Question about Garmin GPSMAP 3210 GPS Receiver
Cannot set up the arrival alarm to a point
I've tried to set 0,001 miles arrival alarm and the 15 seconds arrival alarm. Then I navigated to a specific poin but upon arrival there was not a sign or a sound indicating the arrival.
Am I doing something wrong??
Thank you
Giuseppe Leveroni
    Novelist:
  • 113 Answers
If you set your arrival alarm to .001 you are trying to hit a very small circle, only 6' in diameter and the odds of actually reaching that point are incredibly low so it's not likely the alarm will go off. Try setting your arrival alarm to .100 just to see if the arrival alarm works better.
When you set alarm to 15 second arrival you should see and hear an alarm, however, the slower you are going, the smaller the arrival circle gets, which means its gets harder to hit the area that triggers the alarm. 15 seconds is the default setting and I have found that it works fine at normal cruising speeds. If you are traveling very slowly, try bumping the arrival time up in 30 second increments to see if you can get an alarm.
When the alarm does go off, it is a very faint double beep which is hard to hear over the sound of wind and engines. I don't remember exactly how the visual arrival message appears but it is also very subtle. It appears either as a change to the menu bar at the bottom of the screen, or as a message box on the screen that dissappears very quickly. When I use that model I frequently miss the arrival alerts.
Posted on Jan 08, 2009
How does an earthquake alarm work?
An earthquake alarm provides an early warning by detecting an earthquake's soundwaves before the shear wave hits your area. The alarm will detect a quake that is even many miles away! A loud alarm will then go off.
May 07, 2013 | Home
I have forgotten my alarm code for my motorhome Sigma S30 The keypads still work but I need the code to reprogramme a more rememberable number
Here are some important informationabout Sigma S30. Programming a New PIN Code:
The standard PIN code can be changed following thesequence below:
i) Type in to the keypad **
ii) Type in to the keypad the "existing PIN code" then *
iii) Type in to the keypad 92 * "new PIN code" * "new PINcode" #
Programming Remote Keys to the System:
Remote keys can be added or removed to/from the systemfollowing the sequence below:
iii) Type in to the keypad 91 * " the number of keys to beused" #
iv) Press the first remote key button until bleep sounds,release and press next key. Continue until all
keys have been taught to the system. Note the maximumnumber of keys is 4 and all keys required
to operate the system must be taught during this operation- any key not included will no longer
operate the system.
Full Programming, Diagnostics and Features
This section contains all the information that the dealersuse for programming and diagnosis of
the Sigma M30 alarm system, using the MK1 keypadprogrammer.. Programming can also be carried
out using a dealers CP1 programmer.
MK1 Keypad Programming Introduction
It is important the keypad buttons are not pressed tooquickly-
Each time a button is pressed the LED on the keypad willflash once as confirmation. The next button should
not be pressed before this confirmation.
It is important the keypad buttons are not pressed tooslowly-
When in programming mode, if a button is not pressed for aperiod of 10 seconds or more, the alarm will
automatically exit programming mode. This will be confirmedby repeated flashes from LED on the keypad.
You must wait until the LED stops flashing and then startagain.
All programming functions are entered after typing * andthen the programming PIN code. The programming
PIN code is 17856.
To enter the programming PIN code, the alarm system mustfirst be armed and then disarmed using a valid
remote key. (Or keypad using the PIN code)
* 17856 * must then be entered within 30 seconds ofdisarming the system. This is then followed by a 2
digit function code, then another * and then sometimesoptional parameters as shown in the following tables.
It is important to remember the * key is used to separatethe various parts of the code like this:
* programming PIN code * function code * parameter #. The# key is pressed at the end of all
sequences and is used like the "enter" key on a computer keyboard.
Programming Features On or Off:
Programming
PIN
Function
Code
Switch Code
(where 0=off and 1=on)
Function Default
* 17856 * 00 * 0 or * 1 then # arm/disarm bleeps * 0 (off)
* 17856 * 01 * 0 or * 1 then # door open warning bleeps *0 (off)
* 17856 * 02 * 0 or * 1 then # auto-lock * 0 (off)
* 17856 * 03 * 0 or * 1 then # auto-arm * 0 (off)
* 17856 * 04 * 0 or * 1 then # auto-arm to include doorlocking * 0 (off)
* 17856 * 05 * 0 or * 1 then # auto-rearm * 0 (off)
* 17856 * 06 * 0 or * 1 then # engineer mode * 0 (off)
* 17856 * 07 * 0 or * 1 then # hold-down remote key button= -ve
output on wire 4
* 0 (off)
* 17856 * 08 * 0 or * 1 then #
hold-down remote key button =
extends lock pulse
* 0 (off)
* 17856 * 09 * 0 or * 1 then # after disarm -ve output onwire 4 * 0 (off)
Programming Timing Settings:
Programming
PIN
Function
Code
Variable(s) Function Default
* 17856 * 10 * 1 to * 30 then # stall to ignition on timein seconds 30 sec
* 17856 * 11 * 1 to * 99 then # unset to ignition on timein seconds 30 sec
* 17856 * 12 * 1 to * 99 then # panic time in seconds 05sec
* 17856 * 13 * 1 to * 51 then # lock time in seconds (51gives two
short pulses)
01 sec
* 17856 * 14 * 1 to * 51 then # unlock time in seconds (51gives
two short pulses)
01 sec
* 17856 * 15 * 1 to * 99 then # settle time in seconds 15sec
* 17856 * 16 * 1 to * 99 then # threshold setting time inseconds 15 sec
* 17856 * 17 * 1 to * 99 then # auto arm time in seconds60 sec
* 17856 * 18 * 1 to * 99 then # auto re-arm time and also-ve
output time after disarm , on wire 4
(green/red) in seconds
60 sec
Displaying System Diagnostics:
The dashboard LED displays the value of settings as anumber of flashes.
Programming
PIN
Function Code Function
* 17856 * 30 then # time elapsed since last trigger (inminutes)
* 17856 * 31 then # as * 30 above - but each flash = 256minutes
* 17856 * 33 then # wire 7 (orange) ignition trigger count
* 17856 * 34 then # wire 1 (blue) -ve door trigger count
* 17856 * 35 then # wire 2 (blue/red) -ve boot triggercount
* 17856 * 36 then # -ve bonnet switch trigger count (blacksingle wire on siren
plug)
* 17856 * 37 then # ultrasonic's trigger count
* 17856 * 38 then # last trigger register (see tablebelow)
* 17856 * 39 then # reset all above trigger counts to 0(zero)
Setting Up Pre-set Programs:
Keying in the following sequences on the keypad sets up afixed set of features, which can be used as a
starting point for further tailoring:
* 17856 * 80 # everything off, lock and unlock pulses 1second.
* 17856 * 81 # as for * 80 above, with auto-rearm on.
* 17856 * 82 # as for * 80 above, with auto-arm on.
* 17856 * 83 # as for * 80 above, with auto-rearm andauto-arm on.
* 17856 * 80 # Default setting configures the values shownin the previous tables 1, 2 and 3. Hope this will help you. Good Luck.
Aug 22, 2011 | GPS
I just got a Memorex Digital CD Alarm Clock with no manul the modle number is MC 7101. I'm not able to set the clock or alarm. I just need the instructions.
To set the clock:
1. With the power off, press the TIME button; the time will blink.
2. Press the MINUTE button to set the present minute and the HOUR button to set the present hour.
Make sure to set the correct AM/PM setting.
3 Press the TIME button (or wait approx. 15 seconds) and the time will be set.
To set or reset alarm time:
1. With the power off, press the desired ALARM, Press and hold the desired ALARM 1 or ALARM 2 button; the alarm time will blink. The Alarm 1 or Alarm 2 time and settings will appear.
Press the MINUTE button to set the alarm.
2. Press and hold the desired ALARM 1 or ALARM 2button; the alarm time will blink.
Press the MINUTE button to set the alarm minute and the HOUR button to set the alarm hour. Make sure
to set AM/PM setting. Press the ALARM 1 or ALARM 2button again (or wait approx. 15 seconds).
3. Repeatedly press the ALARM 1 or ALARM 2 button to select alarm off, alarm on, for buzzer, radio or CD.
If you needed the manual it could be downloaded:
http://www.retrevo.com/support/Memorex-MC7101-Clock-Radios-manual/id/1081dj880/t/2/
Thanks.
gylacz
Aug 01, 2011 | Memorex MC7101 Clock Radio
I do not know how to set the alarm for my Sangean RCR-1 alarm clock.
Alarm settings can be made with clock/radio on or off.
The Alarm Clock/Radio is equipped with two independent alarm
systems each of which can activate the Human Wake System Buzzer
or turn on a preselected radio station.
Using Alarm with a Preselected Radio Station:
Select desired station using + or - Tuning Button [18] or select one
of the 1-7 presets.
Set the desired volume level using Alarm Level Adjustment [9]
Select alarm system 1 or 2 by pressing the alarm button [14] or [15].
Display will blink with selected alarm
Press alarm set button [16]
Display will blink showing selected alarm hour and alarm mode
and beep
Press alarm Mode button [20] to select alarm mode
Use + or - button [18] to set alarm time hours.
Press set button [16] to set minutes using + or - button to
set minutes.
Press alarm days selections 1-7 (Sunday-Saturday) to select
alarm days.
Display will show the days on which you wish to be awoken by the
radio alarm.
Pressing alarm button 1 or 2 will confirm settings and a beep and
display indicates radio alarm is set.
Note:
If alarm days or alarm mode are not selected display will blink
all the days for a few seconds indicating the alarm is not set
and the alarm will not be activated.
If you would like to be awoken to the station you are presently
listening to press alarm button 1 or 2 for more then 2 seconds.
This allows the station you are listening to be stored into
memory. Then follow above procedures.
Using Alarm with HWS Alarm Beep:
Display will blink with selected alarm Press alarm set button [16]
and beep
set minutes
alarm days.
buzzer humane alarm
display indicates buzzer humane alarm is set.
Note:
Cancelling Alarm Setting:
Alarm functions can be cancelled:
and beep
Press alarm Mode button [20] one or two times (depending if you
were in the alarm radio or alarm buzzer mode) till display blinks.
Press alarm 1 or 2 button again to confirm alarm cancellation.
The symbol will stay on the display for about 2 seconds
and disappear.
You may also select days you wish to be or not to be woken after
pressing the Set button while display is blinking. Press 1-7
(Sunday-Saturday) of button [19] to make a selection.
This is the figure of your device and you can find which button where is:
Thanks.
gylacz
Jun 10, 2011 | Sangean RCR-1 Clock Radio
I have the Caddx NX-6 alarm system. Problem: Alarm system will not arm when entering the 4 digit code. Symptom: I have all doors/windows/zones closed. LED displays READY. I press the code and get 3...
If the power was out for 5 hours and the control panel still shows 'low battery', it's probably time to replace the battery for the control panel. However, this shouldn't keep the alarm panel from arming up. I would first try to re-start the control panel by removing the power and battery connection for a few seconds and plugging it back in. After that, it would be a good idea to re-enroll all of your attached sensors, etc. by entering into programming mode and exiting. Press * 8 + {go code} then just press exit. The default 'go' code is 9713. After about 15 seconds, the panel will have auto-enrolled each attached device. Try arming and disarming the panel. Be careful of setting off the alarm, as your monitoring station may dispatch police, etc. in the event of alarm. This is why having a certified alarm installer do this work is a good idea, as they can put your account with the monitoring station on 'test' so alarm signals are recorded for testing purposes but are not acted upon.
Feb 11, 2011 | GE / Caddx NX 6 Fastpack with NX 1308E LED...
I dropped my battery operated alarm clock: the second hand still works but the alarm doesn't come on at the set time and the hour & minute hands don't "hold" their position - I took the clear...
The hour and minute hands can be pushed onto their respective shafts at any point in most clocks.
If you already know the time that the alarm is set, let the clock run until it sounds.
When the alarm sounds, install the hour hand and the minute hand to the exact alarm set time. If, say, the alarm is set for 6:30, push the hour hand onto it's shaft at exactly half way between 6 and 7 and then push the minute hand onto it's shaft pointing at exactly 6.
I think this should get you operating.
Gary
Jan 16, 2011 | Vacuums
HOW DO U SET ALARM
To create an alarm follow the steps below:
  1. While in standby mode, press the Menu / OK button
  2. Select Tools
  3. Select Alarm Clock (9)
  4. Highlight the desired Alarm, using the navigation keys, from the following:
    • Alarm #1
    • Alarm #2
    • Alarm #3
  5. Press the Menu / OK button
  6. Set alarm to On, using the navigation keys
  7. Set alarm time, using the keypad
  8. Select either A for AM or P for PM, using the navigation keys
  9. Press Menu / OK button to choose the Ringer Type from the following:
    • Single Tones (1)
      • Tone 1 through Tone 9
    • Ring Tones (2)
      • Ring Tone 1 through Ring Tone 15
    • Melodies (3)
      • Ball (1)
      • Caribbean Cruise (2)
      • Chorus of Clocks (3)
      • Right Here (4)
      • Guitar Man (5)
      • Latin Lady (6)
      • Minuett (7)
      • Mixed up World (8)
      • Pressure (9)
      • Simply Blue (10)
    • My Content (4), for previously downloaded music
  10. Select desired Repeat frequency, using the navigation keys, from the following:
    • Daily
    • Once
    • Mon to Fri
    • Sat & Sun
  11. Select the Snooze Interval, using the navigation keys, from the following:
    • 5 Minutes
    • 10 Minutes
    • 15 Minutes
    • 20 Minutes
  12. Press the left soft key for Done to save the alarm changes
Dec 16, 2009 | Samsung SPH-M500 Cellular Phone
Alarm problems
When creating a new alarm, the LG Shine will start with the "Set Time" function where you can set a 15 minutes alarm jump (by moving the navigation button horizontally). If not desired, you can go one step down onscreen to set the alarm time manually. If you accidentally jump back to the 15 minutes jump method in the previous function, it will automatically postpone the alarmsetting with 15 minutes increments again. Please verify you don't use that function by accident while setting up the alarm time manually. If all of this is not the case, I would suggest to return the phone because there could be a problem with the phone or software.
Feb 06, 2009 | LG Shine KE970 Cellular Phone
In the last week I have bought 2 tomtom ones. one was a 125 the other a 130. Both have given me the same problem. On arrival of my destination it is taking me anywhere from 1/8 mile to 1/2 mile away from...
First thing to check is make sure your maps are up to date. Run your device through TomTom Home and make the proper updates. 1/2 a mile away seems too far of a distance to be off by. I've taken trips on my TomTom and even other brands for that matter, and it is not unusual to be slightly off or announce the arrival a few hundred feet too early. If it is navigating you to the wrong street, you need to update your maps. The maps are very reliable on my device so use that as a starting point.
Dec 06, 2008 | Tomtom ONE 130 GPS Receiver
Magic chef beeping
You need to replace the touchpad. I'm just getting ready to replace mine for the second time in 14 years. A bit pricey but not a hard repair to make.
An appliance repairman told me that it's possible to peel the old pad off and carefully fish the connecting wire out to the point where it plugs together. This would save removing the burners and the stovetop I'm going to give it a try when mine arrives
Mar 01, 2008 | Magic Chef 31000 Gas Kitchen Range
Garmin GPSMAP 3210 GPS Receiver Logo
88 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
