Question about Canon LaserClass 9000L Plain Paper Fax
Laserclass 9000l I im sending a 7 page fax and it stopped after 3 pages now it wont fax at all what can i do
  • 59 Answers
What porbably happens on the Fax 9000 is the memory is almost full. What you can do is press data registration and set, scroll down to TX settings and set, scroll down to Auto Redial and set scroll down and when you get to Error TX press set and press the down arrow to Off. Then to quickly dump the memory. Pull the power plug and hold down the stop button and plug the power back in and release the button once the time and date appears. Presto the memory is clear, the speed dials are still there and once you put the document into the feeder it should indicate 0%
Posted on Aug 09, 2007
When the problem occurs what does the display say?
Posted on Jun 21, 2007
SOURCE:
Replaced cartridge and still printing light on right side of page
check the transfer roller inside of fax (foam roller) may be pinch down on one side
Feb 17, 2010 | Canon LaserClass 9000L Plain Paper Fax
Date andd time is wrong
Open one-touch speed dial panels. Press 'Data Registration' button. Press 'Set'. Arrow down until Date/time is displayed. Press 'Set'. Make required changes. Press 'Set'. Press 'Stop' to return to standby mode.
Nov 05, 2009 | Canon LaserClass 9000L Plain Paper Fax
How to program brother mfc 8460n to print confirmation sheets for when a fax is sent.thanks
Press 'Menu', '2', '4', '1'. Report Setting is displayed. Press down arrow to select "on + image". Press 'OK'. Press 'Stop/Exit'. Reference page 70 in this link to MFC 8460n on the Brother site.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_8460N_8660DN_8670DN_8860DN_8870DW_EN_1586.PDF
Nov 04, 2009 | Canon LaserClass 9000L Plain Paper Fax
How to programm my fax number
Here is a link to your Canon LaserClass 9000 users guide, unfortunately it was scanned 90 degrees off.
http://www.actcopiers.com/Manuals/LC9000.pdf
Setting up group dial will allow you to send to multiple locations with only one scan of document(s). Programming fax number should be located on page 3-5.
Oct 16, 2009 | Canon LaserClass 9000L Plain Paper Fax
How can i use a cannon 9000L laser class as a printer??
I don't think you can use as a printer. Only fax and copy
Mar 13, 2009 | Canon LaserClass 9000L Plain Paper Fax
How do get a page count off of a canon 9000L
Open the 2 panel key covers.Press dataregistration button and then the # key.1sssw will apear on the display.Press the arrow button untill printer is display.press set button,arrow button again untill print count is display press set and then the counter will be displayed.To return to normal press stop.
Mar 09, 2009 | Canon LaserClass 9000L Plain Paper Fax
"TURN RG SW OFF"
There is a switch on the operator panel. It may be under the speed dial flaps or on the upper right side of the unit.
Jun 17, 2008 | Canon LaserClass 9000L Plain Paper Fax
Send or recived fax
1st of all do check that the telephone line cord is plugged into the correct jack in the machine. It needs to be in the jack marked "line." not the jack marked "Tel."
Further questions need to be addressed, such as :Is this a recently acquired machine? or Has the machine been disconnected from the power for any length of time? or Has the machine been moved to a different location?
Dec 21, 2007 | Canon LaserClass 9000L Plain Paper Fax
Canon LaserClass 9000L Plain Paper Fax Logo
105 people viewed this question
Clive
Clive
old marine
old marine
