Question about Brother HL 5150D Laser Printer
Brother HL 5150D not printing unless I keep pressing Go
My printer will print 1-2 pages and then the status light will go red and the paper light blinks but there is plenty of paper in the printer. If I press go, it will print another 1-2 pages and then stop again. I tried changing the toner with no results.
    Sergeant:
  • 221 Answers
Its not the problem of toner cartridge.its the problem of gears which pulls the paper they r worn out or may be cracked internally.exactly what happens when you u give the print for the first time the printer gets command and the gears starts spinning and the paper gets pulled because it gets a pressure internally and after 2 pages that pressure gets low and it stops pulling the paper.some times changing the paper thickness solves the problem temporvarily .i mean use the thick quality paper instead of thin.
Posted on Jan 08, 2009
When press print, the status light flashing orange. It print for a while then the paper light flash yellow, then it stop. The printer print up to half a page the it stop. Check printer and turn printer...
the flashing amber status light is normal indicating data going from computer to printer.the flashing paper light indicates a paper jam or out of paper. A sensor maybe not working properly or sticking. If your model number ends in a D check
Jul 16, 2014 | Brother HL 5140 Laser Printer
What are the steps to reset toner lights for Brother HL 2240
Try this Toner reset sequence (worked on Brother HL-5350DN)
With Printer off open the toner door
Hold the Go button as you turn the printer on.
All lights will turn on. Keep holding Go until status light goes off.
Press the Go button 2x.
The Paper, Drum & Toner light will come on
Press Go 6x
Status light will turn red
Close the front.
Jul 02, 2014 | Brother Hl2240d - Hl-2240d Laser Printer...
Prints blank page, then ERROR: undefined
When you press and hold down the Button will it give you a test print. Have you down loaded the latest drivers from brother.com.. Also does it do it with all programs.
Feb 03, 2010 | Brother HL 5150D Laser Printer
How to find number of pages printed from a brother HL 5250N
Turn on the printer.
Once it is on and the status light is on, press the Go button 6 time. Status light turns yellow and printer will print off internal configuration - including number of pages printed. Should be 3 pages. This report also includes the percentage used of toner, drum, laser, and fuser.
Dennis
Jan 27, 2010 | Brother HL 5250DN Laser Printer
My Brother 5240 laser printer has a red status light when i turn it on. I hit cancel job, and the light turns green. however, when i print a file, the file goes into the print queue for a few seconds then...
It may some paper jam inside your printer . open the front cover pull out the cartridge and look any jammed paper is there or not. if not the the problem may came from your toner drum.
Nov 25, 2009 | Brother HL-5240 Laser Printer
My hl 5150D will not print. when isend document
1/ Check waste toner may need empty. 2/ You maybe out of toner. remove toner and give it a good shake will get a few more prints usually. Need more info from you. Have you check paper paths. Have you rebooted both printer and computer. Remember you must remove power supply on both for ten seconds for true reboot.. Good luck
Oct 10, 2009 | Brother HL 5150D Laser Printer
Can the Brothers HL 2040 handle printing 65lb
It probably can but only from the front slot, the paper tray has to bend the paper around the roller in the front when feeding.
Aug 28, 2009 | Brother HL-2040 Laser Printer
HL-5140 Brother laser printer red status light remains on.
The red lite indicates one of the following needs to be looked at:
Cover open (Front cover) Close the front cover.
Cover open (Jam clear cover) Close the jam clear cover of the fuser unit.
Memory full - Press the go button.
Print overrun - Press the go button.
Clean drum unit - Clean the corona wire.
Jan 15, 2009 | Brother HL 5140 Laser Printer
Not printing
The red light, along with the paper light being lit indicates that it is having a problem feeding the paper OR it is set wrong for duplexing. Check your manual on page 3-4 or download a manual at:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_5140_5150D_5150DLT_5170DN_5170DNLT_EN_1295.PDF
I can't tell which of the error conditions fits your situation, but this should put you on the correct path to figure it out.
May 22, 2008 | Brother HL 5150D Laser Printer
Print light blinking
turn it off..let it set for 4 min..and then turn it on..try a test page first, though
May 10, 2008 | Brother HL-5240 Laser Printer
Brother HL 5150D Laser Printer Logo
235 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
