Question about Sony Cyber-Shot DSC-W7 Digital Camera
Lens every time i turn the camera on the lens sounds like its opening but it is not, and the screen says turn off and turn back on. When i do that it just keeps on doing the same thing
OK I know whats wrong with this one, because my cmaera did the same thing. The outside shutter in the lens opens, right? Well, the inside shutter is stuck. Its staying shut. Take the camera apart(or if you dont feel comfortable doing it yourself, take it to a expert)and tap the side gently, it should fix itslef like that. If not, its the same problme, but you'll have to take it in somewhere.
Posted on Jun 01, 2007
Lumix DMC FZ35 Lens Opens and Retracts Continually When Turning the Camera on.
it sounds like it has slipped a gear in the lens.. you could try to manually push the lens in when it comes out and that might reset it but it also might break it.. best is to send it back to panasonic.. is a easy fix
Oct 01, 2012 | Panasonic Lumix DMC FZ35 Digital Cameras
What does it mean when your camera lens is not working and the screens say, turn off the power and turn it on again ? What happen if the camera lens is moving but ther screens is not opening or showing...
I may not have enough information for this... how ever, let us try. And I am not sure which one you are talking about, maybe both at times?
Does the camera play back files correctly and can be seen on the LCD?
If the first, then some problem exists with the lens. This camera then needs repair.
If no screen on the LCD, then repair is recommended.
In both cases, it seems the camera is in need of repair.
Because this camera is a few years old, I recommend to sell it for parts and as is on a site such as Ebay.
Nov 14, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Lens Error!
Hi onikaassing, A very common problem in all the brands "lens error". The remedy is that you have to replace the lens block assembly. Actueally the sled motor start malfunctioning, Contact nikon service centre maybe they have the component level repair facility which can reduce the repair cost. Thanks for using fixya.
Jun 14, 2009 | Nikon Coolpix S210 Digital Camera
Lens Error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 17, 2008 | Nikon COOLPIX L4 Digital Camera
Lens error
This lens is in need of repair, though contrary to what some of the people on this site will say, paying $150 for a lens repair is completely unnecessary.
Usually a problem like what you are having is just a realignment and cleaning of the lens and gears. This in itself is a relatively cheap repair ($50-$75) Sometimes however, the plastic housing covering the lens itself gets damaged, or the lens twists inside the housing, which many times can require purchasing a new lens (this will run $150 or so).
Jun 17, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Optio M20 Camera: Press on/off button to power up camera, the camera opens the lens cover, turns on a red led inside the lens, cycles the lens out and back in,then makes about 5 little popping noises. The...
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 29, 2008 | Pentax Optio M20 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Lens error
wheni go to turn on my camera it says"lens error"on the screen and wont turn on lens is "stuck"open.
Nov 26, 2007 | Nikon COOLPIX L3 Digital Camera
Camera lens comes out and goes back in when I turn it on.
Sounds like the lens can't get into the proper position. Any possibility of damage to the lens?
Aug 10, 2006 | Olympus FE-110 Digital Camera
Lens malfunction
hello, you are right. Actually there is some problem with lens assy.. When you turn on the camera the processor of camera start to check whole camera including mechanism. when it find something abnormal,it will not let to turn on the camera. This is the problem. I think there is some problem in lens mechanism and i and processor also suppose something abnormal in lens mechanism which makes buzzing sound. it is advisable to go to sony for professional repairs. hope you got it...
Aug 01, 2006 | Sony Cyber-Shot DSC-P92 Digital Camera
Sony Cyber-Shot DSC-W7 Digital Camera Logo
59 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Syzys
Are you a Sony Camera Expert? Answer questions, earn points and help others
