Will not print from a computer. Exclamation point on screen
SOURCE: konica minolta bizhub C252 printer Problem
Is anyone else having problems getting Konica to stand behind its products.
SOURCE: bizhub 250. error c2152
Check and make sure there are no jams by the fuser ie: bits of paper in the paper path.
SOURCE: where is the volume setting for the Konica Minolta
Touch Utility/Counter key
Select User Management
Controls for sound (beeps) and volume are located there
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
SOURCE: how to scan to smb with konica minolta bizhub 250
create a folder on the pc you want to scan to and share the folder on the network. This must be done or the printer will not see the folder. Then register a new SMB user on the bizhub and direct it to that pc's IP and the shared folder.
