Question about Symbol MC9090 Barcode Scanner
Types of Barcode that can be scanned using Symbol MC9090
I would like to know if the Symbol MC9090 scanner can read all types of barcodes or not?
Can you please specify the list of barcode types that can be scanned using Symbol MC9090 scanner.
  • Anonymous May 08, 2009
    Can it read I2OF5 barcodes? I am having trouble scanning that type but all others I have tried seem to work without issue.
  • toddjordan May 14, 2009
    What about with DCLINK software?
  • 97 Answers
It can read all standard symbologies apart from PDF symbologies unless it is equipped with an imager scan engine.
Posted on Mar 26, 2009
    New Friend:
  • 4 Answers
This depends on the spec of the MC9090 and which scan engine is installed. Imager versions are capable of reading all common symbologies, 1D versions are limited to linear codes. Check which are enabled in data wedge or Wavelink depending on which application you are using on the device.
Posted on Dec 15, 2012
MC9190 will not scan a certain barcode, but the MC9090 will, what could be the problem?
Firstly you need to know exactly what 'symbology' or type of barcode you are trying to scan. E.G. 128CODE, ect.
Once you know this make sure 'DataWedge' is installed and go to the settings section of the software.ensure that the type of barcode you are printing is selected in the settings. After this is should work.
regards
Dave (Pen Mobile) Germain
Jan 28, 2013 | Zebra Symbol Technologies MC909X-G Series...
Can we determine the symbology of a barcode that the MC9090 just read?
This is application dependant. The Motorola Datawedge does have this function and so does some diagnostic software, but each application would need to have the functionality written for it.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL +44(0)1202 620955
http://www.biastechnology.com/
Jun 05, 2012 | Symbol MC9090 Barcode Scanner
Symbol DS9808 will not scan barcode
Hello Dbird,
the scanner has several barcode types enabled by default. Other type or lengths must be activated with an programming barcode from the Programm Reference Guide for DS9808.
Please check which kind of barcode are you using. Download the Program Reference Guide from support.symbol.com Scan the barcodes from the chapter Symbologies
Dec 02, 2010 | Zebra Symbol DS9808 Barcode Scanner...
Symbol MC9090 Barcode Scanner cannot enable scanner error code "A0000008"
The scanner engine/output can be used only by one application. If a second application is trying to access the scanner, while in use. The error message will come.
Please check if there are more applications running in background. Usual MC9090 applications with scanner drivers are Telnet, Datawedge, Rapid Deployment and custom software. Exit one of the application or try to exit all of them. Start your scanning application again, no error should appear now.
Oct 21, 2010 | Symbol MC9090 Barcode Scanner
How do i update the firmware on a Symbol MC9090?
http://support.symbol.com
go to the link above, type in the vs of the mc9090 that you have, for example, firmware upgrade for mc9090-g
let me know if you need anything else
Kim Ganoe
Datex Corp
800.933.2839
Mar 18, 2010 | Symbol MC9090 Barcode Scanner
Does anyone have a successful experience using this to scan outdoors in full daylight?
not sure if you found a solution , but I figure I''ll share mine anyways.
we had the same problem in scanning outdoor so this is what we did:
there are 2 types of MC9090 standard range and short range. the short range works batter for outdoor sine it has a wider longer beam. you will loose in distance , you will have to come closer to scan but it will work ....
let me know if you came up with something else ...
Aug 06, 2009 | Symbol MC9090 Barcode Scanner
Give me an example about defined data types
data types are variables which is used to store values in to the memory for ex: numbers can be stored in the for of integers(int), alphabets and special characters can be storerd as characters(char), date can be stored as date format(date) etc.,
these are called data types:
int
char
date
varchar
Jun 25, 2009 | Symbol MC9090 Barcode Scanner
Could not active it the scanner on the MC9090
The link works for me DataWedge provides a convenient mechanism for non-scanning aware applications to receive data from embedded or connected data capture devices. It allows the user to capture data into any application that accepts keyboard input. It supports four types of Data Feeds: Barcode Scanners, RFID Tag Readers, MSR Readers and Serial Data Input. It provides user with text/hex data formatting and prefix/suffix facilities. Description
  1. New Test and Log Display.
  2. Improved DataWedge Startup Time for MSR and RFID
  3. Gen2 RFID Support
  4. Device enable/disable persistence over cold boot
  5. Virtual Key Support in Prefix/Suffix
  6. Performance improvements for MSR
  7. Enable Serial Interface on startup
  8. Support added for Event based Serial reading.
  9. Delays regarding RFID are fixed.
  10. Several Barcode character mapping issues fixed.
make sure some security software is not blocking your access
Jun 22, 2009 | Symbol MC9090 Barcode Scanner
Symbol MC9090 Barcode Scanner Logo
1,691 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
