Question about Frigidaire GLRS264ZA Side by Side Refrigerator
Icemaker woes I am at my wits end. But enough about me. For two years or so now, I have been having trouble with this icemaker. It gets a cube wedged in the back/right slot, second from the back of the cabinet. There it sits, poking its little head up at me. So I have learned to keep a dowel rod above the refrigerator to break it off, and then it (usually) goes about its merry way. Or not. It may "click" incessantly for hours if no one hears it and obeys. My husband has tried pouring warm water into the tray to loosen things up, but I find that it only causes the water to re-freeze in the bottom of the repository- thus eventually causing an icejam and jamming the auger. I have tried tightening the screw for "+" and "-", with lesser results, (honestly, I don't know if my husband messed with it and that's the cause or not. I do not know which direction to go to try to resolve it.) I have also tried to insert a screwdriver into the larger gear's screw to help it along. Which sometimes works. I am afraid that these plastic gears will soon break. Sometimes, even after I "think" I have gotten the ice cube loose from the tray (or broken out) it will start clicking again within a few moments. (insanity--now I understand Chinese water torture!) Within the last six months I have also had intermittent problems with some sort of defrost cycle where I have water pouring out the ice dispenser, down the front and causing a river on the floor. We're talking bath towels full. What do I do next??
  • Julie Lohr Jun 02, 2007
    Thanks, I realized after I bought it that I shoulda asked the repairman first. There was a big recall on them--I am no Frigidaire fan any more. Shoulda coulda woulda....
  • 23 Answers
Buy a whirlpool lol
Posted on Jun 02, 2007
Why does water drop before ice is made?
Refrigerator Leaking From Icemaker
If it's leaking from inside the freezer then it's coming from the icemaker or the drain. Lets start with the icemaker. If it's the icemaker there will likely be an ice hanging from the icemaker or just a big block of ice in the ice bin. In any case, it will be obvious.
There are a few reasons this will happen: one is the icemaker will stop turning when it gets to the fill cycle. This will happen when the gears in the icemaker break. On GE icemakers that were made before the year 2000, you can see the gears by taking off the cover on the front of the icemaker. However, if the small gear is broke you can't buy it as far as I know. I have been taking them off of junk icemakers for years. So this part may be hard to find. But if the big gear is broke replace it. Another reason icemakers leak is the fill tube is stopped up and I already discussed this earlier (replace water valve and clean out tube).
Another reason icemakers leak is that the water comes in too fast so it over fills the first cube mold. When this happens you will get a few drops of water when it fills. To fix this you have to take the icemaker out and remove the piece on the side of the icemaker. I don't know the name of it so for this we'll call it cube separator because that's what it does (most of them just snap off others have a screws). Now take silicone (RTV) and put a small amount around the first cube mold only under the cube separator. Now reinstall the cube separator and wipe off excess silicone and it shouldn't leak anymore.
Another reason that icemakers leak is that the refrigerator water valve sticks after the icemaker goes out of the fill cycle. When this happens the valve stays on and the icemaker keeps on turning, in which case, replace the refrigerator water valve.
Mar 28, 2016 | Refrigerators
Serial # k15004707 model # mf12665xew3 french doors ice maker in upper left corner. After the ice maker fills with water it drips off the front side.
May 05, 2015 | Maytag Refrigerators
How to fix a kenmore ice maker leaking water
Feb 20, 2015 | Kenmore Refrigerators
Ice maker leaking water
Jul 14, 2014 | Frigidaire Gallery Series GLHS269ZDB 36"...
I moved my GE TFX277PFSB (new in 1994) side by side to my enclosed sun porch 2 years ago when i got a new fridge for the kitchen. Today, I decided to run a water line to it to allow it to make ice again. ...
Make sure the arm on the icemaker is in the down position,if it is up and locked in place the icemaker is off. If it is down and the icemaker is turned on,each time it got cold enough the to cycle the icemaker(usually about a hour) the icemaker started and for 7 years power was sent to the water inlet valve to fill the icemaker and the icemaker side of the water valve is burnt up. The water valve has 1 inlet teh house water supply attaches to and 2 outlets 1 for icemaker and 1 for door dispenser
Gene
Aug 07, 2011 | Kitchen Ranges
Nothing is cool no ice or anything but the fan in the freezer and the fan bottom rear are working continuously
If your icemaker is producing small cubes, hollow cubes, huge cubes, or a solid slab of ice, one of the first things you want to check is the fill level. And it's not as difficult as you might think. (Hey, the hard part's wrenching that bottle out of Pookie's little fingers!) Unplug the refrig, pull the icemaker - usually one screw underneath, either 2 more or hooks above the cube mold - and unplug it. Take it to your sink and melt out any cubes with hot water. Then plug it and the refrig. back in, leaving it unattached from the freezer wall.
Manually start a 'harvest cycle' (see below) and hold Pookie's bottle under the fill tube. You'll have to wait a few minutes, because the water enters near the end of one complete rotation of the cube ejector, which constitutes a 'harvest cycle'. Regardless your type of icemaker, you're looking for 130-150 cc's, with most working best around 145cc's, but anywhere in this range should work OK.
(When replacing your icemaker with a new one, always check and adjust the water fill level this way too. You'll save yourself a lot of trouble.)
Jan 18, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Icemaker makes shells. Outside is frozen but
Hollow cubes are caused by not having enough water in the ice mold. Fill it up manually by pouring water in it and see how the cubes turn out.
look for an adjustment behind the plastic endcover with a +/- on it. - is less water. + is more water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
There is a screen filter before the water inlet valve in the water line. It can get partially stopped up with sediment blocking water flow.
Oct 28, 2009 | Freezers
The icemaker will not work
you might need to replace the icemaker or the freezer isnt getting cold enough for the icemaker to operate correctly. if freezer isnt getting cold enought for icemaker to operate correctly you should probably have it checked by a tech. if the icemaker isnt taking water you also could have a bad water valve
Sep 17, 2009 | Refrigerators
Ice maker not making cubes
You may have ice built up in icemaker where the water goes into it.  You will have to remove the icemaker and to get the ice cleared out.  Once that's done, you should be ok.
Jan 13, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Frigidaire GLRS264ZA Side by Side Refrigerator Logo
143 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
