Question about Roper RAS8445KQ Top Load Washer
Washer won't do anything but fill
My Roper washer does nothing but fill...then makes kind of a humming sound. Does this mean the motor is gone?
  • 1 more comment
  • puppers Jan 09, 2009
    Thank you. I checked about the price of the motor...I am getting estimates ranging from $175 (independent repairman) to $238.50 (Sears). Does that sound right? I am told I will have to pull the motor out and replace the whole thing. Thanks for the help
  • Anonymous Jan 12, 2009
    The washer fills but will do nothing else.
  • benmayasam Jan 19, 2009
    The washer fills then makes a humming sound, but won't do anything else.
    Problem Solver:
  • 15 Answers
This could mean 2 things 1. check you lid switch first if it is broke your washer will fill up but the motor and pump will not function
2. your motor and pump coupling will need to be replaced BOTH THESE ITEMS ARE VERY INEXSPENSIVE USUALLY UNDER 15.00)and can be easily purchased online or at your local sears. be sure to take your model number with you. Glad to be of service
Posted on Jan 08, 2009
My Roper isn't spinning or draining. I took the motor off to check the coupling but it isn't broken or wore. When the door is down, it will fill up with water but nothing after that. When it tries t
Can you easily turn the motor by hand? If not, the motor bearings may need oil on the felt pads which surround them. Dribble it down beside the shaft at each end (after removing from washer and standing vertically). Any automotive engine oil would be fine.
Jan 20, 2015 | Roper RAS8445KQ Top Load Washer
What will the washing machine do if the timer is bad. My Roper fills up with water and won't do anything else at all, doesn't even make a humming sound. Had to drain with cup. The knob for
From the closed position lift the lid of the washer about 2'' and listen for a distinct click. Then set lid back down and should hear another click just before it closes. The wire form hinge on left side of lid actuates the lid switch. Is it broken? Let me know.
Jan 26, 2013 | Washing Machines
My roper top load washer model rtw4440vq fills with water but wont wash, spin or drain
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Sep 30, 2012 | Roper Washing Machines
The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
May 18, 2010 | Whirlpool LHW0050PQ Front Load Washer
I have a Roper Washer Model RTW4340SQD that
The lid switch is on the top left side of the top cover. If it is bad the machine will fill and stop. The lid switch must be good for the machine to agitate and spin.
Nov 01, 2009 | Roper RTW4300SQ Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Washer ax6245wv0 roper washer
  Sounds like something in pump.  This is causing motor to hum and not turn.  Motor is going off on thermal overload.  This is why the humming stops.  It may be possible for you to tilt washer back and access pump.  Remove clip on bottom and top and pull pump off motor.  Try and turn pump.  Remove hoses and see if you can see obstruction.
Oct 14, 2007 | Roper RAS8445KQ Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
132 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
