Question about Vulcan Pwt 18V Rs 18V Cordless Reciprocating Saw
VULCAN RECIPRCTING SAW
WE NEED TO CHANGE THE BLADE BUT THE OLD BLADE IS BREAKING HOW DO WE GET THE BLADE OUT OF THE HOLE
  • David Ford
    David Ford May 11, 2010
    I have never heard of a Vulcan Recip Saw. Do you know who the original mfr is? If not plesase provide as much info as possible. What kind of blade clamp system and I will try and help.
  • Vulcan Master
  • 43,501 Answers
Getting a broken blade our of the sawzall chuck can be difficult and require some ingenuity and patience...
Sometimes there be enough blade left so that you can grab it with a needle nose pliers... othertimes it is flush and that makes it more difficult... holding the chuck in the release position and rapping the saw against a table or with a hammer can jiggle the piece out....of course you have the chuck pointed down while you do that...
Also moving the piece around a bit with a stiff wire and also soaking the chuck and blade with WD-40 helps also....
Usually it will take a combination of these things and some persistance to get the job done...
heatman101
Posted on Aug 27, 2010
How to change blade on a Chicago jigsaw
Harbor Freight Chicago Electric Jig Saw - Review - YouTube
? 2:21
www.youtube.com/watch?v=lSh0M4WIJTk
Dec 13, 2013 - Uploaded by AdamDIY
Chicago Electric - Orbital Jigsaw 92772 They change the design over time but some of the key flaws tend to ...
jigsaw from hell - chicago (electric?) brand - DoItYourself.com ...
www.doityourself.com/.../445560-jigsaw-hell-chicago-electric-brand.ht...
Mar 9, 2011 - Most blades either have a hole in the shank or the shank is shaped like a .... A brand new one is only about $25 and no tools for blade changes.
Oct 22, 2015 | Saws
How do you lock the blade to change it on a skilsaw model 5500
generally you put a screwdriver thru the hole in the saw blade and rotate blade until it stops against something and then remove bolt that holds blade on.
Aug 10, 2015 | Skilsaw 5500 Circular Saws
How to put the blade into the black and decker 3.4 amp powered handsaw
#1) You have to locate the blade release button on the saw (see your manual). The opposite side of the release button is a screw-like OVAL shaped PIN. To insert the blade, the direction( or position) of this OVAL shaped PIN has to match the OVAL shaped hole in the blade. You could use a screw driver to change the direction/position of this OVAL shaped pin. You have to push down the release button when you use the screw driver to turn.
#2) Hold the blade in Vertical position in your right hand. The "Oval" hole is on top. The teeth is facing your left hand. You will see that the "oval" hole on the top of the blade is a "horizontal" oval.
#3) Hold the saw (handle) in your left hand as if you were going to saw using your left hand.
Now peek through the hole of the saw and find the direction of the OVAL PIN. It has to be a "horizontal" (or lied down) OVAL. If it is not, use the screw driver to adjust it.
#4) Hold the blade using your right hand. Oval hole on top, teeth facing your left hand. Insert
the blade from the bottom of the saw. What you needed to do is to insert the PIN into the hole
of the blade. When you inserted the pin into the hole of the blade, slowly turned the blade upward, the blade will lock by itself.
Oct 15, 2013 | Black & Decker PHS550B Powered Handsaw...
How to change a blade on dw305 dewalt recirocating saw
On the DW305 you need an allen wrench to remove the blade. Some tools have one somewhere on the handle, if not find one to fit in the blade clamp hex-head bolt. Loosen the bolt and the old blade should come out easily. When you put the new blade in make sure the pin inside catches the hole in the blade.
Mar 07, 2012 | Dewalt Saws
KS 66 changing saw blade
Make sure that the hole in the saw blade is the same size as the hole in the old blade. If larger obtain a spacer from your supplier. (Spacer is a washer with outside diameter fitting tightly in the sawblade's center hole and inner hole the same diameter as your saw's shaft.
Aug 15, 2017 | Metabo Saws
Husky thd750 wet saw changing blade
If this is the K750 cut off saw, then to change the blade you need to remove the 13mm fixing screw ( anti clockwise )if you cannot hold the old blade to remove the screw, insert a 6mm pin into the right hand belt cover, there is a hole to tale this, this will engage into the pulley and lock it, then remove the outer flange, the old disc will now come away, make sure the new disc has the same size centre as the old one, the size will be on the rating plate on the cutter guard.
Oct 29, 2011 | Garden
Change blade miter saw
Un-plug the saw. Remove the screws holding the side saw guard in place. Look at the center of the saw blade for the nut holding it in place. Take a socket wrench that fits the nut and loosen it. You'll need to take a scrap piece of wood 2x4, and jamb the teeth of the blade into it while loosening the nut. The nut will come off first and then a washer/spacer.
Reverse the order for installing the new blade. Make sure you use the proper size diameter blade (10 inch) and mounting hole in the replacement blade. Also, use the provided washer/spacers that were on the original blade and secure the nut. Spin by hand to see if everything clears. Mount the protective guard back on. Plug in the saw and test cut .
Good luck. If you are still unsure - ask a handy neighbor to help. It takes about 5 minutes to complete this task.
Oct 05, 2009 | Delta Cycle Rothko Rolling Bicycle Stand
Can not remove the old blade
1. Unplug the saw.
2. Locate the blade lock button used to lock the motor shaft when changing a blade. For your saw, this button is usually located on the left side of the blade guard somewhere around the motor housing.
3. Push the button while rotating the blade until the button engages and the blade will no longer turn.
4. Use the wrench that came with the saw (or another wrench) to loosen and remove the blade bolt. For your saw the bolt should have standard right hand threads which means you loosen the bolt by turning it counter clock-wise.
5. Remove the old blade and replace it with a new blade of the same mounting type. Some blades have a round through hole and some blades have a diamond through hole.
6. Re-install the blade bolt and tighten clock-wise while holding the blade lock button down.
Oct 03, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
Size of hole in 10inch blade for dewalt power workshop radial arm saw
The size of the hole directlly relates to the size of the blade that fits on the saw, do not change blade sizes it is dangerous and will not fit properly
Mar 10, 2009 | Dewalt Factory-Reconditioned DeWalt DW432R...
How do you re-install the Skillsaw 5150 blade?
I,ve personally never heard of a problem quite like yours. I use skill saw brand saws every day and the arbor and washer will only make the blade wobble if installed incorrectly. Blades can be turned around to cut different types of material as well. Check to make sure the hole or diamond is the same on the new blade(you might have to punch it out) if its not seeding properly on the saw, you could also check under the guard to make sure nothing is binding the saw. The only other thing I could suggest would be to check the lock button (the one you hold to change blades, that stops the saw motor from turning) if that is stuck, your saw won't run. Good Luck!!
Oct 28, 2008 | Saws
Vulcan Pwt 18V Rs 18V Cordless Reciprocating Saw Logo
122 people viewed this question
Top Vulcan Saws Experts
Tom Chichester
ray gallant
Are you a Vulcan Saw Expert? Answer questions, earn points and help others
