Question about Harman Kardon CDR30 2-Disc CD Recorder
2 different "Recording" problems with my unit.........
Hello, I have 2 different problems with my CDR30. One, is the "copying one CD from another" function. The problem with this function is that if, for example, you are making a copy of a 60 minute track, the CD burner will keep burning beyond the 60 minute mark, and will keep running to the end of the disc, thus "Adding" 20 minutes of silence to the new track. So, basically, the machine keeps running beyond the end of the master disc. Problem two is related to dubbing from another source. My usual input is an analog source (Tape deck). I'll be burning a CD in deck #2 using the analog input, and the machine will stop the track by itself after 10 or 20 seconds. Sometimes the machine will run for several minutes before ending the track. But the result is always the same: the track was ended prematurely. I had a repair shop "Fix" the problems, and they could find no faults. So they "Adjusted and cleaned" the laser, and the unit worked fine for about 4 weeks, and is now repeating the same faults. Anything I can do before I scrap this unit ?? I've had the unit about 5-6 years, and prior to these problems, have had flawless performance from it, so i'd like to try to resurect it. Thanks !!
I think you need to use manual button for increment track number
Posted on Nov 22, 2009
Can copy from analog sources, but can't copy from digital source, eventhough the signal is monitored. The display says "can't copy".
Media
The unit requires Digital Audio CD-R or CD-RW media for
recording. Computer CD-R or CD-RW discs do not work with
this unit.
Serial Copy Management System
This unit is in compliance with the Serial Copy Management
System standard. This standard has been established to
restrict digital-to-digital copying to only the first generation.
The basic rules governing this system are as follows:
Rule 1
A digital recording is possible from a digital source such as a
CD, DAT or MD onto a recordable CD-R, CD-RW, MD or DAT
through a digital input connection. However, further digital
to- digital recording is prohibited for the second and later
generations.
Rule 2
When an analog source such as an analog disc or FM
broadcast is digitally recorded by using a CD-R, CD-RW, MD
or DAT, this recorded source can be digitally recorded on
another CD-R, CD-RW, MD or DAT. However, further digital
copying is prohibited.
Download the manual "cd-rw880_ef_manual.pdf" on the page linked below:
Download free pdf for Teac CD RW880 CD Player manual
Aug 22, 2013 | Teac CD-RW880 CD Recorder
JVC XL-R2010 CD Recorder - recording dao problem
Reading the manual over and over, it looks like there is a function called Autotrack and by default is ON.
In the manual, page 22, shows you how to put the Autrack OFF.
Be careful that if you use the synchronize one-button recording you will have again the Autrack automatically ON again and that means a pause or bump between tracks.
For your reference I used the manual at this location http://resources.jvc.com/Resources/00/00/98/A0013ien.pdf
Please let me know if you need further help.
Oct 28, 2007 | JVC XL-R2010 CD Recorder
My hk cdr 30 no reading any digital audio inserted disc. otherwise everything
CD do not just read any types of files, the disc must contain only files compatible with the unit. Check your manual.
Jan 20, 2013 | Harman Kardon CDR30 2-Disc CD Recorder
Harman Kardon CDR30 2-Disc CD Recorder both cd
Open the unit, inspect any obstruction, look for the belt that driving the CD tray, if it is loose replace it.
Jun 12, 2010 | Audio Players & Recorders
Copy RCA Digital Recorder to CD
Hello the way you are trying to do it is more complicated, I recommend sell your unit and upgrade to another unit that transfer audio files fast and will give you more time recording and better record quality for example this model has a software the is really easy to record in to a CD on different audio formats if you want plus you will received a Dragon® NaturallySpeaking® 9 Recorder Edition that you can change audio to text the price is really good check it if you want
http://www.tvps.com/Products/Sony-ICD-SX68DR9-Digital-Voice-Recorder---Refurb__SO-P-ICD-SX68DR9.aspx Good luck
Mar 08, 2010 | Sony ICD-B5 Digital Voice Recorder
Describe your Harman Kardon CDR30 2-Disc CD Recorder Problem It's a CDR26 and neither of the drawers will open.
With mine, it was the drive belts for the cd drawers, which were stretched and rigid. Open the case. Remove the 4 screws that hold down each cd drive. Push the drives out enough so you can pull the silver facing off the sliding try by pulling it up. Now you can lift out the cd drives, removing all the connectors as you go. Flip the white plastic slider underneath each drive and you can mechanically open the slide tray. This reveals the little motor and rubber pulley belt that operates the slide tray. If the belts are broken, perished, rigid or something, get something similar from your local electronics parts store (a couple of bucks each belt), and reassemble.
Feb 11, 2010 | Harman Kardon CDR30 2-Disc CD Recorder
Recording audio only from an HDTV concert
Have a look at the manual for your AV receiver, you may find that you can change the digital output format between DTS mode and PCM(audio) mode. It needs to be in PCM(audio) mode for your CD recorder to be able to record digitally. If that doesn't solve it I can only suggest recording in analogue mode, i.e. taking a stereo analogue signal from your receiver to the analogue inputs of your CD recorder.
Hope this helps
HifiJohn
Jan 04, 2009 | Harman Kardon CDR30 2-Disc CD Recorder
Harman Kardon CDR30 2-Disc CD Recorder Logo
104 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
