Question about IBM ThinkPad 380ED
IBM Thinkpad 380ED; CRASHED; PROBLEM WITH LOADING DELL IBM
I have an IBM Thinkpad 380ED, Window was installed, it crashed, but I had a dell computer with windows software,. I can't get the software to reload on my thinkpad because it says write protected. I have deleted partitions...it comes on.. I have Dell windows xp and drivers...but how do I install the program on to my thinkpad when it's write protected. PLEASE HELP..ASAP...I also have a desktop with xp installed but I got it from a small computer store with xp already installed.
Upgrading from vista to win7
I would start by deleting partitions and doing a full format. Then loading an OS. Check MS minimum system requirements for OS and double them.
If it crashes again. Start checking RAM.
Sep 27, 2012 | Dell Computers & Internet
My harddrive crashed and I got another computer from a friend the crashed computer is a dell -the one i got from a friend is an acer --I installed vista home version on the acer using the dell cd--can I...
No, those product keys are called OEM which means they are tied to the computer it was sold with. Even if you got another Dell you cannot use that product key. However the acer may have its own key that you can use.
Mar 16, 2010 | Microsoft Windows Vista Home Basic Edition...
Tried to install update and computer crashed
A few ways to try and eliminate.
Upon startup F8 for safe mode: Last Know Configuraton
Hit F8 for safe mode. Go into accessories>system tools>system restore
Doesn't work then: need Windows CD setup. Let it run and hit R for Recovery Console. At the DOS prompt type FIXMBR or FIXBOOT.
Mar 05, 2009 | IBM ThinkPad T30 2366 Notebook
Ibm thinkpad 2635 desplay drivers
westy351,
here's the link for you to download the required driver, don forget to download the driver for Access IBM as well.
ThinkPad 380ED 26356AU
Dont forget to rate my solution. Thanks.
Jan 07, 2009 | IBM ThinkPad 380ED
IBM 2635-6AU
update bios ibm thinkpad type 2635
Oct 02, 2008 | IBM ThinkPad 380ED
My ibm thinkpod 2647 always hang's up
It could be that the hard drive crashed. It should be looked at to see if that is the case.
Jun 10, 2008 | IBM ThinkPad T20 2647 Notebook
IBM THINKPAD 2635-5AA 380ED ERROR 174
Your problem sounds like the system isn't finding the hard disk
May 01, 2008 | IBM ThinkPad 380ED
Hi my IBM 2635-6AU, ThinkPad 380ED 26356AU screen is dark and i cant see
From what you are stating it seems like your backlight in your lcd needs to be replaced. Plug an external monitor up to your laptop. Press the fn & f key (the one with the picture of a monitor in it.) Your diplay should project to the monitor. Display is ok.....replace the backlight.
Hope this helps you
Oct 26, 2007 | IBM ThinkPad 380ED
O&O DriveLed 2.0 Crashes the whole Machine
When you say crashed do you mean completely or is it whirling at the 1st boot up for example XP bios area?.
Aug 26, 2007 | O and O Software DriveLED 2.0 (20204) for...
IBM ThinkPad 380ED Logo
159 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
