Question about Hitachi 53UDX10B 53" Rear Projection Television
ROLLING PICTURE HATACHI
WHEN I TURN ON THE TV, 50 INCH PROJECTION TV, THAT I BOUGHT AT A ESTATE SALE, THE PICTURE ROLLS CONTINUOUSLY. WHEN IT WARMS UP, 15 MINS, THE ROLLING SLOWS DOWN BUT NEVER STOPS. IF ANY WORDS OR ADS WITH WORDS SCROLLED ACROSS THE SCREEN IT ROLLS AGAIN.I CHANGED SATELLITE CABLES WITH NO CHANGE.
THE PICTURE WAS FINE WHEN PURCHASED,MAKES ME WONDER IF SOMETHING CAME LOOSE IN TRANSPORTING TO MY HOME.GREAT PICTURE WHEN NOT ROLLING HELP ME
  • Hitachi Master
  • 5,138 Answers
Replace Verical IC and componets in same circuit maybe 2or3 bad capacitors. 100uf 35v ,1uf or 2.2uf 50volt. you need to order vertical Kit.
Posted on Jan 08, 2009
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
Jun 23, 2010 | Sony KP-51HW40 51" Rear Projection...
Can not get pip to work
Pip has its own tuner, try getting a cable splitter to split the signal into the tv. If you have digital cable you may need a second cable box to do this. If your cable provider still sends an analog signal the splitter will work.
Jul 10, 2009 | Toshiba 53H71 53 in. Rear Projection...
Old magnavox 52 inch big screen tv - screen rolls, jumps, loses c
the screen on my hdtv has alot of marks on it how do i get another
Feb 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture rolling when I first turn on my tv
A rolling picture or loss of vertical sync can be caused by several components including a bad signal board or jack panel assy. You will not be able to resolve this yourself. contact a Mitsubishi authorized service center.
michtech
Feb 14, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Video picture rolls
not a lamp problem, it is a problem in the video board, verry hard part to change, probabily not something you would want to do yourself, you may want to see what a service center will charge you
Jan 09, 2009 | Televison & Video
Picture rolling horizontally and vertically
tv needs repair c2c52 and c2po5 need to remove .both should be on the signal pcb
Nov 16, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Rolling screen
my screen on my mitsubishi won't stop rolling
Aug 22, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Hatachi 50 inch projection TV
Hey king901, must be a Hitachi gremlin. I have the same problem on the same day - how weird!!! My red light flickers for a second and then goes out. I wonder if it is a power supply problem??? If you find out can you email me at sportygirl651@yahoo.com. Thanks. BTW, my set is about 8 years old.
Dec 29, 2007 | Hitachi 50UX57B 50" Rear Projection...
Picture is Rolling..stops after some warm-up
I have seen this many times. There is a 9 volt regulator on the small signal board that causes this. The regulator goes bad and the 9 volts starts dropping, especially at start-up when the regulator is cold. If the voltage is below 8 volts then the picture gets dark and the vertical becomes unstable, with the picture squeezing down and/or rolling. As the regulator warms up the voltage starts rising back towards 9 volts and the symptoms start clearing up. There are 3 regulators in a row on the board and the regulator in the middle is always the bad one. Replacing that regulator should cure your problems but it should be replaced by someone experienced in servicing Mitsubishi projection TV's because pulling the chassis out is quite tricky.
Aug 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Parental Control Passwords
According to the owner's manual, if you forget your code, just reenter ?7777? to reset to factory preset code.
May 28, 2007 | Zenith IQB50M90W 50" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
407 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
