Question about Magic Chef MCWC16MCG Wine Cooler
Magic Chef 52-bottle Wine Fridge from HD
We've had our wine fridge since Christmas, without any problems, but now it sounds like a water fountain. There seems to be no pattern at all to when it does it, and seems to have no relation to whether or not the compressor is running or not. There is no moisture exiting anywhere. It will make the noise almost continuously for ten or more minutes, will be quiet for some random length of time, then back it comes - sometimes for only a few seconds, sometimes for a few seconds, every few seconds - really with no pattern at all. I've of course cycled it on and off, and unplugged it for a spell, but back it comes. It's loud enough to be heard from adjacent rooms during the day, and from anywhere in the house at night. Running water, gurgling, not like an ice-makers fill cycle, but sort of drippy, drainy water movement. Thoughts anyone?
  • Mark8027 Jun 23, 2008
    Yes, our Magic Chef wine fridge/cooler was making the same random water sounding noises...then stopped working. Bought it at Home Depot about 3 yrs ago...we are bummed and not sure what the life span of a $150 wine cooler should be. Any suggestions on what might be wrong with it, please give answer. mmajors@satx.rr.com
bobotfel
  • 237 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
SOURCE: where can I find magic chef wine cooler compressor for MCWC52B
My Name is Mike. I have the same unit. The compressor is not bad. Replace the start relay& overload on compressor.
Posted on Jun 05, 2009
SOURCE: MIni fridge stopped working/cool.
I got mine in 2005. It stopped working 4 or 5 weeks ago. It made a clicking noise and the compressor was very hot. Compressor is under warranty but appliance repair shop wanted $125 to install it and another $75 to charge it with freon. I saw a posting somewhere else that said it was a relay switch. I ordered one from RepairClinic.com for $24.00 incl. shipping, put it in and it's working now. There's a black plastic housing on the left side of the compressor. Just unscrew that, pop the cover off (that was a little tricky) and plug in the new part. Maybe I'll get another 3 years out of it.
Posted on Aug 04, 2009
  • 47 Answers
SOURCE: E3 error code on my Magic Chef Wine Cooler - what
could be a broken fan, compressor gone, thermostat. neither one you can fix. you need a refrigeration mechanic or a new fridge
Posted on Nov 11, 2009
SOURCE: E3 error message on Magic Chef wine cooler
Taken from another poster at Home Depot reviews and similiar to what others have found...
The e3/e4 problem is the "connectors" for the fans to the middle separator shelf are put in the pathway of condensation. This causes them to get wet and rust. PLEASE NOTE: If you decide to attempt this fix, you take full responsibility for your fridge and the outcome. If you don’t think you can do this…DON’T! Call a licensed electrician. Here is how I resolved my e3 issue: 1) Unplug the fridge
2) Remove all wine and the metal shelves
3) Remove the 2 screws from the middle separator shelf, one on each side on top
4) Remove the 4 screws from the backboard, one in each corner
5) Slide out the middle shelf slowly, on the right hand side towards the front of the shelf there will be 4 connectors you must disconnect before removing the shelf (they are tucked into the shelf). With one hand on the backboard and one on the shelf, slowly take them out together
6) Once you have the backboard and shelf out, you'll see there is a black and white connector, each having a red and black wire on each side
7) These are the fan connectors that are causing the issue. Mine were brown/green and damp (not good for electricity)
8) Using wire cutters, cut as close as possible to the "black" connector on each side to remove it. You will have 4 wires left, 2 from the backboard and two from the shelf (both having a red and black)
9) Take some of the sheath (cover) off of each wire
10) Take the red wire from the backboard and the red wire from the shelf and twist the metal portion together
11) Cover w/ electrical tape!!! Or you will have the same e3/e4 issue
12) Repeat step 10 and 11 for the black wires
13) Move onto the "white" connector and repeat steps 8 - 12
14) Put the backboard and shelf back in the fridge. Be careful not to pull the backboard and shelf apart or your connection may come apart
15) As you slide the shelf in, make sure the wires you disconnected in step 5 are in the "channel" on the side of the shelf or the shelf won't slide properly.
16) Reattached the 4 connectors and then re-attach the backboard and the shelf with the screws
17) Plug the fridge back in
18) Put the metal shelves and wine back in
" Sucks that a $0.10 piece of heatshrink on the connectors could avoid this...? Bad Design.
Posted on Feb 08, 2010
I need a manual for a Magic Chef 24 bottle wine cooler...digital.
help us help you
What is the model number? Why do you need the manual? To troubleshoot? To operate or change settings? George
Sep 26, 2014 | Magic Chef MCWC30MCG Compact Wine Cooler
We have a Magic Chef MCWC52B
The light may be old, and need repairing, I would try contacting somebody local rather than buying a new one.
Nov 30, 2007 | Magic Chef MCWC30MCG Compact Wine Cooler
The refrigerator just stopped working. After looking at some complaint boards on the ewb it could very well be the compressor
compressors work for a long time the first device to check is the thermostat this is the most common fault in fridge units that are not turning on ( kicking in )
best of luck merry christmas
Dec 08, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
My magic chef wine fridge keeps making a loud popping noise every 15-20 minutes. It s model # WCMC458?
I have a Magic Chef wine cooler making that loud popping noise - Model # MCWC45MCG Could you let me know the way to fix it if possible or where to take it considering I live near Indianapolis, Indiana?
Aug 15, 2010 | Magic Chef MCWC45A Wine Cooler
Magic chef wine cooler (30 bottles) is not cooling any more
if its clicking every few minutes its the ptc relay.located to the left of the compressor behind shield with 1 screw.go to repairclinic.com...part# 1206838
Jul 21, 2010 | Magic Chef MCWC30MCG Compact Wine Cooler
E3 error code on my Magic Chef Wine Cooler - what does this mean? Not sure of the model # but its only 1.5yrs old...Thanks!
Nov 11, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Wine fridge stopped cooling. Just clicks every
its the ptc relay go to repairclinic.com...type in model #...its a cheap and easy fix.if you see what the part looks like on line youll find it on cooler.should be left of compressor behind black plastic cover with 1 screw
Oct 29, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Wine fridge not cooling
It is normal for a compressor to be hot to the touch, but not super hot. clicking noise sounds like the relay located on the compressor terminals is bad. Hope this helps
Jul 27, 2009 | Magic Chef MCWC30MCG Compact Wine Cooler
Where can I find magic chef wine cooler compressor for MCWC52B
Mar 31, 2009 | Magic Chef MCWC45A Wine Cooler
I have a magic chef wine cooler (Model MCWC50DBT) and the labels keep falling off of the bottles. The temperature is set to red and we don't seem to have any other problems.
All the wine chiller set 2 temp red and white, red wine temp only for 18- 20 oC , your using white wine don't set red wine temp , set only for white temp mode,white and red wine set temp are different temp
May 27, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Magic Chef MCWC16MCG Wine Cooler Logo
378 people viewed this question
Top Magic Chef Refrigerators Experts
vince
Marvin
Marvin
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
