Question about Motorola Mobility W510 Mobile Phone
My MPT version 4 will not recognize all my phone contacts.
I have a W510 that came with MPT version 4. It does a great job of synching my outlook calendar and transfering media files. I tried to use the text message function of the software the other day and it pulled up the ''Select Contacts'' window. I selected ''phone contacts'' where all my contacts are stored and it only pulled up a small portion of my contacts. All of my contact numbers are designated as mobile or home or work, so in theory it should have pulled all the contacts with mobile numbers. Can you tell me why this happened? I manually added a contact from the MPT to the phone and it recognized it, even though the information was identical to a contact that was already in my phone that wasn't being recognized. Thank you for any help you can give me.
  • jasonsportab Jan 08, 2009
    All my contacts are in PHone contacts....the SIM is empty.
    Sergeant:
  • 290 Answers
Do you have some of your contacts on the SIM and some on phone memory? I have used the MPT software for many years and never had any trouble but if you have contacts in both places you might need to adjust the options to view both.
Posted on Jan 08, 2009
  • William Douglas
    William Douglas Jan 08, 2009
    ok that is odd I have never had trouble with the MPT software have you tried re-installing it? If that doesn't work might want to call Motorola support.
Contact list doubled entrys
One entry is most likely sim card and other is synched from outlook. You can usually chose contacts to display and select one or the other in contact settings.
Nov 16, 2012 | Samsung Galaxy S 4G Cell Phone
How do i customize ring tones? (i.e. use my own music, etc.)?
Please find steps to customize ringtones.
Note: in order to be able to use this method one has to have two Motorola phones: the W510 and an older one that isn't ringtone-locked (I tried a V190 and and RAZR V3 and both worked).
First create a backup directory on your drive and call it something like "Original Motorola W510 audio directory". The name doesn't really matter as long as you can find it later if you ever need those files again. Next install the ringtones you want to have on your W510 to the old uncrippled phone.
Then follow these steps:
Step 1 - Connect the W510 to your computer via USB or Bluetooth
Step 2 - Fire up P2K (latest version)
Step 3 - In the right pane navigate to P2k:/c/mobile/audio/ on the W510; in the left pane navigate to the backup directory you just created on your hard drive. It will be empty.
Step 4 - Select all the files in P2k:/c/mobile/audio/, right-click and select "copy", the files will be automatically pasted in your backup directory.
Step 5 - Delete all the files in P2k:/c/mobile/audio/. Once this is done the "audio" directory will have vanished so it's possible that P2K will crash, this is not a problem.
Step 6 - Create a new directory on your disk, name doesn't matter. Unplug the W510 from the computer and reboot it (the phone), then close P2K (if it hasn't crashed already) and plug the older Motorola phone into the computer, wait for the computer to recognize the new phone, then restart P2K. On the right pane navigate to the old phone's audio directory (same location as on the W510), on the left go to the new directory you have just created.
Step 7 - use the method described in Step 4 to copy all the files in the audio directory to your hard disk. *Do not erase any files in the old phone's audio directory*
Shut P2K down and unplug the old phone from the computer. Plug in the W510 and wait for the computer to recognize it. Once this is done fire up P2K once more.
Step 8 - Remember that the audio directory on the W510 is gone, so you can't navigate directly to it, you need to create it first. In the right pane go to /c/mobile/ and select "New Folder" from the menu at the bottom of the pane. Name the new folder "audio" and navigate to it.
Step 8 - In the left pane navigate to the new directory on your hard drive that contains the audio files from the old phone.
Step 9 - Copy all those audio files to the new audio folder you just created on the W510.
Step 10 - That's it, your W510 now contains every single ringtone that was on your old phone and all of them now have the "apply" option enabled so the W510 will now accept any of those sounds as a ringtone.
Unfortunately the W510 still won't accept sounds from any other source than the old phone but as long as you're able to get those those sounds (inclding custom sounds) to register as ringtones on the old phone you'll be able to transfer them to the W510 using the method described above. It's a little tedious but there ain't no such thing as a free lunch is there
Thanks
S
Nov 21, 2009 | Motorola Mobility W510 Mobile Phone
Outlook synchorisation failing
download the latest ActiveSync it will back up all contacts and much more, here's the link for windows vista version:
http://www.microsoft.com/windowsmobile/en-us/help/synchronize/device-synch.mspx
make sure to chose "combine data" from PC and Phone.
let me know if this helped ?
Jan 03, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Can not sync my contacts between Outlook and the BB Bold 9000
I had a similar problem just now. I fixed it by doing the following:
1. In the Blackberry Desktop manager, click the Synchronize link
2. Click the Configuration tab
3. Click Configure synch...
4. Double click the Contacts transfer (Device<--Outlook)
5. Make sure you have "Replace destination data" selected
6. Then perform the synchronization again.
Note, I am writing this from memory, not by looking at the computer step by step, so some of the wording for the screen instructions may be paraphrased.
Danny
Nov 28, 2008 | RIM BlackBerry Bold Smartphone
Pairing tungsten t3 with newer cell phones
I use Bluetooth to synch to my Sanyo cell phone, so I would think you could do the same. I maintain my Contacts in Outlook and synch with my Palm. I then synch my Palm to my phone.
1. Make certain that your Contacts (in Outlook, Palm Desktop, or whatever you use as your source to feed data to your Palm) contains ALL the phone numbers you want in your phone.
2. If, like me, you have a lot of contacts and a limited number (500 in my case) of contacts that can be stored on your phone, you will want to erase all contacts on your phone first.
3. On your Palm, go to Preferences
4. Select Bluetooth -- Bluetooth should be ON, Discoverable (Yes) and Connectable (Yes)
5. Turn on your Bluetooth-enabled cell phone -- I believe the range is 20-30 feet but I have not tested that. When I synch, I have them both on my desk because I want to see that it is working.
6. Select Trusted Devices. Hopefully, your Palm will detect the cell phone. When it does, add your cell phone as a trusted device.
7. Select Contacts on your Palm and use the pull-down menu to select Send Category.
8. Select Bluetooth
9. Select your phone
10. Your phone will probably indicate that it is receiving data. You should soon have all phone numbers stored on your phone without using a direct-connect cable.
Oct 01, 2008 | Palm Tungsten T3 Handheld
Sync Outlook Contacts & iPhone
When you create a new Contacts Folder you have to make sure that you create as a subfolder of the main contacts folder (in the create window you are shown the file tree).
I had the folders moved in different groups as well but I am not sure that it made a difference.
Please note that you have to leave outlook and itunes on for a few minutes before they synch and iTunes see the new folders.
Oscar
Sep 07, 2008 | Apple iPhone Smartphone
Downloading motorola MPT 4 for free
check this one out for options.
http://www.download3k.com/Internet/Telephony-SMS-GSM/Download-Mobile-Phone-Tools.html
don't forget to download motorola (model) USB driver software so your pc will recognize your phone in case you want to connect it with a a/b usb cable.
Nov 22, 2007 | Motorola Mobility RAZR V3x Cellular Phone
Address Book Not Synching
If addressbook is presently syncing to Contacts in Outlook, then you will need to reinstall the desktop to alter the conduits. The reinstall should overlay the present version. Just select to alter conduits when requested.
Sep 14, 2005 | Samsung SPH-i500 Handheld
Problem Hot Synching Mail with new version of Outlook
You will need to Uninstall your old Software and Reinstall the new. If yours is like mine, You will come to a page that says "Regular" or Custom" Install. You need to select Custom and will later see two choices for Outlook or Palm.
Sep 13, 2005 | Palm m125 Handheld
Motorola Mobility W510  Mobile Phone Logo
79 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
