Question about Alcatel Newbridge MainStreet 3624 Multiplexer
I can't connect via terminal emulation!
I have a few 3624s and after moving them to a new work site, I can't connect to them to configure the T1s. It's supposed to be a direct connection from a terminal to the box, but I can't access the 3624's internal software at all. I've tried 4 different terminals and 3 different 3624s. I've tried patch and crossover cord. Bit rate, parity, etc, are all set properly. What could be going wrong?
How do I configure the gas hoses on the Hyosung GT250R
I have this exact same issue. For the life of me I cannot figure out how to get these fuel lines and vacuum hoses configured in the correct fashion. I'm still having a hell of a time. Are you still having this issue??
Mar 14, 2012 | 2008 Hyosung GT250R
T1 wireless router
Unless there is already a wireless router connected to T1 line in your building then yes, to use wireless off the T1s connection, you would need to add one in.
Apr 06, 2010 | Computers & Internet
I recently moved. When I did so, I received new high speed internet gateway hardware, ip addresses, etc. I connect my Linkstation Pro Duo (2.0TB) to my home network gateway, and I cannot see it on my...
You must install it again so it obtains the new addresses from your new hardware configuration. You'll need your installation CD and can find instructions/downloads on the Buffalo site (support).
http://www.buffalo-technology.com/en/
Apr 05, 2017 | Buffalo Technology Linkstation (hdh250lan)...
A user's phone calls keep dropping out during calls incoming or outgoing and the time of each call varies. We have two 3MB T1s installed in two different sites connected over MPLS. Were not having...
I would recommend starting with what is simple.
Have you tried replacing the Ethernet patch cord that the phone is connected to?
How about the curly cord between the phone and handset?
Does the phone do the same thing if you connect it to a different port?
Does a different phone do the same then when connected where this phone is connected?
Oct 21, 2017 | 3Com NBX 2102 IP Phone
Moved unit to new location. Configured w/new IP's etc. Connects to other sites with no problem. I can connect to other sites but they can't hear us. Internally unit says mic not connected. Have tried...
experiment with the hole you plug the mic in and make sure the mic is not muted. generally if there are three holes on the sound card it's the furthest from the speaker. colour code is red or close to red
Oct 21, 2009 | Office Equipment & Supplies
Linksys Wireless WRT54G Router Won't Connect
Here's something you can do.
First, power off the modem and the linksys.  Then swap the yellow cable with the blue cable (this time, connect yellow cable to port 2 of Linksys)
Now, turn on the Modem first... wait about 1 minute, then turn on the Linksys.
1. Log into the router and go to "Status" tab.
2. You should see something called Internet and under it Configuration type.  If all you see is 0.0.0.0 without a gateway address, it didn't work
3. You can also see 2 buttons at the bottom of the screen.  Click on "DHCP Release", then "DHCP renew"
4. look at the configuration type and see if it is no longer 0.0.0.0 Then try connecting to the internet to a website you have not visited (do not try the same websites as before when you initially tested).
Jun 29, 2009 | Linksys Wireless-G Broadband Router
Losing wireless Connection
No solution known to fix this. Internal the software tries to refind itself.
In Linksys software there are two separate programs running. The video is sent to the wireless router and recorded on your computer. Whether it is alive or not and can be configured is a different program. That program requires the wireless camera be literally just a few feet from the wireless router. Say 5 feet or less. One configured you can move the camera to well over 100 feet from router fine.
But eventually it will lose connection and you have physically move camera back.
This is a major flaw of this system and why it won't work for a real application
Jun 20, 2009 | Linksys Wireless-G WVC54GC Network Camera
Connecting to internet
The network key is with the wireless router that you have. When you moved, your router reestablished itself with a new connection at a new location, and more than likely set a new key. Try reconfiguring your router with a new network key, then configure the laptop with the new key, and it should connect.
Jul 06, 2008 | Toshiba Satellite A45-S250 Notebook
Internet/ mms setting (PLEASE!!!!!!!!!)
Mine works fine- here are my settings on thePrada (multimedia settings for messages)
T-Mo MMS as connection
Proxy port is 9201
Proxy IP is 216.155.165.50
Internet mode is WAP
Profile name is T-Mo MMS
MMSC is http://216.155.174.84/servlets/mms
hope this helps
Oct 26, 2007 | LG Prada KE850 Cellular Phone
Internet connection problems using the BEFW11S4
If you are having problems connecting to the Internet, follow the following steps: 1. Internet service: Check with your Internet Service Provider to make sure that service is active. You usually can determine a good link to the service if you can bypass the BEFW11S4, plug directly into the ISP modem unit, and get a good connection. This will narrow the issue down to either the service, or the router. 2. Network cables: Verify that the network cables that connect the network together are plugged into the current ports as they should (modem into the WAN/Internet port, computers into 1, 2, 3, or 4). Also try to change some or all of the network cables that attach to devices coming from the BEFW11S4. You may have bad cables. 3. Router configuration: Your router may not be configured to use your Internet service properly. While plugged into your provider?s modem and able to get online, run the bundled Router Setup Wizard CD-ROM program that came with your router. This will configure the router automatically for you. Note: this program must be executed on the main computer when plugged directly into the providers modem unit and able to get on the Internet 4. Manual configuration: If the Setup Wizard CD-ROM from Step 2 fails to configure your router, you may need a manual configuration. While plugged into the provider modem unit and able to get online, visit http://kb.linksys.com, and search for the name of your Internet service provider for detailed instructions on manual configurations. 5. Router firmware: Upgrade your router to the latest firmware version. Please go to http://www.linksys.com/download to download the latest version of firmware for your product. After the upgrade, be sure to reset the router, by holding in the router?s reset button for 30 seconds and reconfiguring it for use with your service (Step 3 or Step 4). 6. Malfunctioning equipment: You may have a faulty network adapter, or a bad router. Please contact Linksys Technical Support for further assistance.
Feb 16, 2006 | Linksys BEFW11S4 802.11b Wireless...
Alcatel Newbridge MainStreet 3624 Multiplexer Logo
59 people viewed this question
Top Alcatel Computers & Internet Experts
Thomas Perkins
Thomas Perkins
Sameer Raut
Sameer Raut
Are you an Alcatel Computer and Internet Expert? Answer questions, earn points and help others
