Question about Whirlpool LHW0050PQ Front Load Washer
WASHER MAKES A BANGING NOISE WHEN SPINNING
Washer makes banging noise
  • Anonymous Feb 04, 2009
    hi, i have the same problem with my washer, it makes big bang, or a humming sound, it's really weird, and it leaks very often.
    i have tried to reduce my load of clothing, also tried to wash heavy things(like towel) alone with light things such as shirts, to balance out the weight, but nothing worked...can anyone help?
Try redistributing the wet clothes for better 'balance'.
Posted on Feb 02, 2009
MAKES A LOUD BANGING NOISE AT THE END OF SPIN CYCLES. WHEN IT IS SPINNING SLOWER, NO PROBLEM. IT IS NOT A PROBLEM OF BEING LEVEL.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 17, 2011 | Whirlpool Duet 3.8 cu. ft. Front Load...
On spin cycle machine vibrates and makes a load banging sound especially on the final spin.
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 14, 2010 | Washing Machines
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Makes a loud banging sound when spinning clothes
check springs and shock absorber.try to put more laundry.
Feb 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Very loud banging noise when spinning
sounds like a balance problem may be when the drum was replaced they didn't fit the new drum in the correct spot the other thing that would cause load banging and excessive vibrations in the machine is if the shockers are worn out,
believe it our not even washing machines have shockers to dampen the movement of the drum spinning
Dec 19, 2008 | Indesit W 123 Front Load Washer
Makes a hard banging noise when the washer is draining and spinning
Check the springs, and make sure the water ring still has water in it.
Jun 23, 2008 | Roper RAX4232KQ Top Load Washer
Ge profile WNSB8060BWW VERYYYYYY LOUD
Rear ball bearing broken change half drum or buy new washer ????????????
the super tech
Sep 04, 2017 | GE WNSB8060BWW Top Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
214 people viewed this question
Dan Webster
Dan Webster
Sal De
