Question about Epson Stylus Photo RX620 All-In-One InkJet Printer
The red exclamation mark and the green setup light remain on.
When i turn the power on the print head and the scanner index and all the green lights on the left hand panel come on then go off leaving just the setup light on with the red exclamation light.The lcd display doesn't come on and the printer doesn't react when i press any of the Right Hand panel.
The model is EPSON STYLUS PHOTO RX600.
  • Epson Master
  • 10,766 Answers
I experienced the same problem several years ago and tried the suggestion provided below. It worked and it is still working today.
Here are instructions posted by John Phillips on "FixYourOwnComputer.com:"
Steps I took - and it worked beautifully - display problem solved !!
1. Ease off the plastic facia that covers the control buttons - (no screws - it just clips on)
2. Remove the cross head screw that is seen to the bottom left of the display unit.
3. Flip display unit open - remove the cross head screw that holds the dark plastic support clip that is behind the unit and top right ish!!
4. Remove the display unit - unscrew the 4 small cross head screws that hold the display assembly together - NOTE THAT THE CONNECTING RIBBON RUNS THROUGH THE HOLE - I didn't make a note at first, and it took me ages to work out where it went when trying to re-assemble it !!
5. Mark the connecting ribbon so that you know which way up it should be, then carefully pull it away from the black connecting block - Re-assemble merely by pushing it carefully back into place.
6. On the circuit board you will see a large (ish) black Integrated Circuit - using a magnifying glass you will see a tiny soldered fuse marked F1 just to one end of this Integrated Circuit.
7. Using a single strand of clean copper wire ( a single strand taken from a multi strand piece of speaker wire is ideal) carefully solder it across the two terminals
8. Having a soldering tip small enough is vital if you are to attempt this - an ordinary tip is TOO BIG. I used a piece of copper earth wire (obtained from ordinary "Twin and Earth" electricians household mains wiring cable) I then wound it around my soldering tip and filled it down to a fine point.
9. Re-assemble - switch on - and if you have been careful and succeeded in this feat of micro soldering - you should have a realistic chance of having a fully functioning display once again.
Posted on Jun 29, 2015
neoranjit
  • 310 Answers
SOURCE: The printer will not scan
have to installed the software that came along with it ? Can you make sure that
1. the lights in the printer glow as they used to..
2. The software that came with it is uninstalled and reinstalled again.
This usually does the trick
- Ranjit
ranjit@supportminds.com
Posted on Nov 02, 2007
SOURCE: my troublesome printer
Did you refill this ink cartridge? If the ink is low or out your printer will not print until the cartridge is reset. If you refill it yourself see http://www.ssclg.com/epsone.shtml. This is free software that will allow you to reset the ink levels. Then the red light will go out and poof you can print.
Posted on Apr 11, 2008
SOURCE: epson c43sx does not print
change the cartridge thats simple red light indicating you must change your catridge
Posted on May 16, 2008
Dipu007
  • 2110 Answers
SOURCE: epson photo rx600
If the LED display screen on your printer is blank please try disconnecting
the USB cable from the computer and then disconnect the power to your
printer. Reconnect the power to a different power outlet, and turn your
printer back on. If the same issue occurs, your printer will require
service.
Posted on Dec 04, 2008
gwbm
  • 353 Answers
SOURCE: Epson Stylus photo 810/ink jet printer
Hi Alan
I expect by now you've solved this problem - but just in case .....
The waste ink "protection" counter has exceeded its limit and needs resetting. You can do this easily by using the SSC utility - download from:
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (810), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
Posted on Mar 15, 2009
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Red exclamation mark light comes on in dashboard
take it to your local autozone, advance, etc.. autoparts store. They can perform a free fault scan. They'll come out to your car, plug in their scanner, read the faults, print out any faults and reset your light(s) - All for FREE
Jan 03, 2011 | 1994 Mitsubishi Montero
Scanner stopped in middle of scan . green light in front went out. later red light came on. message on screen said that the carriage was locked. I tried turning scanner on and off and green light comes on...
test the power supply to the scanner also test the leads that attach from the power supply to the scanner if its connected to a computer you might have to uninstall it then reinstall it this applies the driver aswell you can do this control panel admistrive tools,computer management,device manager scroll down you should see a yellow question mark? right click to reinstall drivers or ports(com&lpt)ECP printer port right click update driver
hope this helps
Oct 27, 2010 | Computers & Internet
My r290 add red color to my photos
*** I'll be more than happy to help you on that. you might be talking about R280, because theres no R290 for epson. there is a great possibility thatsome of the nozzles of your printer are clogged by dried inks, thats why when it prints, the inks are not equally distributed or is not balanced.to check that, print a nozzle check, and if you see gaps or breaks, between the lines, do head cleaning. this is how you can do it, its very easy for you. Using the Buttons on the Printer 1. Make sure the printer is turned on but not printing, that the CD/DVD tray is not inserted in the printer, and the red maint.5.1.8.jpg ink light is not on. (If the red maint.5.1.9.jpg ink light is on, you need to replace a cartridge.) 2. Turn the printer off and make sure the front tray is in the paper (lower) position. 3. Make sure letter-size plain paper is loaded in the printer. 4. Hold down the maint.5.1.10.jpg paper button, then press the maint.5.1.11.jpg power button. Hold down both buttons until the maint.5.1.12.jpg power light begins to flash, then release the maint.5.1.13.jpg power button. maint.5.1.14.jpg 5. When the nozzle check starts to print release the maint.5.1.15.jpg paper button. Check the nozzle check pattern that prints to see if there are gaps in the lines. maint.5.1.16.jpg 6. If there are no gaps or lines, the print head does not need to be cleaned. If there are gaps or lines, or the test patterns are faint, follow the steps in do the Head Cleaning to clean the nozzles. Using the Buttons on the Printer 1. Make sure the printer is turned on but not printing, and the red maint.5.1.23.jpg ink light is off. (If the red maint.5.1.24.jpg ink light is flashing or on, you need to replace a cartridge.) 2. Hold down the maint.5.1.25.jpg ink button on the printer for approximately 3 seconds. The printer runs a head cleaning cycle and the green maint.5.1.26.jpg power light flashes. Cleaning takes several seconds. Caution:
Never turn off the printer while head cleaning is in progress. You may damage it.
Do not insert the CD/DVD tray until cleaning has finished. 3. When the green maint.5.1.27.jpg power light stops flashing, make sure paper is loaded in the printer, then print a nozzle check to determine whether you need to clean the print head again. Print Head Nozzles If you don’t see any improvement after cleaning three times, turn the printer off and wait overnight. This allows any dried ink to soften. Then, try cleaning the print head again.
Feb 16, 2010 | Epson Stylus R290 InkJet Printer
Red exclamation mark keeps flashing. No message on screen, just a bar going round and round the periphery of the screen. Printer will not work. The round green power button remains on, without flashing....
i've looked it up and seems that it's a common problem and you need to flicker the CD door up and down a bit till your printer recognizes it's fully shut!!!
stupid HP can't get their stuff to work properly
hope i did a better job
:D
Oct 23, 2009 | HP Photosmart D5160 InkJet Printer
New Saeco Odeo Go has solid red exclamation mark, doesn't budge
You have to 'manually' prime the pump: When the red exclamation mark shows, press the water switch on the right side (the picture of the water drip), then open up the steam nozzle and let the machine pump hot water into a cup until the red light goes out.
Jun 11, 2009 | Saeco Odea Go
Printer suddenly stuck while starting up
eww this one can be lots of things!!!
make sure no paper jammed anywhere
make sure the print head is moving
make sure the ink cartridge is set down right
May 24, 2009 | Samsung CLP-300N Laser Printer
Power Light Is Red, Internet Light Is Green, Other Lights Off
Check cable connections.
Try unplugging router from power for five minutes.
If that does not work call Internet Service provider to check if there is a problem with their server.
Apr 10, 2009 | Actiontec GT704WG Wireless Router...
Epson C66 red light stays on for ink
The first time you install ink cartridges, the printer must charge its print head for about 90 seconds. Wait until charging finishes (the green power.jpg power light stops flashing) before you turn off the printer, or
it may charge improperly and use excess ink the next time you turn it on. If the printer stops moving or making noise, but the green power.jpg power light is still flashing after 5 minutes, turn off the printer. If the light is still flashing when you turn it back on, contact Epson.
Turn off the printer, then make sure the ink cartridges are inserted completely and the ink cartridge cover is closed completely. Also make sure no packing material remains in the printer. Wait a moment, then turn the printer back on to clear the error.
Nov 13, 2008 | Epson Stylus C66 Photo InkJet Printer
Epson Stylus Photo RX620 All-In-One InkJet Printer Logo
119 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
