Question about Goodmans W280NS Television
Goodmans 42 plasma gtv42p3
Hi i have a 1 inch black line in the centre of the screen from top to bottom it some time go away
  • Anonymous Mar 24, 2014
    Turn off mains for about 1minute line goes but comes back about 3 minutes later
  • 372 Answers
This sort of fault is normally caused by a bad connection on one of the ribbon cables on the ysus board, Ribbon connectors will need to be cleaned with isopropyl alcohol & replugged in firmly. If you undertake this work your self please be carefull not to dage the ribbon when pulling out & refitting.
Posted on Sep 04, 2007
Hello , my name mike I Have a samsumg 42 inch plasma model pn42A450p1d . Picture looks good other than left side has a 3 inch black section from top to bottom. Any help
Hi, My name is Amp:
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 20, 2016 | Samsung PN42A450 Plasma TV
Hi have a samsung 42 inch plasma, all of a sudden it has a band 20cm wide of dotted lines going across the whole screen, some channels or when playstation in use the band gets wider, does not seem to...
if the band is horizontal your tv has bad y-buffer board. Usually there are 2 buffer boards- top and bottom. if the problem is in the top half of the screen replace the top board, otherwise replace bottom board.
but better to replace both a the same time.
if the tv has a vertical lines from top to bottom it may have bad plasma panel and can be considered as not economical to repair.
Oct 03, 2012 | Samsung SPN4235 42 in. Plasma HDTV
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
Black vertical line appears on plasma tv screen
If you wish to get some details; visit the site linked here. Pull up older posts.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jun 03, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Nov 09, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Goodmans plasma 42" gtv42p3
When that happened, the part responsible is often a ribbon connector cable, that connects to the plasma screen right when the screen starts to be black.
The ribbon cable has a built in chip , when the chip is gone you get this problem.
Feb 02, 2008 | Goodmans W280NS Television
1inch line from top to bottom
The black line indicates that either the flex cable that connects the panel to the buffer board has come loose or the panel is bad. Try to reseat the connector located inline with the symptom seen on the screen, if it's loose or inserted crooked, the panel will show this problem. Good luck. Joe Weibel customelectronics.org
Feb 19, 2007 | Sony PFM-42V1N 42 in. EDTV-Ready Plasma...
Televison & Video Logo
144 people viewed this question
Top Goodmans Televison & Video Experts
Steven Wander
Steven Wander
Steve Allison
Steve Allison
Colin Stickland
Colin Stickland
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
