Question about Kenmore 20897
Washer will not agitate.
My kenmore washer will fill up with water and agitate a VERY little but not much.
  • 87 Answers
You probably have a bad transmission.
Posted on Jun 08, 2007
Kenmore 800 washer agitates before filling with water
This could be caused by a couple of problems. The water level sensor could be bad so that the washer thinks it's got water in it already or the timer could be bad. If the washer starts to fill after it starts agitating then the timer would be the problem.
May 30, 2014 | Kenmore 24032\24036 Top Load Washer
During filling reaches fL before finished filling and stops
Not sure if this was explained to u but these washers do not fill like the old top loads did... the machine uses very little water, the clothes are rolled over and over through the water as it cascades down and up through the agitator. If you look at the agitator you'll notice it does not have an elongated spindle, it's not required. Although the machine doesn't fill your clothes will be fully washed, this design was developed to conserve water...
Aug 19, 2013 | Kenmore Oasis Agitator 4.5 cu. ft....
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    Kenmore 80 series top loader washing machine 110 volt was plugged bu mistake into 220 volt outlet. Machine will no longer fill water or agitate but when put into spinning it will spin
    First off I can tell you the water valve coils are probably cooked / burned out. With POWER OFF / unit unplugged you can remove one wire from each of the coils and check for resistance across the coils. No resistance = open coil = no fill. NO FILL = no agitate because the water level pressure switch is trying to sense the water level that never rises. If there is no water then there will be no agitation.
    If you really want to see if it will agitate in it's current condition you can fill the unit with a garden hose on a low level water setting and fill it a little over half way to see if it will agitate. (You will have to remove the hose and close the lid)
    If that works then the water vavle would be the culprit causing your condition. The wire wound in the coil windings of the water valve is smaller in thickness than a human hair and would easily fail if 220VAC was put across a 110V winding.
    Feb 02, 2010 | Kenmore 24032\24036 Top Load Washer
    Washer wont agitate or stop filling on any setting
    Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
    Nov 18, 2009 | Kenmore 24712 Top Load Washer
    Kenmore 80 series washer. Agitates immediately and does not fill
    it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
    Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
    Kenmore 90 Series fills with water but would not agitate or spin
    You have a problem with the motor coupling. Top-load washers use what's called a direct-drive system, meaning it does not use a belt but what's called a "motor coupling". I probably replace 5 a week because these little guys break because of 2 reasons that i've found.
    1) The break mechanism is too dry and causing the basket to stop at a holt, which puts a lot of strain on the coupler.
    2) They break because of over-loading. I don't think you're over-loading though because it was find for 5 straight years.
    Good luck to you. The repair is kind of hard to do on your own for the first time, so I would call an authorized technician. It will run you anywhere between $90 to $120 at most.
    Best of luck!
    Jul 14, 2009 | Kenmore 22422 Top Load Washer
    Kenmore series 70 washer will only fill with water.
    I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
    Jun 30, 2009 | Kenmore Washing Machines
    Kenmore 80 Series will not fill up with water
    if your washer will agitate when set to fill but not fill, then your pressure switch is bad.
    also you may want to check and see if you are getting both hot and cold to your washer.
    Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
    Trouble shooting kenmore washing machine 80 series.
    washer will fill with water that's it, will not operate on any cycle
    Jun 22, 2008 | Kenmore 24032\24036 Top Load Washer
    Washing Machines Logo
    43 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
