Question about Air Tools & Compressors
CHANGING OIL HOW OFTEN SHOULD I CHANGE THE OIL ON MY WESTWARD 4ME96 COMPRESSOR?
  • 70 Answers
When the oil starts to get milky color hard to give an answer also depends on enviroment and use milky oil is bad oil this means it has high moisture content
Posted on Jan 08, 2009
Oil change
Only change oil if theres sludge inside the oil carter most times its special compressor oil check the oil level with the dipstick until his own sealing ring so as not to further suppress some people pushing it completely and then the compressor is too little lubrication and splash he absolutely nothing to lubricate the piston pin and piston cylinder wall. He may even just a little bit to be filled at maximum level, compressors are not comparable with English Car, s which have had to drive down oil levels to curb oil consumption since any. a compressor nor to the brim even stop then splash he no longer good.
Dec 26, 2015 | Air Tools & Compressors
Westward 5.5 hp air compressor only runs on choke
remove carburetor, remove float bowl, carefully clean clogged fuel passages with carb cleaner, replace.
Sep 25, 2014 | Air Tools & Compressors
What compressor oil do i need for my puma air compressor
Any name brand compressor oil will be fine, just make sure to drain the old first, and then refill
May 30, 2014 | Puma Air Air Compressors Puma Air PUK5520G...
AC adapter requirements
Grainger sells the unit as well as replacement chargers. They should be able to direct you to which one you need (there are 2 available)
Mar 02, 2014 | Westward 3LE85 - Portable Power Source,...
Air compressor
isn't one but the owners manual might have some simple trouble shooting info in the back
Nov 13, 2013 | Westward Air Tools & Compressors
My air compressor will fill up with out a problem when it is empty but once it runs down and tries to kick back on the motor will not turn over. please help
Sounds like the tank check valve is bad. recommend replacing the check valve located at the end of the air discharge line and tank.
Aug 10, 2011 | Westward 4B220 Portable Air Compressor
Hello - jusy wondering if the the lubricant in the compressor must be changed and if so how often. Thanks!
yeah it must be changed just like oil in a car engine. although u dont have combustion in the cylider u still have wear. think of it as a lawn mower. when u check the oil it should be brown. not black. after its been in there too long it needs changed. the way set service intervals is your own preference and judgement. because even the recomended intervals dont need to be kept exactly basicaly its life of equiptment vs cost of matenence. an air compressor does not hold much oil so the cost is cheap i change mine ofter. u cant over change it. but if u dont change often enough u reduce the life of it. u ether go by what the book says for how many hour of run time before changing it or like i said a little more often to increase life of the tool or you go a little less often to reduce the mantenance cost.
like i said if it my equiptment i change oil often so i know it will last. and just like a car, most air compressors have and air filter. this keeps dust from damaging the piston and cylider. depending on tbhe conditions u run it in you probly want to clean the filter or atleast check it at every oil change.
Nov 18, 2010 | Ingersoll Rand - Rand Type - 30...
What kind of oil to change and how often
You must use compressor oil or at least 30W (straight weight)non-detergent oil in your compressor. Most compressor brands state the oil should be changed every 200 hours of use or three months if used regularly.
Sep 08, 2010 | Stanley Air Tools & Compressors
How much oil does a 1/4 hp compressor motor take
is it hermetic closed compressor? if it is you do not have change oil.
if it is half hermetic and have freon also not change,
if it is air compressor then change oil after 500 hours,use oil especially for compressors,not recommended to use motor oil.
Feb 22, 2009 | Samsung Refrigerators
Air Tools & Compressors Logo
236 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
