Question about Dell 924 All-in-One InkJet Printer
Paper won't feed
I can't get the paper to feed into printer at all, then while trying to fix a long piece transparent piece came undone from inside the printer, I don't know where this piece goes, but now printer makes a load noise
  • skyhi5 Jan 08, 2009
    I don't know what a "platen" is I thought the piece might go in through the ink cartridges, I guess I need to look for a diagram of the inside of the printer, I wored on this for hours already and am so frustrated, thanks for trying to help!
    Novelist:
  • 140 Answers
If that long piece of transparent film has any visible lines in it like a ribbom cable then that is exactly what it is. I do not recall any piece like that acting as a dust cover or shield. You will need to disassemble the printer and take all the covers off. You probably only had a piece of paper stuck in there to begin with. Once the covers are off and you can see the platen the part that actually moves the paper through you will see what your problem is and be able to see where that transparent piece goes as well. God bless.
Posted on Jan 08, 2009
How to disactivate or bypass the OHP sensor on the phaser for semi opaque paper (calc paper)?
Hi Rich,
Thank you for your lengthy and informative question that does help.
My first thoughts:
Did you try and tell the driver what particular type of paper you wanted to print on such as none Xerox recommended.
A thought just occurred if you were wanting to print transparencies then the printer would have to print strong colours at 100% because once you place the image on a OHP the image would look really washed out.
All the Xerox printers I've ever worked on don't have sensors that look at the opaqueness of the media, they do however have transparency sensors because once the edge of the paper has been detected a jam could occur, so lever type sensors are used to actually feel the media.
Good luck.
May 26, 2015 | Xerox Phaser 7400DN Laser Printer
Paper mismatch officejet 6500 crumples
There could be a foreign object or torn piece of paper that's stuck further inside the printer mechanism path. Try using a flashlight and inspecting any access or clean out hatches. Sometimes something will be caught inside and cause the paper you feed in to crumple and create a jam. I watched a video on youtube giving different ideas on how to fix this problem. Fixing Paper Pick-Up Issues
May 27, 2013 | HP Officejet 6500 Wireless All-in-One...
My lexmark Z2300 will not feed the paper. The roller in the back (by the paper) does not move. I just changed the black ink. It has also said communication problem when I tried to print. NOW when you...
Disconnect the printer from your pc. Remove the sheets of paper from the feeder. Open the printer cover and remove the cartridges. While the cover is open, check the cartridge area and make sure there are no obstructions in the cartridge carrier's path. Check for any loose transparent strip (encoder strip) behind the carrier. If everything looks fine, close the cover. Unplug and replug the printer into the power source to reset it. When the printer turns on, reinsert both cartridges. Close the cover. Reconnect printer to the computer. Try to print again.
May 24, 2011 | Lexmark Z2300 InkJet Printer
Faulty paper feed
There is a sticker or piece of paper inside the printer. TO fix this, some parts needs to be removed so the foreign object obstructing the paper path can be removed from the printer.
Apr 15, 2010 | Lexmark X4550 Multifunction Wireless Color...
The following is my exact problem...can it be repaired? Hard to tell if piece is broken. "My faxes are not printing. The error message says there is a paper mismatch and tells me to remove the transparency...
Somewhere, your printer has a sensor (probably a light and a mirror and a detector), to try to distinguish between transparency media and opaque media (such as a sheet of paper).
So, that sensor either has a piece of transparency media stuck inside it, or it is otherwise misdiagnosing what media is between the light-emitter and the light-detector, and thus is claiming that there is transparency media loaded into the paper-tray.
It sounds like you need to take the printer to a qualified technician.
Dec 03, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
SAME PROBLEM LEXMARK X2350 STARTS FEED PAPER AND PRINTER HEAD MOVES AS PRINTING BUT WILL NOT FEED PAPER WHILE PRINTING? ARE THERE 2 FEEDERS IN THIS PRINTER? HOW TO FIX?
transfer roller that starts the paper and feed that feed the paper. have you had a paper jam and torn a piece of paper off inside the feed mech? i dont remember if this one feeds off the motor or a belt. either way you would have to disasemble the printer to determine where the problem lies. might be more econimical to replace the printer.
Jul 13, 2009 | Lexmark X2350 All-In-One InkJet Printer
Paper feeding crooked and jamming in my Canon IP6600D printer.
Try doing a thorough cleaning of all the rollers in paper path making sure that there also no scraps or obstructions in the path.
Aug 31, 2017 | Canon Pixma iP6600D InkJet Photo Printer
Color transparencies are dark & poor color
Nice printer.. Hope this will give hints. Considering transparency papers, please try another batch of or a piece of transparency paper. Try to adjust also the graphics preferences (dark to light) aside from transparency paper selection. Have a nice day.
Best regards,
Rosener Guyano
Feb 17, 2008 | Epson ACULASER CX11NF All-In-One Printer
Paper feed
Your printer is politely asking you to please get a torch, and open the lid of unit and thoroughly check inside all over for a tiny jam of paper or something else. I am willing to bet you will find some jam. I would also switch it off, and wait a while before turning on and printing again. Good luck
Aug 31, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Dell 924 All-in-One InkJet Printer Logo
70 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
