Question about Monarch 9416 (Part M09416-TT04) Printer
My Monarch 9416 203 DPI prints offline
I just installed the printer. I am using the same driver as other printers I have and the same OS. However, when I try to print ID Tapes it prints the first one online and the next one offline. When I try to print barcode from the same printer it feed a few labels before printing. I basically copied the printing prefrences from the other printers that are working fine, so I am a little confused.
  • ljones201 Jan 08, 2009
    Sorry, I did not mention, but the printers are all the same.
  • 140 Answers
You did not say whether this printer is the same as your others, if it is not then you will have to get the correct software driver for this particular printer.
Posted on Jan 08, 2009
How do I change from offline to online?
When running a WIRELESS PRINTER, it happens to me all of the time, Turn the Power OFF, wait 15 seconds and while you are waiting, CLEAR OUT your Printer Que... Then Power back up and then it should work.. If this did not work, then Do it again and UNPLUG ALL the cords to the Printer and wait 30 seconds and then replug them. If it continues, then you need to remove and reinstall the Printer on your list of available printers...
Oct 21, 2014 | Epson WorkForce Pro WF-5690 Inkjet...
How do I change from offline?
Power it down, Unplug, clear out the Printer Que on your Computer and then reboot the Equipment. IF this does not fix it, you may have to delete the printer and reinstall into your computer... IF this a Wireless Printer, ensure you clean the Que before attempting to use it.,
Installing hp 1510e, plugged cable, wiil not recognize
then try to install manually, under Windows click add new printer,...
then find your printer on list and choose it.... and install it....
use drivers either to load by Windows automatically, or use path to your CD with software and drivers
Jan 13, 2014 | HP Deskjet 1510E Inkjet Multifunction...
HP LaserJet Pro 400 MFP showing offline when printing
My computer says that the printer is offline and my printer will not print idk what to do... suggestions????
Oct 10, 2012 | HP Laserjet Pro 400 Mfp M425dn...
My usb never reads a printer and it says its offline and never prints. canon Mp240 printer.
The printer connected to your system requires drivers to function. Drivers act as the translators between the printers and the operating system and issues with the drivers mean that problems would come up with the use of the printer. If the driver is unable to initialize and sustain communication between the printers and the OS, printer would show offline. All users having the printer showing offline issue are recommended to check the printer drivers installed on the system. if the printer drivers are found incorrect or outdated, then the drivers would have to be resolved to solve the issue. get more help to fix printer offline error .
Jan 20, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Drivers for monarch paxer printer
The printer doesn't have to have drivers. You can use the programmer's manual from here:
or you can use drivers from companies like Seagull Scientific, which allow you to create a label using something like Word, and then their drivers create a graphic image of the label you want, and in the language that the printer understands, which allows it to print out like you like.
Feb 01, 2010 | Monarch Paxar 9825 Printer
Raw data printed, no formatting
If you create the data file in notepad, you're doing one step too many.
If I print the word HELLO in Notepad or Word, and then send it through the ncielabel drivers, you should get a label with the word Hello.
If I create the datastream with the printer's native language, you'll get all of the raw data because the driver is trying to print exactly what is on your notepad or Word page.
If you want to send raw data to the printer, you do not need to use a driver. Send the data to the IP Address or the Com port in question.
Avery Dennison, the folks that own Monarch/Paxar, have a utility that will allow you to send your notepad file either tcp/ip or through a com port. Go to:
If you're unable to figure out how to use the Help section to help you send the file through tcp, call 1-800-543-6650, option 7 for their tech support. This number and option is valid as of June, 2010.
Oct 05, 2009 | Paxar Monarch 9855 Printer
Seagull would likely have to provide the real help here, but it sounds like your Seagull drivers are not using the correct supply setting. If the supplies have a black mark on the back of the liner, then set your driver up as black mark. If they ONLY have a small gap between the labels, then set it up as die cut. If it has a die cut and a black mark, set them up as black mark.
It is also possible that your sensor is dirty, damaged, or covered up so that the printer cannot see the supplies. If you're not using Monarch/Paxar/Avery Dennison supplies, then the index mark (die cut or black mark) may not be to the printer's specification and it just doesn't know when to start and stop on a label.
Jul 24, 2009 | Monarch 9416 (Part M09416-TT04) Printer
Problem to print label when Monarch is installed on network
101 : The format referenced by batch isn't in memory. (Try rebooting printer or closing/opening software)
005: Supply width is invalid. (Check your format data)
May 29, 2009 | Monarch 9855 Thermal Printer
Hp 5400 printer continuously shows as offline
If you are one a Mac, I may be able to help, as this happens to me. Sometimes when I send a print job, the printer shows as offline. HP recommends turning the printer off and then back on, but this did not always correct the problem. Go the the Printer Queue, click on the print job and then click on Pause Printer. Count to 10, then click on Resume. This fixes the problem for me and the printer then prints the job. I am running OS X 10.5.7. This same problem occurred using OSX 10.4.x
May 29, 2009 | HP Officejet Pro K5400n - - colour -...
Monarch 9416 (Part M09416-TT04) Printer Logo
261 people viewed this question
Top Monarch Office Equipment & Supplies Experts
David Payne
David Payne
Are you a Monarch Office Equipment and Supply Expert? Answer questions, earn points and help others
