unit. Is there a way to repair? Replace...
The fan can be replaced. It is very similar to some of the PC cooling fans. I've got the same problem (again) and will be replacing it soon. I will give you the fan specs once I remove my fan ( I think it is 4" 120VAC - will let you know when I repair mine).
Jun 14, 2009 | Xantrex Technology Heart Freedom 20 12...
Shore power won't connect.
The ground and neutral are bonded until a source power is sensed by the machine, then they separate.(pg 24 in your manual). The problem is that the GFI receptacle is faster then the xantrex. One solution is to run the 2 ground wires thru a HEAVY DUTY momentary push button that DISCONNECTS, before it ties into your ground bar on your boat. Hold the button down as you plug in to the dock, count to ten and let it go. The internal bonding will have had plenty of time to separate. If you find a better way.......   let me know too. Steve
Apr 09, 2009 | Xantrex Technology Heart Freedom 20 12...
Xantrex Technology Heart Freedom 20 12 Inverter Logo
487 people viewed this question
Top Xantrex Technology Boating Experts
Craig Butler
Craig Butler
Steve
Steve
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
