Question about Epson Stylus Pro 9800 InkJet Printer
Epson Stylus Pro 9880 Does Not Print
I have used this printer for almost 6 months and all of a sudden it will not print. I use the Serendipity Rip and also run 2 Epson 9800's.
The 9880 does not show an error of any kind and when I send a job for printing, it goes through the rip as if it is going to print, but when it gets to the 9880 it sits idle. I have not changed anything from before, it is running through an ethernet setup. Is there a reset button or is this something that a tech must fix.
Thank You in advance for any information
  • Amrit May 01, 2016
    Moisten the pad.where the carriage comes to rest. Give cleaning comand then nozzle check.
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 24, 2009
How to fix printer blurr
most likely you're wiper for the capping station is covered in ink. I recommend having the printer cleaned by someone who does maintenance on Epson printers.
Mar 21, 2014 | Epson 9880 stylus pro Printer
Epson 9880 prints half a job, then stops
i aint too sure if its the same but i had an epson printer with the same problem last year it would print half a page spit out and then print the same half a page again and just stuck in a loop even on printing disks it did the same i found out after by speaking to a printer specialist it was the printers eeprom which is the printers memory bank that was failing and nothing can be done with it
Feb 11, 2014 | Epson 9880 stylus pro Printer
Epson stylus pro 9880 blocked nozzles won't clear
I have a 9800 - you can remove the print head, and try cleaning the nozzles manually and see if there's something on them. I'm sure any warranties would be void if you do such a thing, but - you're up for replacement of the print head anyway. So do with caution and at your own risk.
It takes about 30 mins and requires a reasonable level of skill. Search around and get the service manual - they are out there pretty easy to find. They give step-by-step procedures to get it apart safely.
Then clean the print head with either rubbing alcohol or hot water (alcohol is probably better). If your print head got stuck on tape, you might have the glue from the tape on the print head. So some kind of solvent to remove the glue - again - be careful and watch that you don't create further problems.
I've done similar with my printer and it still works fine and haven't had to change the print head for the past few years.
Feb 05, 2014 | Epson 9880 stylus pro Printer
Epson9880 no ink sent to print head
no ink sent to print head at all?problem with printer mainboard, usually caused by short circuit in head, then "burn" the fuse in mainboard.
Jan 14, 2013 | Epson 9880 stylus pro Printer
How to remove and clean epson stylus pro 7000 printer head its cloged
Welcome to FixYa!
If you have not used your printer for a long time, the print head nozzles may be clogged. Perform a nozzle check and clean the print heads.
Use the Epson Printer Utilities to do a nozzle check and to clean the printer head.
Reference Manual of Epson Stylus Pro 7500 InkJet Printer:
http://files.support.epson.com/htmldocs/pro75_/pro75_u1/INDEX.HTM
Comments and rates are appreaciated.
Thanks for using FixYa.
Jas
Feb 23, 2011 | Epson Stylus Pro 7500 InkJet Printer
Need manual and adjustment programme for epson 11880
My Epson Stylus Pro 11880 color ink-jet printer work fine but my problem is they can't print more than 7ft long & suddenly it's stop printing.
Jan 16, 2010 | Epson Stylus Pro 11880 InkJet Plotter...
9880 not print nozzle ink discharge check in self test
Go to Menu and off Auto Nozzle check ...............
I hope it may solved your porblem
Oct 26, 2009 | Epson 9880 stylus pro Printer
Epson Stylus Pro 9800 InkJet Printer Logo
827 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
