Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 136 chain saw
Main idle screw for adjustment
  • Anonymous Mar 16, 2014
    diagram the idle adjustment screws on mccullogh 3214 chain saw
  • 211 Answers
Hi
high speed H=3/4 turn
low speed L=1 1/4 turn
iddle speed adjust accordingly
best regards savumihai71
Posted on Jan 09, 2009
I CAN NOT GET MY SAW TO IDLE DOWN TO WHERE THE CHAIN DOESN'T TURN. I HAVE TO IDLE SCREW ALL THE WAY OUT. WHAT DO I DO NEXT
Check the floats in the carb arent sticking and check there arent any blockages restricting airflow or restricting the movement of the accelerator cable.
Jul 28, 2014 | Husqvarna 3-pk Saw Chain 16" 3/8" .043"...
How to adjust ticover
There will be three screws on the side of the carb, a L screw, this will adjust the fuel mixture from idle to half throttle, a H screw, this will adjust the mixture from half throttle to maximum throttle, and a I or T screw, this works on the throttle spindle and will increse the idle, not the mixture.
Sep 08, 2011 | Husqvarna Chain Saw Chain 14"
Looking for a repair manual for husqvarna 136 chainsaw
Below is the link to the Husqvarna website where you can download a repair manual for free. Click the link and just find the year of your chain saw and you are good to go!
http://www.husqvarna.com/us/homeowner/support/download-manuals/?query=136&types=O
Oct 18, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How do I tighten the chain for model 136?
A link to a 2003 Husqvarna 136 follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2003/HOUS2003_O0301010.pdf
See pages 7 and 8 for chain adjustment installation/adjustment.
All Husqvarna saws may be found here:
HusqvarnaUSA.com
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Sep 07, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Reference the Husqvarna 350 chainsaw. Why does the chain continue to turn at idle? I just installed a new clutch. Adjusting the idle down causes the saw to shut off upon trying to accelerate.
Sounds like the clutch is still grabing. Easy solution is to apply the chain brake at idle to stop the chain turning. Try adjusting the L screw for a smoother idle.
Aug 05, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
How do I adjust carb on a 136 husquvarna chainsaw??
If running and you just wish to tweak it a little just follow this. If you need a starting point start at 1 turn CCW from lightly closed then follow this.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too. HTH
Lou
If your description was a little brief and I missed your question reply below and I will get back to you.
Feb 14, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How do you loosen the chain on a chainsaw husqvarna 136?
Hi there. On the outer bar cover near the motor you will find 2 nuts. Slightly loosen those two nuts. Then check around the these nuts or near where the bar attaches to the powerrhead at the front of the saw. You should find an adjustment screw of some sort, which will be the chain tensioning screw (which moves the bar forward/back depending on which way it is turned). This has the effect of either tightening or loosening the chain, so turn this screw noting whether the chain is tightening or becoming loose.
You must slightly undo those 2 main nuts on the side of the chain/bar cover first or the bar will not move and the chain cannot be loosened.
Jul 08, 2009 | Husqvarna Garden
Where is the bar oil adjusted from on husqvarna 345
Turn the Hus 345 chain saw upside down, you may see a little Icon of a oil droplet and a + - arrow by the chain. THe adjustment screw is not pictured in any of the standard user manuals,. but it is a small black slot headed screw over a rectangale metal tab by the chain. I believe if you turn it counter-clockwise, it will give you more oil,, It did for me. If you have the bar off, you can start the saw and see it come out the hole, that would verify your oil pump is working. Make sure the holes on the bar are clean also. running the saw at a fast idle for 1 min should oil the chain well enouth that it starts spraying off the end of the bar when you gun the engine.
Mar 31, 2009 | Husqvarna Forest & Garden No.967012396 345...
345 husqvarna chain saw will not run
If it idles it is not flooding out as it it most vulnerable to flooding at idle if the stalling is happening as you try to throttle it up it is likely starved for fuel. Start by changing the in tank fuel filter, and the spark plug. good chance that will solve your problem. If it does not Turn the high idle screw out in 1/8 turn increments try running the saw after each adjustment. Keep track of the amount that you turn the screw. you might have to put it back to its original position. Some times adjustment screws will vi berate out of adjustment and other times crud will cause fuel restriction opening the screw allows for a larger port for any restrictions to pass through. After you use the saw for a short time turn screw back in if it starts to stall at idle or you notice increased smoke.
Jan 05, 2009 | Husqvarna Forest & Garden No.967012396 345...
Carburetor problem
Hi
High speed H=3\4 turn
Low speedL=1 1/4 turn
idle speed t adjust accordingly.
regards savumihai71
Dec 14, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
1,161 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
