Question about Sanyo DP42746 42 in. Plasma Television
Sanyo dp42746 Suddenly no picture, minutes later, no sound.
Can you explain in a little more detail, how to test the main y board. I am trying to check the power supply as you suggested but cannot find exactly where I am supposed to unplug. When you say just to the left of the power supply box, are you talking the box that the cord runs from to plug into the wall?? Thanks
  • 9 more comments
  • walker555 Jan 08, 2009
    You were correct. This is my problem. I have found the y-main for sanyo but they look different than my y-main. The y-main I have (and all the boards inside) has a samsung logo on it. I found the Samsung y-main and it does look like mine. Would you recommend buying the Samsung model or the Sanyo? Are they interchangeable? Weird. Also, not sure what exactly the top and bottom buffers are??? Just want to ensure I order the right parts. Thanks a million!!!
  • walker555 Jan 15, 2009
    In contact with Sanyo right now to get parts for this t.v., then need to make the repair:) Will post the outcome!!! Thank you very much for your help and will rate the solution upon receiving and installing the parts. By the way, they said they couldn't send the panel0. What exactly is the panel0?????
  • davidyunus Jan 22, 2009
    I have unplugged the yMain board from the power, and the electricity sound in the main Y went away, but they screen is still black. Does that mean i have more issues besides the y main and the ybuffers? I appreciate your time.
  • Anonymous Feb 04, 2009
    no picture
  • walker555 Apr 02, 2009
    I recieved the y main and upper and lower y buffers and had them installed by a tv repairman. He called today and said I now have sound but still no picture. Any other ideas???
    I had a tv repair man replace the y main and upper and lower y buffers. I now have sound but still no picture. Any other ideas???
  • walker555 Apr 03, 2009
    The parts came directly from Sanyo so I am guessing they are new. I do think there is a strong possibility of error on the tech's part but before I tear into it and try to figure it out myself, how confident are you that this will fix the problem? (I only ask because I have not done this before and it will take me much longer than average to read the schematics and figure it out) Not many choices for tv repair where I live so I truly appreciate your help!!!
  • Sundog33 May 11, 2010
    My 42" went out today - 2 years old. I took the back off an noticed a ossillation noise coming from that Y board. I wrote down the board number and googled it and found this site. The scarry thing is I have a 52" of the same Sanyo in the den...........but this sounds like a Samsung problem. They make that board and it looks like its used in a lot of different brands.
    Slap, what do you think of the idea of opening up the 52" and swapping the boards to see if it works before I buy? Do you have any idea whats taking out these boards? I'd hate to have 2 TV's down.
  • Jeremy  Sluder
    Jeremy Sluder May 11, 2010
    The power supply board is the large board dead center of the unit. To the left of the Power supply is the Y main. Uplug the connector running from the Power supply to the Y main. Its a large plug. Just unhook it and the set will then come on with no picture if the Y is bad. If it does order the Ymain and the top and bottom y buffers.
  • saryejade
    saryejade Oct 05, 2012
    heres a copy of the letter I sent to sanyo. This is such a common problem, I thought something should be done about it. Just email me or the company if you agree. Sanyo's email is support@sanyotv.com To Whom It May Concern, I purchased a flat screen television model number DP42746 about 3 years ago. The picture and sound just randomly shut off and never came back. After doing some research, I found that many other people are having the same issues in the same time frame. Not only are the televisions failing with the same errors, they are also lasting roughly the same amount of time. It may be a coincidence but these products are all conveniently failing right after your service warranty expires. In the past, televisions would normally last 10 years or more. It is unacceptable to ask such a high price for an item and rig it to fail just outside of your warranty limits. If this were an isolated case, I would attribute other factors to the televisions failing but there are THOUSANDS of complaints, same model, same time frame. Your company cannot continue to do business in this way and are liable to make reparations to every last customer who trusted your company and was let down. I am currently gathering a list of people with documentation as to these issues after repeatably being ignored by customer service and representatives of your company. Your company seems to be unconcerned with a few people not purchasing products, but maybe as we unite they will get the hint. Doing the right thing is not always cost effective but people with morals should do it anyway.
  • 51 Answers
The buffers are attached to the Y main, on the left side of the board. Samsung, sanyo, several others all have the same boards. As long as they are the right part # just go for the best price. Check www.shopjimmy.com for used boards.
Posted on Jan 08, 2009
  • Jeremy  Sluder
    Jeremy Sluder Apr 03, 2009
    Where the parts new or used? If used you probably have a bad board, or the tech didn't install them correctly.
3 Suggested Answers
  • 71 Answers
SOURCE: i want by tv sanyo -modele-dp42746
whats the problem here?
Posted on Mar 05, 2009
  • 71 Answers
SOURCE: i have a sanyohdtv 42in.model# DP42746, the wall
use a spike guard
Why is the picture on my samsung s42ax-yb03 flashing on and off continuously and buttons on tv not working properly
Sounds like main power regulator board [SMPS] fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
May 03, 2014 | Sanyo DP42746 42 in. Plasma Television
Sanyo turn it on green light comes on and stays on but tv will not model dp42746
open back panel and look for error code
to test all y sub boards remove the main power connection to the y main and turn the tv on if it powers on one of those boards are bad.. remove both sub boards. and plug in the y main. if it powers on then that board is good either, put your multimeter on 2k omh and test the upper ysub boards black connector, the top 2 pins with negative to the 5th pin positive. you should read 500-1k ohm if its way under 100 there is a short.
the bottom ysub board place the multimeters black probe on the bottom 2 pins of the black power conection and the red on the 4th pin.. results are the same.
low resistance means theres a short in the board.
Oct 03, 2011 | Sanyo DP42746 42 in. Plasma Television
Green light comes on no picmor sound
Hello Afox5, hi, make sure that there are no user controls or setup that are out of order. as a backgrounder, TV of this type mostly has two boards, power supply and main board. On the power supply board, this has two section, primary that deals with mains voltage and secondary that deals with TV supply current requirements, if you see green light mean that power on the secondary section of the power supply board of your TV is working, but it does not mean that the power supplied to the main board is correct, the supplied current produced by the power supply section to the main board that controls sound and picture needs to be checked, so voltages are needed to be checked and loose wiring, or screws needs tightening, are a common trouble, but some go to extremes like replacement of any boards.
Aug 31, 2010 | Sanyo DP42746 42 in. Plasma Television
Sanyo Vizon 42" Plasma DP42746 Was using tv when I heard a click and I lost all audio and video, could not change the channel or adjust volume. Tried unplugging and sitting for 10 minutes. Plugged back...
This is a common problem with these TVs. You can download the official Sanyo repair manual for this TV (DP42746) at http://www.eserviceinfo.com/downloadsm/43343/sanyo_dp42746.html. I uploaded it here when I had the same issue with my TV last year. The solution is almost always to replace the Power Board (Y-Main) and the Upper and Lower Y Buffers. The parts and costs (from Sanyo in July 2009) are listed below (NOTE: Sanyo will not ship these parts to anyone but a repair shop): 1. V4 Y-Main (Y-Sustain) Circuit Board (Part # LJ92-01200A, Alt Part # LJ41-02759A) - USD $139.00
2. Upper Y-Buffer Circuit Board (Part # LJ92-01202A, Alt Part # LJ41-02760) - USD $64.00
3. Lower Y-Buffer Circuit Board (Part # LJ92-01203A, Alt Part # LJ41-02761A) - USD $64.00
Sanyo charges USD $10.50 for shipping, which brings the total cost for parts to USD $277.50. From my research, a shop would probably charge between USD $500 and $700 to do this repair. FYI - there is a class action lawsuit pending against Sanyo for this issue. The V4 Y-Main (Y-Sustain) Circuit Boards fail VERY frequently in this TV due to overheating. Hope this helps.
Aug 03, 2010 | Sanyo DP42746 42 in. Plasma Television
I have a Sanyo DP42746 and it is about 3 years old. Yesterday the picture went out, but the sound still worked. It went off for a minute and then came back on. It is starting to get worse in that it is...
For what it's worth, you can download the official Sanyo repair manual for this TV (DP42746) at http://www.eserviceinfo.com/downloadsm/43343/sanyo_dp42746.html. I uploaded it here when I had the same issue with my TV last year.
Feb 23, 2010 | Sanyo Televison & Video
Our sanyo dp42746 went black made a pop sound and would not turn back on no power light or nothing
Most likely a power supply board went bad. the pop sound is bad capacitor on the board. Most bad capacitors will look like this: 18976c2.jpg
The other picture below shows a normal capacitor in the middle, but two bad capacitors on the sides of it. One with the dome top and one leaking. 5d53c3a.jpg
You can try repairing the board by replacing the capacitors or replace the whole power supply board. Most replacement boards can be found at a good price at Shopjimmy.com or Ebay.
Dec 29, 2009 | Sanyo DP42746 42 in. Plasma Television
Sanyo DP42746.Can't get tv to come on. The green power LED is on.
unplug the power connector to the tv, wait two minutes then plug it back in and try to turn on the set... this worked for me.
Dec 20, 2009 | Sanyo DP42746 42 in. Plasma Television
Hi, had a question about what you said, have a minute?
You need to replace the top and bottom y buffers when you replace the Ymain. If not, it will just go back out. If you have space, wire a 12 volt mini cpu fan near the left of the Ymain and the buffers, should last alot longer that way.
Jan 22, 2009 | Sanyo DP42746 42 in. Plasma Television
Sanyo DP42746 42 in. plasma TV
Well I have the same problem with green light and no sound and no pix. After i opened it all up i checked the main power supply board and found all fuses good and the 12vdc side of the board dead. My best guess is this power board has many problems. All the driver boards for the screen are located on the perimiter of the screen. If you loose part of the power supply board you will loose part of functions of the tv. At this time i am looking to replace the entire power board. Will let you know the location and fix soon as i find it. jim jamesgibson@nycap.rr.com
Jun 19, 2008 | Sanyo DP42746 42 in. Plasma Television
Sanyo DP42746 42 in. Plasma Television Logo
1,665 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
