Question about ASK Proxima C160 Multimedia Projector
Proxima C160 Color Convergence Issue...
I'm currently having problems with the blue and red being out of alignment on the projector. I didn't find any settings in the software to fix this. Any ideas?
There are no adjustments for convergence in the service menu. The code is: Effect, Blank, Video, Computer, Volume Down, Volume Up.
Posted on Jan 05, 2010
The solution to this is found in the service menu of the projector. Go to the service code page and enter in the code to get the service menu and adjust the com settings which are a digital convergance adjustment that fix ghosting.
Posted on Feb 27, 2008
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 28, 2011 | RCA R52WH73 Projection Television
Replaced bulb for a proxima c160 bulb won't strike led power button flashes red what can I do
You may have purchased an aftermarket generic lamp. The chances that the lamp is defect is about 20% with the counterfeit products....Read here for a better explanation:
http://www.fixyourdlp.com/guides/ask-proxima/sp-lamp-017/ask-proxima-sp-lamp-017-lamp-replacement-guide.php
I also suggest buying the original lamp as recommended by the above link. You may find yourself troubleshooting further for no reason simply by buying an aftermarket replacement.
Apr 26, 2010 | ASK Proxima C160 Multimedia Projector
How to change proxima c160 lamp
On manual below on page 38 tells you how to replace the lamp.
proxima-c160-manual.pdf">http://www.aboutprojectors.com/pdf/ask-proxima-c160-manual.pdf
Good luck and please rate 4 thumbs for the free answer
Mar 23, 2010 | Office Equipment & Supplies
How to connect my C160 ask proxima to my laptop hp?
C160 has M1-DA connector. You need an adapter.
Try this or Google it.
Dec 06, 2009 | ASK Proxima C160 Multimedia Projector
I have a proxima dp6860 color shadow
the lcd panel may be out of alignment. there really isn't a way adjust it easily. it'll need to go in for repair to an infocus service center. try av solutions in ny. they're really good.
i think it's www.avsolutionsny.com
Nov 20, 2009 | ASK Proxima DP6860 Plus Multimedia...
Lamp won't strike
the ballast might be bad as well.
Aug 07, 2009 | ASK Proxima C160 Multimedia Projector
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
Blue instead of red colour afer replacing lamp in sharp xv-z2000
You didn't put your 3-D glasses on backwards, did you? :)
Seriously, if you are using the component inputs, be sure the three cables didn't get mixed up when you put the projector back. Otherwise, you might have an issue with the color wheel inside the projector, but I doubt it.
Dec 31, 2008 | Sharp XV-Z2000 Multimedia Projector
Center adjust on Red gun is not aligning with B&G vert.
frist set blue and green than set red itwill shoew yu single chakall will be focous in single line than than gun will be allign horizontal if it will correct if itisnot comming than cathode problem.
Oct 06, 2007 | Sony VPH D50HTU Multimedia Projector
ASK Proxima C160 Multimedia Projector Logo
621 people viewed this question
Top ASK Proxima Office Equipment & Supplies Experts
Steven Wander
Steven Wander
Dayton Computer
Dayton Computer
Are you an ASK Proxima Office Equipment and Supply Expert? Answer questions, earn points and help others
