Question about Neff W4380X1 Front Load Washer
Neff w4380x1gb the red led display is showing weird timings for various programme setting and the wash is reported to do just that -wash, with no rinses. i have connected a new element up but it made no difference am i now looking at a facia pcb? any help appreciated. tone.
  • tony howlett Jun 04, 2007
    sorted the main power card was faulty.
I have bought NEFF W5429XOGB washing machine but lost its user manual. i want to know how it operates.
please send me its user manual so i can use it.
thanks and regards
wakeel effendi
Posted on Jan 17, 2008
We have had the same problem - £208 for a new power board - IT DID NOT FIX THE PROBLEM
Posted on Jun 20, 2007
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
Neff H5972N0GB combination oven. Its a new item that was panel damaged at the back. On plugging it in, the panel on the right does not light up to show the settings - normally red back light. With a...
most likely the backlight bulb is broken. It depends on the type of display if it is a easy fix or not. All models after 2010 have LED backlight. But who knows maybe there is only a connector dislodged. I who say disconnect the mains and open up the frontpanel.
Feb 01, 2015 | Neff Ovens
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
Neff washer dryer V5360XOGB red led light keeps going round
THIS IS A POWER MODULE FAULT IT WILL NEED REPLACING IT SITS AT THE FRONT LOWER RIGHT HAND SIDE THEY ARE NOT CHEAP.... SORRY
Aug 09, 2009 | Neff W5340X0 Washer
NEFF washer not starting. error code 3/flashing anti-crease butto
This may be a simple control fault that can be reset by unplugging for 5 minutes or switching the breaker switch off for five minutes also. if the five minute reset doesn't restore the machine to its original operational value, you will then need to replace the main control board in this unit. it has failed.
May 11, 2009 | Neff V4380X0 Front Load Washer / Dryer
Needing to replace the brushes on a Neff W4380X1GB
not the motor but the program switch
the motor only gets instructions from that switch or program board and the motor is running well if it does the rest of the wash well
Dec 02, 2017 | Neff W4380X1 Front Load Washer
Neff washing machine with error code 6
error code 6 is drainage fault if it takes longer than 6 minutes it times out and aborts programme check filter isnt blocked and impellor spins freely,if ok may need pump replaced they are not expensive,
hope this helps
Jan 18, 2009 | Neff W5340X0 Washer
Neff Microwave H6871 no instruction book - unable to operate it
This is more of an idea than solution but have you tried disconnecting the power supply and then plugging it back in? If the red led display lights up you will know it works. Otherwise I would say it's time to replace the microwave. If you don't have access to the power supply try flipping the breaker.
Jan 14, 2009 | Neff Microwave Ovens
Neff W4380X1 LED 01 appearing
This is a water supply fault. Check that the hoses at the back of the machine are not squashed and check to see if there is water getting into the machine
Aug 31, 2008 | Neff W4380X1 Front Load Washer
Error message
Switch machine off at the wall and leave off for 20 secs. Open the door. Switch back on again and close door firmly, giving the door handle an extra hard push. Should be o.k.
Mar 24, 2007 | Neff V4380X0 Front Load Washer / Dryer
Neff W4380X1 Front Load Washer Logo
620 people viewed this question
Top Neff Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Dw Wooten
Dw Wooten
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
