Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Will pick up anything however the air inside canister is spinning
I have taken the vacuum apart and it seems that all the parts are correct. It has not work since we purchase the product from Best Buy and year ago. Thinking i can fix it I did not return it immediatly. It has never worked and will pick up even the slightest article even if I drop a feather and run over it; it will not pick it up unless I move the vacuum over the item until it does pick it up.
Please help it is too expensive of a product just to sitting next to my $20.00 dirt devil vacuum.
  • 66 Answers
Make sur the rollerbrush is turn if it isn't check to see if the belt is missing or broken if so just replace the belt
Posted on Jan 24, 2009
Henry hoover brush not rotating so not picking up
Check the ends of the rollers for a build up of hair/thread, etc between the bar and the ends. remove if found.
Dec 29, 2012 | Numatic Henry Bagged Canister Vacuum
Tip
What to do when your vacuum brush stops spinning
Household vacuums come in all shapes and varieties, but many of them are similar on the inside. There is often a brush running across the length of the vacuum's nozzle, and it spins as the vacuum runs to help **** up debris. But sometimes the brush will stop running, and you'll notice a severe decline in your vacuum's performance.
Usually when the brush stops spinning, it's because something inside the vacuum is binding it up. Dirt can get lodged inside, and hair can get wrapped around a shaft. If there is too much pressure, the drive belt can even snap.
You can usually see and clean the brush just by turning the vacuum upside down, but to get to the other internal parts you have to take the vacuum apart. On canister vacuums, this is usually pretty easy because it's just the nozzle that needs to come apart. Full-size vacuums can be taken apart as well, but the process can sometimes be more involved.
If you can get the nozzle or the vacuum's base apart and get to the parts inside, you should see the brush (which is part of a long shaft), a drive belt, and some sort of mechanism that drives the brush, which is commonly a paddle or a motor.
Hair can get caught up in any of these components and cause them to not be able to spin, as can dirt and other debris. If you clean all of the components out and put the vacuum back together, it should work just fine. The brush, over time, may become frayed or damaged, and the drive belt sometimes will snap, but otherwise a good cleaning will usually make your vacuum run as good as new.
on Jun 01, 2010 | Vacuums
My dyson vacuum cleaner doesn't seem to have the same suction power it used to. I have cleaned out the canister and have taken apart the vacuum head (for cleaning carpets) and it doesn't seem to be...
Hello, this is Ava with Think Crucial.
Most of the time the reason why the vacuum is not picking up is due to loss of suction. You may need to check for blockages of your wand and hose. Remove the wand and hose from your cleaner when checking for blockages and any damages. Make sure to turn off and unplug your vacuum from the power before doing this.
You can purchase a wide variety of high-quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Mar 08, 2011 | Vacuums
E2 series not cleaning
Are the brushes spinning on the power head? If you disconnect the power head and just leave the hose only with the water canister filled .. does it "**** up" dirt?
Apr 16, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Weak suction on rainbow se vacuum
Check for clogs in the nozzle air passages (remove bottom plate)
Check for clogs in the wand
Check for clogs in the hose (trow in a pebble or a penny and see if it comes out the other end)
Make sure separator is clean.
Remove exhaust cap (sometimes there is a sponge in the cap that gets disty and does not let the air pass through).Have in mind that it will not pick up well if the suction and the belt is good but brush roll bristles are worn and too short.
Good Luck,
Rocky
Dec 21, 2008 | Rainbow 75th Anniversary Canister Vacuum
Kenmore canister switch issue
It most likely is the hose pcb. It has the switch on it, and part of it is either just dirty or bad.
May 17, 2008 | Kenmore 25512/ 25513 Progressive Canister...
Blowing out?
Did you check the inlet down by the brush roll?
Feb 13, 2008 | Bissell 3522 PowerForce Bagged Upright...
Hep! My 3 month old Hoover Mach 5 doesn't pick up!
What is happening is the secondary filters, HEPA and the canister all need to be cleaned. This is vital. What the vacuum repair people are keeping from you is that tidbit of wisdom. This particular vacuum is picky about airflow. Pull the canister, and on the body of the vacuum on top of where the canister sits are the secondary filters. There should be a sticker explaining how to remove them. Clean them throuougly, mine was filthy. Make sure you clean the canister by unlocking it and cleaning out the micro holes and the cone end. Mine was completely plugged. Now brush the dirty side of the HEPA filter with the combo tool. Let the secondary filters dry completely (you can blow dry them on cold) Re-install everything, and the vacuum will run like brand new. I vacuumed the whole house after I completed this maintainence and it works like a champ. Don't return this vac until you clean it completely.
Feb 06, 2008 | Hoover Commercial C1660-900 Bagless...
Kenmore 23613
if it smells like burnt plastic it is something wrong with the motor part, but if it is a wet dog,burnt hair gross kinda smell it cool change the bag and buy deoderizer tablet to put under bag kinda like a airfreshener. if it dont work like it used too not picken up like should something wrong
hope that helps,
Dec 29, 2007 | Kenmore 22085 Bagged Canister Vacuum
Canister works, vacuum doesnt
There could be a break in the electric from the machine to the hose - or from the hose to the wand - or from the wand to the Power Nozzle - or it could be the motor is bad.
Wiggle the cord at the Hose with it running- then go to the Wand - then to the Power Nozzle. You may find a break in the wires anywhere along the line.
unplug the Vacuum:
If you have a meter check to see if the reset is working - and last check to see if the motor will work removed from the Nozzle.
Ralph
ifix@shentel.net
Oct 17, 2007 | Filter Queen Majestic Canister Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
52 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
