Question about Xerox DocuColor 12 Color Copier
Xerox 5765 enter diagnostics
I need enter to diagnostic its a xerox 5765 and the error codes i have 9.... whats means this thanks
  • gattitox Jan 17, 2009
    your answer its right, but i cant display the entire code, how can do this wich key i need push please. thanks for your answer
  • 62 Answers
Any 9 code is xerographic. This machine isn't worth fixing if you want me to be truthful. The parts alone will cost you more than enough. Look for DC12 on ebay or something to upgrade.
Sorry, but its the best solution
Posted on Jan 16, 2009
  • oooimstuck Jan 18, 2009
    i'm not that familiar with the 5765 as its an old machine, but the older ones used you used to hold down the "0" button and the rest of the code would appear. Hopefully its a nice easy fix like your waste is full or somethings. fingers crossed
Xerox Phaser 8860 error code 04, 025,.46:0?
Want to resolve your printer issues online then, dial Xerox Printer Support Phone Number1877-778-8@9@6@9 anytime as you like. For further Info Click:https://goo.gl/Co2Bom
Jul 02, 2012 | Xerox 8860dn Phaser All-In-One Thermal...
116-330
Enter UI Diagnostic(hold 0-zero for 6 seconds and press Start button, find Diagnostic) in dC355 Hard Disk Diag Program and make a diagnostics of HDD. Refer to Initialize Hard Disk procedure in UI diagnostic <!-- from fixya rte -->
May 21, 2010 | Xerox DocuColor 12 Printer
My Xerox Copy centre C123 shows error code 124-315 pls help
Thats a weird one. The machine is detecting the wrong speeds.
Try this.
  1. Enter Diagnostic Mode ( UI Diagnostic Mode).
  2. At the Control Panel, press and hold the 0 key for 5 seconds, then press the Start button while still pressing the 0 key.
  3. Press buttons 6, 7, 8, and 9 on keypad and press Confirm.
  4. Press the Log In/Out button (button with Key symbol) on the Control Panel.
  5. Select System Settings.
  6. Select Common Settings.
  7. Select Maintenance/Diagnostics.
Then look at these 3 locations and see if they match, If they do not set them to match the machine speed.
  • [700-600]
  • [700-601]
  • [700-602]
Feb 11, 2010 | Xerox CopyCentre C123 Copier
LA FOTOCOPIADORA XEROX 1025 COPIABA BIEN DE REPENTE ME MANDA U2
U2 = Memory failure.
moz-screenshot.jpgClear U2 error
Enter diagnostic mode
To enter diagnostics:
  1. Power on
  2. Press 'Clear' > 'Exposure' > 'Clear' > 'Exposure' buttons within 4 seconds.
  3. All the lamps on the control panel will go out.
  4. Enter the service mode using the 1 button.
Enter code 16
Press Start button
Exit diagnostics, by switching machine off.
If the error returns, you will need to replace the main board.
Good Luck!
Dec 05, 2009 | Xerox Office Equipment & Supplies
Error-9-354
User Interface (UI) DIAGNOSTIC ENTRY:
Turn on the power… then while holding down the ‘0’ button, press ‘Start’.
The screen will prompt you for an “Access Number”… use the keypad to enter ‘6789’ which is the Default Access Number.
This should bring you to a menu of options to choose from:
• NVM Reset (Non Volatile Memory) / NVM Initialization
• NVM Read / Write (memory adjustments) you will need to know which codes do what
• Component Control (for testing sensors, motors, etc.)
• Print (for running Test Patterns from Diagnostics)
• Subsystem Check (for fuser nip measurement check out, and developer unit check out)
• Max Setup (for setting up copy quality)
Set NVM to 776-060=0 and 776-372=0
Hope that helps
Mike
Sep 23, 2009 | Xerox DocuColor 12 Color Copier
Xerox XC1875 U4 Error on Startup
Give this a try. it may clear you code. Use program 14
To enter diagnostics: Turn on the power and within 4 seconds press the following sequence: ‘Clear’, ‘Exposure Mode’, ‘Clear’, ‘Exposure Mode’ (Exposure Mode is the button on the far left). The console will go completely blank.
To enter a code: Select the first part of the code using the copy quantity buttons, followed by the ‘Print’ button, then the second part of the code followed by the ‘Print’ button again.
To exit diagnostics: Press ‘Clear’ repeatedly or turn the power off.
*To clear a fuser code:(14) Enter diagnostics, select ‘14’ followed by ‘Print’… exit diagnostics.
**To Clear a U2 code:(16) Enter diagnostics, select ‘16’ followed by ‘Print’… exit diagnostics.
May 04, 2009 | Xerox Office Equipment & Supplies
Xerox majestik 5765 error codes
Sorry I am not familiar with this machine, usually if you press the start key for 3 sec it should show you the other codes? Good luck.
P.S.: If i run into anything I'll send it to you .
Jan 12, 2009 | Xerox DocuColor 12 Color Copier
Error code H3 displayed on Xerox XC1044 Copier
this is the solution:
To enter diagnostics: Turn on the power and within 4 seconds press the following sequence: 'Clear', 'Exposure Mode', 'Clear', 'Exposure Mode' (Exposure Mode is the button on the far left). The console will go completely blank.
To enter a code: Select the first part of the code using the copy quantity buttons, followed by the 'Print' button, then the second part of the code followed by the 'Print' button again.
To exit diagnostics: Press 'Clear' repeatedly or turn the power off.
*To clear a fuser code:(14) Enter diagnostics, select '14' followed by 'Print'... exit diagnostics.
H3 stands for high temperature at the fuser.
Mar 15, 2008 | Computers & Internet
Xerox DocuColor 12 Color Copier Logo
256 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
