Question about KitchenAid KHMS155LSS 1000 Watts Microwave Oven
Microwave starts by itself - NO JOKE
I have had to shut the circuit braker to the Microwave, it repeatedly starts a cooking cycle by itself. It begins by asking for number of pieces, cycles through the options and then starts to cook by itself. It is very dangerous, ANY SOLUTIONS?
  • 1 more comment
  • Anonymous Apr 26, 2009
    Exact same thing is happening with my Kitchen Aid microwave. Scared the living **** out of me when I found my micro running at 4 AM! I have contacted the mfr and of course....NO RESPONSE after one week.
  • Anonymous May 25, 2009
    My microwave was beeping on its own. Then I noticed that the key pad had locked on its own. Well it went away and now it's back and incessant! I have unplugged the microwave for fear that it will turn on (it has not done that yet).
  • jyoon181
    jyoon181 Jun 12, 2012
    I have KitchenAid YKHMS2050ss-0 that has exact same problem so I do believe you. Only thing I can't believe is that I will have to fix it out of my pocket since it is out of the warranty period. I really dont think electric control pad something that can "broke" under a normal use (we use it avg 3 to 4 times a week mostly to reheat leftovers). I really think they should responsible for correcting inherent defects and not hide behind their warranty excuses. Shame on KitchenAid and NEVER buying their product ever again. I will tell all my family/friends/coworker/clients about self starting microwave that has mind of its own and their manufactuer that refuses to be responsible.
  • KitchenAid Master
  • 9,098 Answers
You have a shorting membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If not, please reply back with your brand and model number so we can help you better.
In many brands there is a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
We're happy to help you. Once we have all your information and offer a final solution, we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
Posted on Jan 09, 2009
    Problem Solver:
  • 7 Answers
First, do not leave this machine plugged in until it is serviced. If this is a KHMS155LSS, there is a very high probability that you have a keypad short. This defect can cause the machine to start on its own at ANYTIME; at night, while you are away, at work etc.
Contact Whirlpool Customer Service and ask for Safety Dept immediately. They will most likely send A&EMicrowave starts by itself - NO JOKE - 2.gif (Sears) out to fix it. Although they will fix the problem, if the keypad fails again, the underlying self start logic defect is still present. You should be under warranty if it is above model. Please be polite, insistent, but polite. With KitchenAid's pathetic quality in recent years, their customer service reps get more then an earful.
Also, please go to the Consumer Product Safety Commision website at and post a Report Unsafe Products report. This will help get this model recalled before someone loses their home or life.
I almost had a fire this past Monday, Labor Day2.gif, 9/7/09 when my machine self started at 3 AM with a package of bacon left in it to thaw at room temp for the morning. What a smokey mess.
Chinese made garbage. Shame on Whirlpool. Long live Hobart!, please buy back KitchenAid and bring back the lost quality.
Posted on Sep 09, 2009
    New Friend:
Similar problem with my Frigidaire (Electrolux) PLMVZ169GCD from 2008, it would start randomly by itself or if you banged on the bottom of the keypad or pushed up/down on the door handle.
CAUSE: the ribbon from the keypad comes thru a cutout in the metal that it is mounted on to attach to the control board. The cutout has very sharp sides and the ribbon was rubbing on 1 side of it. You couldn't see any damage (very small), but it appears to have cut thru the insulating layer and was starting to short some of the lines to either ground (the mounting plate) or each other.
SOLUTION: I added an insulator (fish paper from an old pinball switch) between the ribbon and the cutout side and then used electrical tape to hold it in. The electric tape itself would probably work. You just have to get the ribbon off of the metal edge of the cutout.
Took about 20 min to figure out the board removal (take pic before removing the wires!), adding the insulator and reinstalling.
Posted on Mar 09, 2018
My Kitchen Aid of 3.4 yrs did this last week. Local independent dealer where i bought the unit replaced entire touch pad - mother board unit. Not 20 minutes later it did it again. Now, repairman just left puzzled. Wants to take it to shop to "look at." I am going to push for an entire new unit.
Posted on Jul 30, 2009
I have a Kitchenaid YKHMS147HW microwave that started turning on by itself, and will not shut off unless I unplug the unit. If I put food in to cook, the food starts cooking as soon as I plug the unit in,...
Sounds like stuck relay contacts. Magnetrons need a high voltage source which is controlled by a micro to relay and then from relay to voltage source. Even the turntable works via a relay.
Oct 14, 2013 | Microwave Ovens
Ge pvm2070smss shuts down
It may be a noisy magnetron if the failure occurs in a second or two of hitting "Start" to begin cooking.
See this FixYa solution. even though your model number is different.
Otherwise, if the internal cooling fan is not running when you are cooking, it will shut down after 30-60 seconds or so and stay off until it cools back down.
Also see
Feb 24, 2013 | GE PVM2070SMSS Microwave Oven
Not heating
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
No power to microwave
Check the Power Cord
Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
Switch the Outlet on
Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
Reset the Oven
Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
Check the Fuses and Breakers
See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
Oct 04, 2011 | Microwave Ovens
Ge pvm2070 shut off and now will not come on
My PVM2070 Spacemaker Microwave quit working & its DEAD. I checked circuit braker, unplugged unit, checked power is ok, open/shut door, pushed very sensor buttons; its DEAD. Help??
Nov 09, 2009 | GE PVM2070SMSS Microwave Oven
Shuts itself off mid cooking cycle -- as if unplugged; then after 5 minutes or so turns itself back on as if it was just plugged in (forgetting all previous settings)
If you just put the fan blade back on, it will almost certainly fall off again.
The best bet is to slightly rough up the contact area of the shaft with sandpaper and use a little super glue to hold the blade assembly on the shaft, and let it set a few minutes before using it.
I always recommend that you use the hood vent exhaust fan when cooking on the stove top to keep heat, steam, and grease out of the controls.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
May 20, 2009 | GE Profile Spacemaker Over-the-Range...
Looks as though thr circuit braker is being reset.
I BOUGHT ANOTHER ONE........................
Aug 27, 2008 | Maytag Microwave Ovens
Whirlpool(GH7145XF2-0) does not work occasionally
That's how it would sound if you were cooking on a power level less than full power.
If you enter the cooking time and hit Start, it should cook at full power by default and not cycle like you describe.
If you are using some sensor cook setting or automatic type cooking setting, it may cycle like that normally.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
If you don't have your manual, you can download it free here. Check the lower right area to enter your model. number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Whirlpool GH6177XP Microwave Oven
your problem most likely is in your door aligment there are 2 arms that need to close some door interlock switches inside the unit next time press in on the door hold it and try to start or push down on the door after it is closed and try to start it
Jan 23, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave stopped working completely
Fan turned on after cooking because a thermostat got to hot and tripped turning on the fan to try to cool the unit.  The unit went completely dead when thermal fuse tripped which is located above the cavity on the left side.
Oct 30, 2007 | Magic Chef CMV1000B Microwave Oven
KitchenAid KHMS155LSS 1000 Watts Microwave Oven Logo
4,749 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
