Question about Philips 32PT9100D 32" TV
HDMI switching problems
I got a Dish Hi-Def receiver (vip 622 dvr) last week so I could start enjoying Hi-Def for the first time on my Philips HDTV. Bought a HDMI cable and hooked it up between the SAT receiver and the tv set and switched the AV to HDMI. Nothing happened so I unhooked and hooked it back up again and the TV started receiving in high def. End of story?, not quite, after I turned the TV back on a while later-no HDMI picture/audio, so I again did the unhooking/hooking thing again and the HDMI came back. Now every time I switch the TV set off the HDMI goes dark, but will come back provided I fool with the cable again. It doesn't happen when I switch the Sat receiver off/on, just the tv set. Anybody experience this problem or know of a solution? Superb Guy
  • 1139 Answers
SOURCE: DVD VHS recorder
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
Posted on Sep 20, 2007
  • 5568 Answers
SOURCE: No TV Signal
This is an older message but if you haven't thrown the set out yet, don't!  Later flat panel sets don't seem to last longer than a year or two before failing so you might want to keep this one.
Your set's tuner has failed. This may be a separately replaceable module.
If you want to take a stab at it, unplug the set for at least several hours, remove the few screws (less than 10) that hold the rear housing.
If the tuner section is not integrated into the main board, you should see a device that is shielded by a sheet metal housing in which the tuner resides.
If this is obviously removable, look on line for a replacement unit for your model of set. They may or may not be still available.
If you can't identify the tuner check with the BBB in your area for a surviving TV repair with a good reputation.
Posted on Jan 10, 2009
  • 814 Answers
SOURCE: tv goes on fine, sound good and pic green light receptor on tv starts blinking and we lose pic sound still good. When we tap the light on tv pic comes on fine for a while then same thing happens again
This television is having problem with intermittent tuner reception.The tuner is the signal processor for the television. The video section is intermittent. This could be a simple matter of cold solder joints that can occur over time due to heat expansion and contraction.This causes the metal in solder to expand and then when the television cools down, the metal that is expanded cannot contract.The solder joints then becomes intermittent. All televisions suffer from this problem.Since you are able to still able to receive the video signal, there appears to be no component damage. You will need to take this television in to a service center and have them rework the solder on all the areas around the tuner section of the television and any other areas that may be susceptible to the problem due to overheating.You can call Magnavox customer support at this telephone number 1-800-705-2000 and ask them for the location of a service center in your area. Or take it in to a local repair center and have them test and service the television for you. You can also try taking it to a school where they are teaching electronic repair and ask them if they will work on the television for you.They will usually do the work for a cost of parts and a small labor charge. Call them first to make sure they will help you and tell you how you can get the television serviced This may not be the only problem you are having with the television. That is why you need to have it tested first. I hope this information help you with your problem.
Posted on Jun 03, 2009
  • 11 Answers
SOURCE: I own Philips TV Model 21PT. When last time I have
Check the supply voltage for the IC sound or change the IC.
Posted on Jan 08, 2010
  • 417 Answers
SOURCE: I am trying to hook up my Philips 19PR19 (made in
Because your TV is an older one, it might not have, what they call RCA inputs (the 3 colored cable) Red-audio right, White-audio left, Yellow-video. If I understand you.
You do have the option of using the 75-ohm coaxial cable inputs. Signal comes in from outside to the 722k, Output of the 722k to the 75ohm coax input on the back of the TV. Tune your TV to ch. 3 or 4. Make sure the switch on the back of the 722k is set to the same.
If you really want to use the RCA colored cables, then you need to buy an RF modulator, which integrates older tv's to newer products. But usually dvd players, not necessarily cable boxes, but it would work if hooked up correctly.
You plug the RCA red, white and yellow from the 722k, into the rf modulator, choose channel 3 or 4 on the modulator
Connect 75ohm coax cable from rf modulator to TV 75ohm coax cable input. Choose channel 3 or 4 on the TV.
Hope this helps.
Posted on Apr 07, 2010
  • 2098 Answers
SOURCE: Hi, I have a Philips 24PW6006/05 flat widescreen
Hi Eugene,
This symptom was caused by leaky/dried filter electrolytic capacitor in the output of power supply section. This capacitor will produced an out-of-regulation in the supply. It needs a warm-up to make itself stable but the symptom will get worst which will not power up or disable the power supply. Leaky capacitor has a dome/bulged at the top and easy to recognize but dried capacitor has no physical indication of fault. You must have a capacitor checker to determine its condition and pinpoint where the faulty one. If capacitor checker is not available, you may replaced all the electrolytic capacitor in the output stage of that board. The affected working voltage are 10v,16v,25v,35v if you see the capacitor with this working voltage replaced them all and your unit will back to normal again. This will not cost you much, because it is cheaper than other parts($4 at the most). Here is the sample of leaky capacitor.
Here's the link for parts replacement.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 07, 2011
0 characters
1 Points
I have Dish Sattelite. The screen on my JVC digital tv says digital strength is low. Do I call Dish? or ?
This sounds like a cable issue. Assuming your Dish receiver is connected to your TV with a HDMI cable (ends are rectangular and the connector is trapezoid in shape), you can first attempt to switch HDMI ports on the back of your TV. If you get the same message, you can try flip the cable end for end -- plug the TV end into the receiver and the receiver end into the TV (I know, sounds silly, but has worked for me). Next is a new (better -- don't get a $5 cable, most good HDMI cables start close to $20 and up depending on length).
Now if you happen to be connecting via a "standard" TV cable (RG 6), first make sure that the cable is screwed on snuggly (no wrench needed, just finger tight). Next is to get a new cable.
May 01, 2014 | JVC AV-20020 20" TV
Can i hook up an old tube type tv to a new high satellite dish? i dont care if i get high def picture just want a regular picture.
Yes there is an option for ouptuting 480i signal from most hd receivers. You will need to check the specifics for the satellite dish receiver as to the channel that the TV should be on as well as how to set it to the resolution that you need. (I know some Dish receivers need channel 60 for the SD TV (coax (RF) connection) when it is TV 2 but channel 3 or 4 for TV 1.) Also check your TV so that you can use the best possible input available.
However, you may not be able to read the closed captions unless you enable them on the receiver. (Apparently, the encoding has changed.)
The manuals for some satellite company receivers are on their website. For example, Dish network manuals are here: . Their manual for the Solo VIP 211k describes connecting the receiver to a SD TV on page 91 (page 97 in the PDF version).
I hope this helps.
(I'm not aware of any satellite system that doesn't use a set-top box. If you do not have a receiver, then the above does not apply and you may not be able to get a signal.)
Apr 13, 2011 | Standard (CRT) Televisions
We would be happy to help get that fixed right away. Theissue that you are having sounds like it is affecting the TV that is closest toyour receiver; we call it your TV1. The first thing we want to ensure is thatall connected equipment is on. Check what type of cable is used to connect theTV to the receiver. If you are using a Coax Cable to connect the receiver toTV1, check the receiver's back panel for the output name. If your receiver hasa "TV CH 3/4 Out" (non-ViP Receiver): Tune TV to channel 3 or channel4, back if it is labeled "Home Distribution" (ViP Receiver):Tune TV to channel 62 or 75. If using non-Coax (RCA, Component, or HDMI) toconnect receiver to TV1, cycle through the inputs until picture appears; MostTVs have a "TV/Video", "Input", or "Source"button. We want to ensure that the TV and the receiver are connected properly,please visit this link to for more information: Once we havemade sure everything is connected properly, unplug receiver for 10 seconds thenplug it back in, this will reset the receiver. If we are still not getting apicture connect another component (VCR, DVD Player, etc.) to the same TV, usingsame cable, same input, and same channel to see if it works. If you get apicture with the other component give us a call at 1-800-333-DISH (3474) forsome additional troubleshooting. If it doesn't work with the other componentthen replace the cable that was used.
We hope these steps resolve the issue. We want to thank you for being a valuedDISH Network customer!
Phillip Chang DISH Network Customer Service Representative
Jan 02, 2011 | Toshiba 32A33 32" TV
We have replaced the dish and receiver box for our 52 in JVC television but still get a "not receiving signal will shut down in 9 minutes" message. Direct TV says that it is a TV problem. What...
This means the input board on your TV is having a problem or that you are just on the wrong input.
How are you connecting the receiver to the TV, through what kind of connection? HDMI, Component... or do you know?
Are you certain you are tuned to the correct input on your TV, for example are you sure you are on INPUT - HDMI 1 if you are plugged into HDMI 1?
Please let me know, or if you need help identifying what input you are on and how to get there.
Just reply to my answer here and I can help,
Nov 08, 2010 | JVC Standard (CRT) Televisions
Toshiba CN36X81 television.. NO Sound... Great Picture. Using the TV2 output of a DISH Network HD receiver... TV2 output is std def, coax output. Using a different TV I get picture and sound... but not...
IF coming in via, the "Dish" networked receiver, please check that this volume is turned way up, on the TV. and then control the the Volume, with the Dish Remote, often this is a problem, as one is turned down, and the other cannot turn that up, simply try syncing the Volume controls, UP on TV, control the Audio with dish remote. thats all i can think of. Check by feeding a signal IN from an AV, source, ie: Yellow, Video, & Red& White, Audio. Turn TV UP and check, IF it responds to this all is well. If NOT then you do indeed have a fault, with the TV.
Mar 27, 2010 | Toshiba CN36X81 TV
Is my hd1080 that i bought about 8 to 9 years ago a high def
If your TV has HDMI inputs or if your receiver has component video out, then answer is yes. Please repost if you need any help.
Aug 30, 2009 | Mitsubishi WS-55807 TV
Problems programming DVR remote to TV
If your DirecTV remote is in SAT mode and the power button isn't turning the receiver on and off, you will likely need a new remote. There isn't suppose to be any trick to getting the power button on a remote to work. However, only DirecTV tech support can confirm this. I would give them a call right away.
Jul 12, 2009 | Philips Standard (CRT) Televisions
Picture format ?
This tv maxes out at 1080i, but that is for the HDMI input. 720p for the Component video input.
Feb 02, 2008 | Philips 30PW8420 TV
Philips HDTV does not turn on
look for imperfect contacts on the inside main board.
Jan 21, 2008 | JVC AV-27230 27" TV
Sanyo DS27880 27" TV, Dish signal lost after tv turned off, doesn't return
checks should on your tv tuner it could be bad.IF circuit should also be check and the video section call in the tech to make checks on your tv.and to do repairs on your tv.
Jan 19, 2007 | Sanyo DS27820 27" TV
Open Questions:
See all Philips 32PT9100D 32" TV Questions
Philips 32PT9100D 32" TV Logo
Top Philips Standard (CRT) Televisions Experts
Sp Gupta
Jim Evans
Are you a Philips Standard (CRT) Television Expert? Answer questions, earn points and help others
