Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
It just stopped
I was mowing along on Saturday and the mower just stopped. I removed the cover thinking the motor had blown, it did not smell as if it had blown. I replaced the switch in the handle and that did not help. I'm wondering if there is a fuse on this machine. Any Thoughts?
  • Barry Nov 13, 2007
    I had been mowing with the catch bag on for about 45 minutes. I changed the cord to another outlet to finish. It started initially ( went one 4 foot push into moist grass) and then stopped. I checked all electrical fuses in house, switched outlets again etc.....
    solution? I waited a day and sure enough it started just fine? I am calling Black & Decker to see if this is a known problem or an unadvertised "overheat or mositure" protect mechanism
  • Anonymous Apr 28, 2008
    I had been mowing with MM875 Black and Decker 19 inch electric lawn mower, and it stopped about 30 mit. later in the middle of cutting. The grass was very long and wet (it was about 11 AM in a cloudy day) and the engine was constally conking, and I was forcefully pushing the lawn mower. I tried next day, but it still did not work. I opened the handle, and I did not see the burn marks on the wire. How do you check if the motor is OK or not?
    Kyong
Mine stops like described above... but after I go to garage and dirnk 1/2 beer while watching NASCAR, then go back and mower works great.... but only for a few minutes on hot days.  Results in lots of beer consumed, but great NASCAR covereage.  On cooler days, it stops less often, but still stops.  Results in less beer consumed, but I haven't a clue who won the Busch series today.
I thnk it's a temperature thing... but not sure about that.  Sometimes works great, even on hot days; but not worth a crap on cold days.  Go figure.
OTHERWISE, I love my cordless electric mower.... I just with I could mow the whole damn lawn without interuption.
Posted on Oct 28, 2007
Most (or all) electric motors have an overload device (heater) that detects high current in the copper windings of the motor. so if the motor is getting too hot, a thin piece of metal bends and breaks the circuit. after a while the thin piece of metal cools down, reconnects the circuit and it will start again until it overheats. overworking your motor will cause high current in the copper windings and hence the motor to stop working until it cools down.
Solution? replacing the heater in the motor may do the trick. that thin piece of metal can only bend so many times before it gets weak and/or faulty.
i am having a similar problem. i took off the cover, but it looks like the heater is internal on the 19" cm1000 motor. i'm not brave enough to tear open the motor itself..=(
good luck.
Posted on May 24, 2008
I had a similar problem. My solution turned out to be the key. The metal part of the key was no longer lined up properly (I think I turned it too hard once). I took a pliers and set it correctly again, and have not a problem since.
Posted on Apr 20, 2008
Bridge rectifier may have to replaced .
Posted on Jul 16, 2007
Procedure for adjusting valves on series 100 lawn mower
if you think it is a valve problem briggs and stratton website has a page that gives all the specs. for intake and exhaust vale setting. you will need to know your engine size and model number.
May 29, 2016 | Garden
21 hp B@S engine exhausting blue smoke
sounds like blown head gasket.
does it have a fuel pump, if so is there oil around it (by the brass colored screen)
if so then you have blown head gasket
Oct 24, 2015 | Craftsman 46 In. 21hp Briggs & Stratton...
Mtdproducts com
This most often happens when you are mowing too much grass at once, or when the deck (or chute if you have a bagger) is clogging for some reason. Sometimes this is made worse by having dull blades. Usually mowing at a slower speed or mowing more frequently will help solve this. If the motor is struggling with the blades, these are usually the culprits. Clean your deck thoroughly, cut the lawn more often, or cut it slower.
In some cases, if your PTO belt may be worn, stretched, or need adjustment. When this happens, the motor will not slow down with the blades but will keep running normally and you may smell a burning rubber smell as the blades slow down.
Jul 16, 2013 | Garden
Murray 42" 20hp stops running
there are safety switches that can shut it off i would disconnect the coil wire from the harness its a small wire if it doen't shut off with that wire off its on the mower side causing the problem the other thing to check is to remove the upper engine cover and see if a mouse chewed threw the wires under there
Aug 05, 2012 | Garden
When pulling cord to start mower there was a click sound and the cord would not rewind
Remove top cover to your engine with all other attachments. Be careful because loosening this part will most likely recoil the cord. The recoil is in the top of the cover. Turn cover over and put some oil on all the mechanical parts at center of unit. Pull the cord till your satisfied it has been lubricated.
Replace top cover along with all attachments, and you should be ready to mow. GOOD LUCK.
Jul 25, 2011 | Garden
LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Wiring problem
its unsafe to hot wire the switch. contact me at 204-783-7294 i will send you a wiring diagram ask for dennis
May 05, 2008 | Black & Decker 19" Electric Lawnhog...
MM875 electric lawnmower
check motor if armature are not broken & see if the rectifier not burnt. rectifier works from ac & convert it to dc to run the motor.
if you need diagram for parts see toolpartsdirect.com
Aug 27, 2007 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
556 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
