Question about Pioneer PDP-4270XD 42 in. HD-Ready Plasma Television
Tv stuck on standby
My tv is stuck on standby. It switched itself off. And now, when the power is supplied, the standby light comes on but the tv will not switch on.
  • 41 Answers
Power supply probably needs to be replaced if you don't even hear the relay click after the power is switched on.
Posted on Mar 30, 2009
My Baird jo47 won't turn on and the standby red is flashing with sound what is the problem
My baird JO47 tv is stuck on standby - Digital TV - Streaming ...
www.tomsguide.com/forum/55998-4-baird-jo47-stuck-standby
Dec 17, 2012 - 4 posts - ‎2 authors
My Baird JO47 tv is stuck on standby and won't come off. ... I have a panasonic 50" TV it will not turn on no green light or standby red light ... Forum; my tv standby light keeps flashing blue on and off and won't switch on Forum ...
Baird JO47 Stuck on Standby ' Electronics Forum (Circuits ...
Dec 15, 2015 | Televison & Video
Power on flashes twice then shuts off
No. i think you have a power problem the switching power supply of your tv is damaged. But you can try to reset it if you know how.
Oct 18, 2017 | Emerson CR202EM9 TV
Tv stuck in standby, red LED is on. How do i rectify this problem??
Could be an open internal fuse or power supply failure
Nov 21, 2017 | Televison & Video
Tv stuck on standby
The internal power supply may have failed.
Nov 04, 2013 | Televison & Video
LCD tv switching itself off
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.4_10_2012_2_12_56_am.jpg
Look for puffed up caps like these in the power supply board.
All this info is just someplace to start and may or may not resolve the problem--it is where to begin.
Apr 09, 2012 | Televison & Video
Lg 50pk550 wont turn on
Repair kit Now available on Ebay.. BUY NOW
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=200884727409
If you have any one of these LG Models TV below, and all of a sudden, the screen lights for only a few seconds, then goes into standby with a clicking noise. [Stuck in standby] When you try to switch it on, it tries but then just clicks and goes back to standby? In this video, I show you the components that goes bad, and the culprit that causes it all. The power supply board has already been bought from Ebay, but I'm still selling the voltage regulator that is dang near impossible to find on ebay, as well as the REPAIR KIT for this power Supply Board. Board model number EAY60968801. With any one of these PCB # EAX61392501/7, EAX61392501/10, EAX61392501/11, or EAX61392501/12 Please Make sure that you've already gone through the process of troubleshooting and testing your tv's power supply board before making any purchases.. I recommend that you get a tv tech to check it out, because every tv is different. Remember, the component, and the repair kit will only repair power supply model (EAY60968801) with the appropriate PCB numbers. You buy at your own risk
Mar 10, 2012 | LG 50PK550 50 in. TV
LG 32LH2000 My TV was turned of last night in the usual way, the power turned off on the remote control, then the power supply switched off and the plug removed. This morning I attached the power...
most LG have a "vacation switch" on the bottom right hand side of the set very near that standby light.
it is placed poorly, where you can accidently click when grabbing the TV to move it or swivel it.
it is a toggle switch, a "master power" switch.
you may have bumped it to the off position. flip the switch, your standby light will come back on.
Apr 16, 2011 | LG 32LH20 32 in. LCD HDTV
TV will not switch out of standby
Unplug,replug the tv an hour later,let the tv reset itself,might work again.
Apr 26, 2010 | Philips Magnavox 27MS343S 27" TV
Won't Turn On....Immediately Switches To Standby
Did you get your tv fixed? It may be the Sub power supply unit. If the main supply went out it would not light the display at all. Yes it is time for th repair shop. Good Luck.
Jan 25, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Pioneer PDP-4270XD 42 in. HD-Ready Plasma Television Logo
2,451 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
