Question about Sony DCR-VX2100E Camcorder
White balance won't set manually
I own a Sony VX12100, which is about 4 years old. It's been a solid workhorse, as I've probably shot over 300 hours of footage. I was out on a shoot yesterday, and the manual white balance failed to set. The picture is very green, and when I go to set the WB in manual mode is just keeps flashing. Also, I've been getting the "Clean Cassette" warning on a more frequent basis lately. Any ideas?
3 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: I have a Sony Mini DV Camcorder about 7 years old.
Yes, need to clean video head of camcorder.
Put MiniDV head cleaning tape in camera and clean its video head as per instructions on cleaning tape.
Thanks.
Posted on Oct 20, 2009
Testimonial: "I was a Fixya Virgin - Got a response in less than 2 minutes. Appreciate the service and will look to joining this site for future needs. Thanks!"
  • 150 Answers
SOURCE: Getting footage from a cassette onto a mac
Sorry but the only way to transfer the tape is to be able to play it in a compatible camcorder or player. Then use one of the analog to digital converters "available on the internet" to transfer it to a PC.
Best bet is to ask some friends if they have an old camcorder that will be able to play that video cassette for you.
Sidenote: If the cassette is fairly new it might already be recorded in digital format, in which case you only need a compatible camcorder or player and a USB or Firewire cable to import it into your Mac
Hope this helps, don't forget to vote if the answers you seek are helpful.
Posted on Mar 23, 2010
50 inch dlp, keeps turning off, been happening since set was a year old, but now it won;t stay on at all some people say scrap it instead of repair what should I do
You probably have a bad lamp. They usually last 8,000 hours. If its not the lamp, it is probably a bad power supply or lamp ballast which is about a 200-300 dollar fix.
Jun 07, 2011 | Akai PT50DL24 50" DLP TV
Is it possible to turn off the white balance in a Sony Cybershot DSC H5?
White Balance is not a setting that can ever be turned off, it is simply your camera's way of telling what is white so that it can process colors correctly. You can however adjust the white balance manually or simply set it to auto. Auto white balance usually works great and I would highly recommend using it. To adjust your white balance, here are the steps:
1) Press the menu button. scroll using your arrow pad to the WB option and then press the Control Button.
2) This should bring up your white balance selection screen. Keep in mind that if your camera is in full auto ( the dial is set to the camera icon ) you will not be able to adjust your white balance.
I hope this helps!
May 05, 2011 | Sony Cyber-shot DSC-H5 Digital Camera
Indoor photos are yellow.
Your camera is choosing (or you chose) the wrong white balance setting. Try Auto White Balance, and if that doesn't work, try tungsten white balance. You could switch to daylight color bulbs in your lamps.
May 02, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
Excessive amounts of Blue Colour on many shots.
You may have the white balance set to something other than auto white balance.
Apr 12, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Two identical Sony cameras are giving terrible photos.
Actually, it probably is the lighting. The Canon's auto white balance just did a better job of adjusting for the lighting. If you work with the white balance control on the Sonys, they will be just fine. Practice, practice, practice.
Feb 22, 2010 | Sony Cyber-shot DSC-W100 Digital Camera
White balance on D50 set correctly?
Are you saying that you're using a white background but it doesn't appear white in the pictures? If so, then yes, you need to change the white balance to match the light. Probably "tungsten" but you could try different settings and pick the one you like best or you could use a white piece of paper and set a manual white balance.
Oct 24, 2009 | Nikon D50 Digital Camera
Some images 'cool' some 'warm'
That issue is related to "white balance". Sounds like the camera is not measuring white balance correctly in order to determine the best setting for each shot, and is flipping between correct and incorrect settings, even in the same conditions!
I could go into detail here, but really it is much easier and perhaps better explained with images on many websites. Here is one example:
http://www.cambridgeincolour.com/tutorials/white-balance.htm
As for a solution, well obviously the camera is not working as it should, but you could also try setting white balance manually if your camera allows it. The above site tutorial will give you an idea of how to do that and what setting to use.
Jul 20, 2009 | Sony Cyber-Shot DSC-V1 Digital Camera
Olympus E300
Hello Kate, See if you can find an internet cafe. I was reading the white balance section of your manual and there is nothing that stops your camera from taking pictures if the white balance is off. Turn your camera off, remove your batteries for about 30 seconds and let it reset to default. Then try inserting the batteries and see if this helps. I wouldn't mind sending you this manual if you can provide an email address. Or a link to go to is: www.olympus.com, then select americas, then select support, then select your camera, then download your manual in PDF format. I wouldn't want your vacation ruined either.
Aug 11, 2008 | Olympus EVOLT E-300 Digital Camera
Limited setting for White Balance.
Hi: So you bought the camera but didn't make a good choise :) Yeap, the "four only options" in the Sony F55 in the White Balance Function are what you said. You have to have that in attention when buying a Digital Camera. About the White Balance > Hold, the intention is to adjust the white balance acording to an object. After you select the option, to use it you just have to point the camera to the object, press half off the shutter button to focus, then you chose the angle and press the rest of the shutter button. On the other cameras those options improve the quality of the skin tones and colors of your subjects reduzing color temperature. Regards
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Sony DCR-VX2100E Camcorder Logo
56 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Jose Ma DM.
Jose Ma DM.
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
