Question about HP Pavilion N5250 (F2362M) PC Notebook
Router Does the hp Pavilion n5250 have a internal antena for a router? I purchased and install a router to my main computer. Do I need anything else?
  • Weldon Dube'
    Weldon Dube' May 11, 2010
    If you are trying to go wireless to the router it has to be a wireless router.
    Hope this helps. Bud
INSTALL WGR614v19 with Hughesnet Mpdem/Router to HP Pavilion dv7
if software is installed correctly should just need to hit the discover button on botton or somewhere on router then u have like 2 minutes to connect and put you password in have you been that far yet not sure at what point you are at let meknow
Feb 26, 2013 | HP Pavilion dv7-1130us laptop
How can I get the internet working after installing Windows XP? I have the computer plugged into a router, but still no internet.
If you have installed the ethernet card driver you just need to unplug both power cords on your modem and your router. Then plug in back your modem first and wait 1 minute. After 1 min. put the power back on your router. Wait 1 minute to make sure it talks with your modem. Try accessing internet after that and if it doesn't work, you can try restarting your computer.
If nothing works after doing this. Maybe you have a bad or missing driver.
Hope it helps!
Feb 11, 2011 | HP Pavilion A6430F Desktop PC
Can the HP Pavilion 763n PC Desktop use a wireless router?
Your computer has a "built-in" 10/100BT network connection integrated on the motherboard but to go wireless you'll have to add either a PCI (internal) or USB (external) wireless network adapter to transmit/receive the signal from your wireless router. Think "walkie-talkie" here with the wireless router installed AFTER the modem (phone line outlet needed) located in a central area of your home and transmitting/receiving to the individual wireless network adapters that must be separately installed in each computer.
Oct 19, 2010 | HP Pavilion 763n PC Desktop
I use this computer for home use only. Would like information on wireless routers and if I need any other gadgets for wireless set up.
you mean you want to connect internet or local network through wireless connection? you need an wireless access point(WAP) also known as Wireless router, but be sure the wireless router you want to buy is compatible with your wireless network built in to your laptop. no other gadgets to need if your laptop have already wireless network and if you want using within a range distance only otherwise you buy wifi antena.
Oct 11, 2009 | HP Pavilion dv6000z Notebook
Cannot access wireless networt on my HP Pavilion
I need more information from you here. Do you have a wireless card? How far away is the router from your computer? If your router is protected by wep or wap, or needs mac address, you need to enter in this information on your computer so the router recognizes your hp pavillion.
Jul 10, 2009 | HP Computers & Internet
Modem Casn't Get A dile tone
If you are sure your modem drivers are installed (no YELLOW QUESTION MARKS when you access the device manager), try this;
My Computer/Right Click/Properties/Left Click/click Hardware tab/click Device Manager Tab/click Modem/go to properties/click TEST MODEM---this procedure should tell you that the modem PASSED or FAILED.
If the modem FAILED, it is defective and will need to be replaced.
Apr 11, 2009 | HP Pavilion N5250 (F2362M) PC Notebook
Wireless Router Advice
what kind do you have right now? verizon fios offers some great wireless routers that are very strong
Dec 06, 2008 | Computers & Internet
Will a computer with 10/10 LAN connect to my wireless LAN?
The 10/100 LAN is a wired connection. If it is connected to the wrt54g through an ethernet cable yes it will see anything on the wireless connection but if you want the computer to use a wireless connection then you will need to get an 802.11B or 802.11G wireless adapter. The wireless adapter does not have to be Linksys but it does generally make thing easier if you use all the same brand.
Nov 29, 2008 | HP AdvanceStack 10:10 LAN Bridge MB...
How to hook up this printer wireless to my main computer
We cannot connect the pro l7680 printer wirelessly. Connect the printer to the router via ethernet cable and connect the desktop to the router wirelessly.
May 24, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Pavilion N5250 (F2362M) PC Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
