Question about Admiral AW22 Top Load Washer
My Admiral washer machine moves and shakes all over the place on the spin cycle what is the problem
  • Anonymous Jan 31, 2009
    This does not work. This machine is a total waste of money!
    Problem Solver:
  • 15 Answers
It needs to be rebalanced.screw the front legs down first tilt the machine up from the front slighltly to automaticly re adjust the back legs (shouldnt be any screw legs there) then manualy re adjust your front legs. this happen a lot when you wash big loads or blankets and such etc. and is normal glad to help you
Posted on Jan 08, 2009
My admiral washer does not work on wash cycle. It will rinse and spin on any cycle but wash
hi Marilyn.
this is what i have found but not sure if this will help you out,if not go to the link at the bottom and see if it helps you out.
Step 1
Make sure the washer's cord is plugged in to a functioning outlet if the Admiral washer won't fill with water. Check your circuit breaker to make sure the power is on and reset it if necessary. Reset the dial and start the washer again. Turn both of the washer's faucets on to full power. Untangle any inlet hoses to remove clogs. If this doesn't work, your hose filter screens could be clogged. Disconnect the hoses from the washer and clean the screens of any residue.
Step 2
Close the washer's lid completely if the Admiral washer will not agitate. The washer will not start if the lid is open. Restart the washer by setting the control dial to the desired cycle. Momentary pauses during cycles can be expected. You may need to wait a minute or two to see if the washer starts. Check the circuit breaker to make sure the washer is getting power. Reset the circuit breaker if necessary.
Step 3
Check and reset the circuit breaker as above if the Admiral washer will not spin or drain. Untangle any of the washer's hoses to allow water into the machine. Check your drains for clogs that may be preventing water to move into the washing machine. Close the lid and restart the washer. The washer will not start if the lid is not completely closed. If there are excessive soap bubbles in the washer, the washer may have locked up because of this. Wash the load again without adding detergent.
Step 4
Rearrange the laundry so it is evenly distributed if the Admiral washer stops or if laundry is still wet at the end of a cycle. Untangle any laundry from the center post in the wash tub. Select the correct water level for the amount of laundry. Select a normal spin cycle for jeans, towels or other heavy loads. Close the lid and start the washer.
Step 5
Check the hoses to make sure they are tightly connected to the Admiral washer if it leaks water. If they are loose, tighten them with a screwdriver. Make sure the drain hose is secured to the drainage area. Avoid putting too much laundry in your machine or soaking laundry for over 30 minutes.
Step 6
Make sure the Admiral washer is on a level plane if it is excessively noisy. If it is not on even ground, move the washer so that it is level. Remember that some washer noise is normal. Thin floors can cause the washer to vibrate and move about and the noise level may rise and fall depending on the speed of the cycle.
admiral washer does not work on wash cycle Google Search
Nov 25, 2017 | Washing Machines
Admiral washer machine tub appears loose and unattached in rrear
First of all is your machine working or not?
If it is working and it's a front loading machine. The machine drum is hanging inside the machine using strong springs that helps it to reduce vibrations during washing and spin cycle.
When machine goes into spin(dry cycle), it usually shakes a little.
Dec 08, 2014 | Admiral Washing Machines
When washer gets to spin cycle it shakes and moves about the laundry room and does not drain
You will have to quit washing your concrete blocks with your red bricks.
When this problems begins you have to readjust the load to balance the spin cycle.Move item around to make the load more pound wise equitable.
Jan 29, 2011 | Admiral Washing Machines
Washer is shaking violently when it is time for the spin cycle
Check to see if all shipping blocks and bolts were removed. Refer to installation and setup instructions for your model.
I once moved into an apartment furnished with washer and dryer. The washer had worn holes in the vinyl flooring and a neighbor said the previous tenant made her son sit on the washer to hold it down. I investigated and found the shipping bolts were still in place. The tub, which is supposed to be able to swing, was rigidly held in place, so the entire machine danced around the room!
Jan 10, 2009 | Frigidaire 14 Cycle Tumble Action Washer
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Admiral clothes washing machine AAV7000AW
Hello calmtouch,
You said,
When in spinning cycle, the barrel begins to move all over banging the washer across the floor. I don't even know what to look for.
Help.
sounds like the coupling connecting the tub to the transmission may be loose and throwing the wash tub out of rotation causing the banging and walking washer.
Bless You
Huuum
Sep 19, 2008 | Admiral AAV7000A
Admiral Washer not spinning
broken or slipping drive belt, ( motor) to spin pulley , losse pulley, defitive drive clutch, spin brake fails to release, or transmission is frozzen
Jul 07, 2008 | Admiral AW22 Top Load Washer
90 Series Top Load Washer shakes during spin cycle
The Guide Plate underneath is out of alignment,, You might have to call me on this one. The only reason I am sure of this is because when my delivery guys would deliver a direct drive washer such as your, sometimes when the machine is laid down to far on its side, it gets out of alignment. Easy fix,, Just hard to explain.
Mar 24, 2008 | Kenmore 22422 Top Load Washer
Admiral AW22 Top Load Washer Logo
251 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
