Question about Admiral AW22 Top Load Washer
Washer must be out of balance
Washer moves and wobbles all over the place no matter what we do
I have floating bamboo flooring in my laundry area and the front load Samsung will NOT go into a spin without struggling for a very long time to get there. I suspect the floating floor as the culprit. Am going to try and screw down the areas around the four legs to see if that stabilizes it. But really... what good is this stupid smart Samsung if it can't handle a pretty stable floor..??
Posted on Oct 10, 2012
  • 221 Answers
The legs on the washer are adjustable, the rear legs are often ( not always ) self adjusting, make sure the legs are not stuck and that they can move freely. But the front legs can screw in and out to move the washer depending on the floor the washer is sitting on. Make sure the washer is as low to the floor as possible. When the legs are screwed out too far the washer becomes wobbly. Often on the metal style legs there are lock nuts that can be tightened to secure the legs so they don't move on you. washers where really meant to sit on a cement floor, if your washer is on a wooden floor look carefully at the strength of the floor. If the floor is moving up and down when the washer is running, the floor may not be strong enough to support the washers weight. Most main floor laundry rooms floors are nailed down, the sub-floor is more secure if the sub-floor has been screwed down. Sometimes extra support may have to be added under the flooring to add some strength
Posted on Jan 08, 2009
Why won't my washer spin?
Sounds to me like your washer tub had a very unbalanced load in it (heavy blankets, jeans, or pillows, all piled to one side instead of evenly distributed around the inside of the tub), and it threw it off balance. When it began to wobble and knock, it may have broken the mechanics underneath the tub which make it spin. The only way to properly diagnose it is if you remove the outer casing of the washing machine and look beneath the tub for broken/out of place items.
Feb 07, 2016 | Bosch Washing Machines
How to balance
By "balance", do you mean balance the load or balance the washer to keep it from wobbling on an unlevel floor?
You can adjust the front feet of the washer to "level" it with the floor.
Sorry I didn't quite understand your meaning. Hope you can use this info.
Jan 27, 2015 | Washing Machines
Tub is off balance
The tub is out of balance. When it starts hitting the sides, stop the washer and move your clothes around inside the tub to balance the tub. Now start it to spin again. This should stop the tub from hitting the sides.
Feb 14, 2012 | GE Washing Machines
Washer wobbles terribly at high spin cycle. Its legs ARE BALANCED, this just started happening one day. The geek squad replaced the 4 shocks and it still wobbles like crazy.I had my warranty company sen...
the washer requires a structurally sound floor for shake-free operation. anything other than a cement/concrete slab will shake. even on a tile floor there is slight shaking. a vinyl over plywood floor just won't cut it. a pedistal makes matters worse; as you're bringing the center of gravity up and away from floor.
Feb 04, 2010 | LG WM-2277HW Front Load Washer
My Kenmore Heavy Duty 70 washer is out of balance and bangs like crazy during the spin cycle. What can I do to repair it myself
If this is a Whirlpool manufactured top loader (such as your Kenmore), it could simply be off level. The rear feet on these washer have an auto-leveling mechanism that you can easily reset yourself. Just follow these steps:
1. With the wash tub empty, open the washer lid and grasp the rim of the tub opening (do not grab the tub).
2. Now place one of your feet at the base of the washer along the front of the washer to keep it from moving.
3. Now pull the washer towards you so the rear feet lift off the floor. You should hear a clicking sound as the rear feet auto-level.
4. Carefully set the washer back down (do not slam it) and the rear of the washer should now be level.
Using a level, check the washer front to back and side to side to make sure it is level in all directions.
If you need to adjust the washer washer front feet, carefully lift the front of the washer and turn the feet to either adjust them up or down. The slightest difference can cause excessive vibration on the final spin. Check by placing your hands at opposite corners on top of the washer (diagonally - one on the rear, one on the front) and try rocking the washer to see if it moves. If the washer wobbles, you need to readjust.
If you still have problems after checking the level of the washer, please post back and let me know. The problem could also be related to balance spring issues. I hope this helps you.
Jan 12, 2010 | Washing Machines
Top loader Maytag washer cannot balance load
The shock absorbers that hold the tank are broken. Then the load will move the washer all over the place.
Look online for an exploded diagram and order the new shocks for it
Nov 12, 2009 | Dryers
Maytag Performa Washer spins out of balance
There was a recall on the washer base, which caused the unbalanced problem. Find Technical Buletin TDL-0050B-B issued by Matag.
Jul 05, 2009 | Maytag Performa PAV2200
1984 Goldwing Aspencade wobbles when I slow down to make a turn about 10mph
Most wobbling at lower speeds are from worn wheel bearings, tires out of balance, or a bent rim. Place the bike up on the center stand (if you have one) and have someone hold the handlebars in place while you move the wheel side to side. If you can feel movement, the wheel bearings are bad. If no movement is felt, rotate the tire and watch for wobbling. Make note if the rim appears to wobble at the same time the tire does. Do the same procedure for the rear wheel as well...If you have further questions, feel free to ask...hope this helps
Jun 27, 2009 | 1984 Honda GL 1200 Aspencade Gold Wing
Out of balance spinning.
there is a spring that hooks to the back the tub of the washer and conects to the frame of the washer its there as a counter balance. if that spring was not put back in place the washer will shake like crazy. if that spring is conected the basket is warped
Nov 17, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Admiral AW22 Top Load Washer Logo
161 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
