My washer does not drin or spin - Washing Machines
  • 15,935 Answers
Replace the timer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Whirlpool cabrio wtw5600xw0 will not spin
I had the power button off so no lights were lit. I also tried it in teh done mode. None of the buttons put it into self test.
My issue with spinning is it will not complete the spin cycle and the lid lock light flashes leaving water in the tub. If I out the machine on drin and spin it will remove most of the water
I also tried the soil level temp keydance to check the console self test and it would not go into that mode either.
Honda Parts.
May 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer wont drin or spin
The problem is one of several things. Normally if the machine won't spin out
the problem is the lid switch. (They may seem ok but are often broken). Second is
that the timer point has become burnt and pulled off the timer switch itself.
If the washer agitates but doesn't spin, then replace the lid switch. Otherwise
I would first check the connector to the motor (Underneath the machine) for
obvious burn spot on the connector (the high speed pin) and if that is ok
then the timer has had a contact point fail and needs replacement. This machine is
direct drive so inspect the coupler when checking the connector. Hope this helps.
May 09, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer spinning but not drinning water
remove the kick panel below the door, make sure the unit is off, disconnect the harness to the pump and connect a multi meter to verify line voltage to it when it is supposed to be draining, such as when u push a drain/spin cycle. if power is there pump is bad, jammed, or pluged. you will need to remove it to disassemble to determine solution..
if no power there and the door is locking and lock light is on then most likely the main control board is bad, but the pumps usually are the culprit.. gots to watch what you feed these things.. $70-100+ for pumps is not something to take lightly..
13 years with my units and no pumps, couple nickels jammed in hose stopped it up but otherwise no problems..
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore Elite 45986 Front Load Washer
GE Drain Hose
Hi, Does this washer have to pump the water up into a drain? If it is possible, it would be better for the machine if you can bring the drin pipe closer to the washer. I know it is not always a possibilty. The longer the drain hose, the harder it is on the washer and sometimes the cloths don't spin out as dry as they will with a short drain hose.
Vic
Jun 20, 2009 | GE Profile WPRE6100G Top Load Washer
My top loading washer does not spin out the water
check: 1-drin hose 2-drain filer 3- no spin mode maybe you selected
Jun 08, 2009 | Washing Machines
Smoking washer
once you get the front panel off check the drain pump while your in there right now get a flashlight and look very closely at the holes in the tub for something like a nail or screwhead or something small enough to have slipped down in one of the holes of the inner tub and be jamming it now when you check the drin pump be warned there will be water still in the pump and tub so put down a bunch of towels
Mar 30, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washer will not spin nor agitate
mj, sounds like a broken coupler, look at number 13 on the picture. The fact that it won't agitate or spin but will drain rules out the lid switch. This is not a hard job. Check this out first. Catriver..post back
Apr 01, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
Top Washing Machines Experts
