Question about Kenmore 82822 Electric Dryer
Amana dryer dle330raw tenson on belt
I have a amana dryer dle 330 raw the belt is off the tensioner how do i get back on
    Problem Solver:
  • 16 Answers
Usually very simple. You need to get the diagram for our model. Most dryer belts go around the drum, around the tensioner pulley and around the motor pulley. You need to take off the front, top and rear panel depending on model. I can change mine in about 15 minutes complete job.
Posted on Jan 09, 2009
My Amana distinction started making a loud sound like maybe the belt and I have to take cloths out of it. Now it stopped altogether. Is it the belt or drum?
Amana Dryer Makes Noise - Model DLE330RAW - Repair ...
www.repairclinic.com/...-/Amana-Dryer-makes-noise-DLE330RAW
When the drum rollers are worn out, they can cause the dryer to make a loud rumblingnoise. To determine if the rollers are worn out, inspect the rollers. If one or ...
Nov 26, 2015 | Amana Dryers
Wont come on
At May be No guides are always there to provide technical support to troubleshoot Amana DLE330RAW Electric Dryer Problems which is free of cost. You can also get Amana DLE330RAW Electric Dryer, Dryers Help from archived solutions related to repair, maintenance, upgrades and installation problems.
Dec 16, 2010 | Amana DLE330RAW Electric Dryer
Where is the heating element on a amana dle dryer
Depends on the model. Usually on the back lower left side under tub or right behind the tub in the top center. The frist location you remove the front panel to get to element and the second location the lid has to be raised up
Mar 02, 2010 | Amana DLE330RAW Electric Dryer
How to Open an Amana DLE330RAW Electric Dryer
pull the nobs remove the back panel and you will see more screws and then gently pry it u(unplugged ofcours) and it shoud pop off.screws are in the side too I think
Dec 20, 2009 | Amana DLE330RAW Electric Dryer
How to install drum belt in Amana Model LED20AW. This model does not have front or back panels to remove. Fabio
Pull the front panel off, remove the top screws and tilt top back. Rout the new belt around drum at the old wear spot with the grooved side against the drum. Next remove the back access door and rout the belt around the idler pulley and motor pulley. There is only one way to do this and get proper tension on the belt.
Also, when you order the belt, ask if it has a belt routing diagram on the belt package.
Apr 07, 2009 | Amana DLE330RAW Electric Dryer
How do I reset the belt tensioner on my dryer
there should be a screw for ajustment adjust the screw
Feb 12, 2009 | Amana DLE330RAW Electric Dryer
I have an Amana Elec. Dryer. Model # DLE 330 RAW that all of sudden quit heating. This dryer is about five years old. It has 7 cycles and 3 temp controls. Could this be a bad heat control switch or a...
It could be a circuit breaker, fuse, or electrical problem. Just because the motor runs doesnt mean it will heat.
You should check for power first.
Then unplug the dryer remove the lower front panel, two screws.
Mark and label any wire you remove so you know where they go!
in the back on the left is the heating element, check for burnt wires, take the element out and check for a broken wire on the back side also check all the thermostats, and electrical components to make sure they are good.
ask more questions if needed
Jul 15, 2008 | Amana Dryers
Opening up the dryer
Usually you can access the belt by uncovering the back panel or bottom end. Then you can access the belt. Good luck
Aug 07, 2007 | Amana DLE330RAW Electric Dryer
Kenmore 82822 Electric Dryer Logo
115 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
