Question about NEC Computers & Internet
Computer DVD/CD Drive does not recognise any discs
NEC DVD-rw- nd3530a Whatever type of disc i try nothing is recognised - audio CD - film DVD even -RW discs I stoed data on months ago; however an EA games disc i have is always recognised
  • 33 Answers
The most likely cause is a faulty DVD drive. Replacing the DVD drive is fairly simple.
You can buy a new one online for around $25 including shipping. If you need help finding a drive or installing a drive, I can help with that. Just let me know.
Posted on Jan 08, 2009
DVD drive recognised but disc not recognised
not sure how its recognised on control panel
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Apr 05, 2012 | NEC MultiSpin ND-1300A (ND-1300A)...
When trying to play a computer generated DVD +R DL, I get a message that says this type of disc cannont be played. please insert a different disc
The disc is probably an incompatible format for this model player. Even if the disc is finalised in your PC, or in a DVD recorder, this player may still be unable to read it. Some DVD recorder/players do not recognise DVD+R (or +R DL) media, while others won't recognise +/-RW discs (except CD-RW); this is a model limitation - not a fault with either your player, the PC burning software or the discs themselves.
Nothing can be done to fix this except purchasing a model which accepts multimedia (+R/DVD-RAM etc). The question is, does your player play ANY normal DVDs? I am guessing your player will accept DVD-R DL discs just fine since this is standard as well as proper shop-bought movies.
Feb 19, 2011 | Panasonic DVD-S35 DVD Player
Dvd player not recognising any discs
Did You Try Taking off The Cover And Cleaning The lens With Rubbing ahocal
Jul 12, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Not recognising dvd player/not playing dvds
Sounds like the laser pick-up is not reading the disc, or the spindle motor is not spinning so the dvd can be read.
Jan 25, 2009 | NEC ND-3540A DVD RW Dual Layer Burner
Not working
Try unplugging it plug it back in then goto add hardware wizard if you have xp and run the wizard if that doesnt work sounds like you need a new dvd burner
Sep 12, 2008 | NEC ND-3540A DVD RW Dual Layer Burner
DVD RW / CD RW Drive
sounds as if your drive is failing, try buying a new drive.
Sep 03, 2007 | Toshiba Satellite A135-S2276 Notebook
Device Won't Recognise Blank CD-R Media or Certain Music CDs.
try and see if you can pull a directory using explorer,, sometimes if you record to the full 80 minutes capacity, the disc will return an error,,,even if you recorded it on that drive...also i know this may sound strange but on the drive tray itself take the mount where the laser is mounted and extend it out to the furthest travel point ,,,gently,,,do not force...load the disc, and see if it is now recognized,,,sometimes it is a timing issue, and this way the tray/laser recalibrates itself....
Jul 03, 2007 | LG GSA-2166D DVD RW Dual Layer Burner
Nec dvd + rw nd-1100a
first try a audio CD see if ti reads that fine. then inset a data CD and see if you can see all the files on it. Try a few data and audio CD's. If it has trouble with any of these your drive has gone to the great garbage dump in the sky.
Jun 28, 2007 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
Help Please
Sorry mate i dont understand all you have written, but this is what i use as nero wont copy most films and just wastes the discs, to copy them you need nero installed, then download a free program called dvd shrink which can be found on google. run dvd shrink put film in drive, click open disc select film, then click backup will rip it to drive then spits out disc and you put in blank and it should work fine. Hopefully this is problem you are having. All the best John
Mar 06, 2007 | Sony DVDirect (VRDVC20) DVD±RW Dual...
Computers & Internet Logo
108 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
